Question about Compaq Computers & Internet
I had this given to me. i do not know how to find the memory slots to install memory
    Novelist:
  • 148 Answers
Let me get a few things from you.
1.make and model of your computer.
2. are you upgrading your memory?
3. what kind of ram do you have.
The process of installing the ram is very easy if the ram matches the computer exactly.I suggest before you attempt to install it provide me with the information and I can walk you through it.. Take care ..Be mucho blessed..Mark
Posted on Jun 28, 2008
What's your question?PLEASE HOW CAN FIX HP 5100 PRINTER CODE 53.13.03
These error occurred with the printer's memory in DIMM Slot J3 (as labeled on the formatter board). This may be unsupported memory.
To help you troubleshoot the error 53.13.03 appearing on the HP 5100 printer, please follow the steps given below:
- Press the Cancel Job button.
- Turn the printer OFF, and turn it ON again.
- If the message returns, check the memory DIMM in Slot J3 to ensure it is supported memory.
- Move to a different memory slot to determine if the slot is bad.
- Reseat or replace memory in DIMM Slot J3.
http://h20564.www2.hp.com/hpsc/doc/public/display?docId=emr_na-bpl11648
If the message persists, contact HP Support Center for further assistance from the link given below:
http://www8.hp.com/us/en/contact-hp/support.html
GuruAid.com
Jun 02, 2016 | HP Office Equipment & Supplies
I was given a Homebase DPF710KC and would like to know how to download the pictures from it to either a USB or memory card?
The Pictures are already on a Memory Card that is installed in the Home Base.... The Home Base uses:CF, SD/MMC, MS, xD Card Slots. Which are you currently using? All you have to do is take the Memory Card out and install it into your READING DEVICE (CARD READER) and then to your Computer and then you can transfer the pictures to you hearts content.
Jan 03, 2015 | Cameras
Ms-6741 ver1 mobo. blowing ram on no2 socket. help please.
first check the specifications for your motherboard every motherboard has a memory limit for each slot you will be able to install the only limited memory given by the motherboard more will cause problem as you said remove the memory stic from slot 2 and insert them to the 1st slot and see what happens if you have still the same i think you have problem with slot
Dec 29, 2011 | ASUS M3N72-D nVidia nForce 750a SLI...
NEC SXi RAM compartment third slot
I just wanted to say that this task is so easy a girl can do it since I have done it a number of times. Follow the instructions given by the first guy, he knows what he is doing.
Mar 19, 2010 | Computers & Internet
I need to know the correct ram speed for the Asus P4B533 board, thanks.I have 3 slots. I want to install the maximum possible.
here you go mate:
Memory Memory Type DDR SDRAM Number of Memory Slots 2 x 184 Pin DIMMs Supported RAM speeds 266 MHz Max Supported RAM 2 GB
Dec 01, 2009 | ASUS P4B533-VM Motherboard
Recently upgraded to vista now memory slot won't read memory stic
For the function keys to function properly install the necessary drivers by looking in the website for updates.
http://esupport.sony.com/US/perl/swu-list.pl?mdl=VGNFJ270B
Choose the Operating system and install all the drivers given in the page.
Good luck !!!
Jun 30, 2009 | Sony VAIO VGN-FJ270/B Notebook
Where is second SDRAM slot for 2nd 512MB chip installation?
This note book has one RAM installed under the keypad and at the back is the expansion slot(DIMM) for adding additional memory. So the slot u see on opening the RAM cover(Part 35 in the manual). I am quoting directly from their manual, page 50:
The notebook has no SDRAM built into its motherboard, but has two slots for PC133 SDRAM
modules: a system SDRAM slot beneath the keyboard (containing an SDRAM module installed at the
factory), and an expansion slot on the bottom of the unit.
I hope this answers your question......sodeep
Apr 29, 2009 | Computers & Internet
I have just installed more memory to my computer and do not notice any difference in the speed of my computer
you may have installed memory that may not be compatible with your motherboard
do you know what type of mother board you have..
your memory must match in this categories
1. type (ddr, ddr2, sdram, simm, rimm)
2. speed (measured in mhz or sometimes given as a pcXXXX number)
3. cas number.
4. whether is ECC, parity, buffered, registered, non ecc
5. check your motherboard documentation to find exactly in what slot your new memory stick should go and which one should go first and which one should go second (ex. if you have dimm slots and you have 4 slots (2 pairs of different color) you may need to install one memory sticks like this: memory - empty - memory -empty
if one of the items that should be matched does not correspond your computer could work but it will work at the slower speed (ex. memory 1 (slow) + memory 2 (faster) = speed of memory 1
note: don't confuse memory capacity (1g, 512mb) with speed (333mhz, pc2700)... the best thing to do is to check the documentation of *********** board or even take the memory stick that you originally have and have the store looking for the memory that you need...
Sep 22, 2008 | Computers & Internet
How to install new ram into the 2840
Unplug the machine. On the right side of the machine you will find a cover. Remove the cover and you will find 1 open slot. The machine can take a total of 224MB (96 is built into the machine) leaving 128 available. The memory type is 100pin, 133MHz, SDRAM DIMM.
Simply click the memory into the blank slot and replace the cover.
Once completed, plug the machine back in and print a configuration page. The memory total should be at 224 once you have installed your 128MB.
Good Luck
Jul 24, 2008 | HP LaserJet 2840 All-In-One Printer
Installing Memory
Hi
Yes, you can replace/upgrate the memory module under the keyboard.
Before you proceed, note that Dell Inspiron 2650 uses DDR200 3.3V SODIMM modules. Also, memory module capacities supported are 128MB and 256MB with a Maximum memory of 512MB. If the current memory installed is 128MB, you need to order 2x 256MB modules to replace/upgrade both memory slots. If the installed capacity is 256MB, you just need another 256MB for the slot underneath the laptop.
Check "Removing the Keyboard" for guide removing the keyboard to access the 2nd memory slot.
Read "Preparing to Work Inside the Computer" before committing to the above procedure.
Let me know how you get on.
Mike
May 24, 2008 | Dell Inspiron 2650 Notebook
Computers & Internet Logo
Top Compaq Computers & Internet Experts
Alun Cox
Lee Durbin
Lee Durbin
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
