Question about Maytag MSD2655HES Side by Side Refrigerator
Refrigerator and Freezer not getting cold?
My maytag side by side refrig model MSD2655HES will not stay cold anymore in either the freezer or refrig section. I have given it a few days and kept turning up the cold level on both and still nothing is happening. The manual says something about a fuse box? Can't locate this and don't know what that is. Do you know of anything that might be wrong with it?
  • 1 more comment
  • atorres45 Jun 28, 2008
    Well, I don't know what the compressor is or where it is located. Can you help me locate it? I hear a humming noise coming from my refrigerator and air is blowing. There is no frost buildup on the back wall of my freezer but there is frost buildup at the bottom of the freezer. I am also not sure what or where the condenser is?
  • tdbrown1 Aug 21, 2008
    my refrigerator will not get cold in the freezer or the refrigerator. compressor will come on for 5 seconds and stop. It is a side by side Model# LSD2615HEW. PLEAS HELP!!!!!!
  • James Helmer
    James Helmer May 11, 2010
    Is the compressor running, is there frost buildup on the back wall of the freezer? Is the condenser where the heat is moved to the air in back of the unit clean?
  • 828 Answers
The compressor is located in back of the refrigerator behind a removable panel at the bottom. But you indicated frost buildup in the freezer near or at the bottom which tells me your compressor does operate. Frost indicates a problem in the defrost system. This type of problem can be caused by a bad defrost heater, defrost thermostat, or defrost timing device. Call an appliance repair for service.
Posted on Jun 28, 2008
  • 481 Answers
Unplug the machine and let it completely defrost with the doors open overnight. then try it. if it still does not get cold then you know it is a more serious problem, like a compressor $300+
if it works for a couple days then freezes up again then you know it is a defrost problem, less serious problem <$100
I have a side by side maytag fridge model number MSD2655HES it is about 6 years old. It seems to be cooling fine but makes an intermittent buzzing noise followed by a click what could this be?
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Aug 29, 2011 | Maytag MSD2655HES Side by Side...
Freezer erator section fine, but refrig not cold
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Aug 18, 2011 | Maytag MSD2756G Side by Side Refrigerator
My Maytag model msd2657hes will run perfectly (other than a slight buzz) and then **** off. Have to unplug it for a few hours and then plug it back up and it will work fine for days or maybe even 2 or 3...
heatman101
Jul 15, 2011 | Maytag MSD2655HES Side by Side...
Refrig is not staying cold, power works, light on, freezer works.
heatman101
Apr 17, 2011 | Maytag 22 cu. ft. Bottom Freezer...
My freezer is cold but my refrig is not
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Nov 19, 2010 | Maytag 24.8 Cu. Ft. Side-by-Side...
MSD2650KES SIDE BY SIDE REFRIGERATOR - BACK OF FREEZER ICED OVER AND REFRIG NOT STAYING COLD. DEFROSTED FREEZER, WORKED FOR A WEEK OR TWO NOW THE SAME THING...HELP
either the defrost heater located next to the evaporator core is burned out or the defrost timer unit is defective in the refrige compartment controls area or the defrost thermostat on or near the evaporator coil in the freezer is defective
Jun 08, 2010 | Maytag MZD2766GES Side by Side...
The freezer is freezing but the refrigerator is not getting cold why?
check the damper door vent located between the refrige and freezer for being iced up and stuck shut,if cold air from freezer can't get past thid door the refrige will warm up,if this isnt the problem,adjust the refrige temp control and watch and see if this makes this door open and close as you adjust the temp of the refrige compartment
Apr 03, 2010 | Maytag MSD2756G Side by Side Refrigerator
The fridge does not seem to be cold.
if just the refrige isnt cold,check the damper door located between the freezer and refrige compartments and see if its open to let in cold air from freezer,if not sometimes they freeze shut and cant operate with temperature setting changes/if nothings cold,then replace the ptc overload relay located on the compressor body,it just unplugs off the compressor
Mar 23, 2010 | Maytag ZigZagW / B Side by Side...
Maytag MSD2655HES Side by Side Refrigerator Logo
550 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
