Question about Thermador C302U Electric Double Oven
Thermador C302U error code
We recently came home from vacation and found our oven displaying the code "CAL". The command keys are not functioning, the clock works fine. I reset the breaker at the electrical box, the error code vanished but control pad is still not responsive. I was told by customer service at Thermador that "CAL" referred to a bad connection to the display board. Does this sound right? Also wondering if and/or where I can possibly get a schematic of our oven.
Thanks,
Kelly St. John
Castroville, CA
  • ncwrsl Jun 28, 2008
    have not yet tried the "hard reset", not sure exactly how to do that.
  • 6,487 Answers
From my experience when there is a power outage, This is likely to have wiped out the control board on your oven. I see it all the time after storms. If a storm comes through, I get a ton of phone calls about control boards not working anymore or doing crazy stuff. If resetting the breaker has shed no light on your situation. I would recommend replacing the main control.
Also when you get this fixed, plug the stove into a surge protector of some sort. This will decrease the chances of a power outage doing damage to the oven control.
Hope that helps........
Posted on Jun 28, 2008
    Guru:
  • 1,894 Answers
Most of error codes disappear when a hard reset is done.
did u try a hard reset first?
C302U Double Oven cooling fans shut off immediately after finishing bake cycle. Replaced control board, still does the same. What controls the cooling fans to protect the circuitry?
Newer versions of the control board software will run the cooling fans for a bit after the cycle ends, but many older models work like yours does
Aug 30, 2016 | Thermador C302U Electric Double Oven
HOW TO REPAIR THERMADOR F64 ERROR
fan issue. search for another post I did to repair this.
Aug 21, 2014 | Thermador C302U Electric Double Oven
F21 error codes
shorted cancel key. replace touch panel and relay board.
Jan 30, 2014 | Thermador C302U Electric Double Oven
CM302US Thermador Double Oven F34/64 Problems need schematic diagrams
air flow/fan issue. either bad fan motor, air flow switch or relay board.
Nov 29, 2012 | Thermador C302U Electric Double Oven
I have a Thermador Model C302U wall oven the fan on the uppper oven starts and then stops and I get the F34 code I am thinking to replace the motor but I want to know if there are other things I should...
When that fan starts up the air pushes against an air switch and that tells the board the fan is blowing. The stove uses a DAC system that relies on switchs to confirm the operations of the fan. the DAC control uses signal voltage to detect switch function. The air switches must physically close by air movement from the cooling blowers before the oven proceeds into a bake or broil mode. Reason being f the cooling motor does not function and the oven goes into a bake or broil mode, the oven will overheat and could damage the fancy smancy over engineered piece of garbage electronic components. My opinion. This is not for the DIY unless you are a TV repairman.
Nov 03, 2011 | Thermador C302U Electric Double Oven
CODE F64 WHEN TRYING TO USE THE BOTTOM OVEN.
Hi, i found out from Thermador customer service that error code F64 means that the lower fan switch (located inside the bottom trim on the right side) is not being detected as closed. In my case, this was because the header (P4) on the Display panel had broken loose from the PC board and was no longer making contact. P4 is where the lower fan switch wires connect to the control boards (actually the display panel).
Mar 29, 2011 | Thermador C302U Electric Double Oven
Oven door wont open code f53 thermador how can i get it open food is in it
Hello,.
Welcome to FixYa.
The "F53" error code on your Thermador "C" series ovens indicates a upper door lock fault, makes sense since that is the issue you described.
Whether there is actually a fault with the lock remains to be seen. Here is what I`d suggest you try...
Locate the service panel for your oven ( should be an isolated 40amp breaker ) and turn it off for a few moments and turn it back on.
This will initiate the start-up sequence which activates and checks the controls and lock assembly, hopefully resetting it to the "open" position and subsequently eliminating the error code.
Let me know how that works or if you require further assistance.
Thanks for choosing FixYa and good luck.
Regards,
Macmarkus :)
Sep 29, 2010 | Thermador C302U Electric Double Oven
We had a power outage and when the electricity was restored the oven is displaying an F1 and F7 code and is beeping the alarm, how do i stop this?
Hello, the F1 error code means internal logic failure (monitoring function) it sounds alarm and inhibit cook mode You can fix it by replacing the electronic range control (ERC)
F7 error code means the function key shorted for over 16 seconds, check for something pressing a key or preventing normal release of the key. You can fix it by replacing the electronic range control (ERC) if other component check normal.
Thanks
Jul 14, 2010 | Thermador CM302U Electric Double Oven
Thermador over/microwave/heating drawer model SMW272YP Bake bottom element will not heat up. I have replaced the element. The display pannel has been replaced in the past, but still keep having the same...
I just found out my baking oven doesn't work and I hear the fan for the convection roast, but no heat. I had the appliance man out and he said that I need a relay board! Big bucks and they don't make this model anymore. Moreover, the microwave and warming drawer work fine. This is ridiculous!
Mar 07, 2009 | Thermador C302U Electric Double Oven
Fading digital display on Thermador SC302ZS Double Oven
when the display is fading it has to be changed part number 492071 that is for a double oven display
Feb 19, 2009 | Thermador C302U Electric Double Oven
Thermador C302U Electric Double Oven Logo
655 people viewed this question
Top Thermador Ovens Experts
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
Are you a Thermador Oven Expert? Answer questions, earn points and help others
