Panasonic CT-32SL13 32" TV
Problem for Panasonic CT-32SL13 32" TV
TV on getting switched on
By pushpa_ip on Jun 28, 2008
When i try to switch on the TV Panasonic CT-32SL13 it doesnt get switched on. Kinldy help how do i fix it...
Same Problem
Dec 03, 2008
-   also have same problem tv wont turn on all of asuddon tv 5 yrs old-   sssmyth
Sep 02, 2008
-   I'm too facing the same problem. its a 4 yr old tv. let me know how u fixed the problem? suggestions welcomed.-   shgp22
Solution #1
posted on Jun 18, 2009
Somewhat Helpful)
jeffreyirish
Rank: Guide
Rating: 96%, 7 votes
You will need to remove the back of the TV. Don't worry, it's not that bad.
There are 4 screws across the top, one on each side on the bottom, one right next to where the power cord goes into the back of the case, and the two more by all of the video connections **These are the most important to remove because they attach the main board to the back of the case.
Once you have remove the screws then the entire back of the set will slide off. If you look where the power cord attaches to the board you will see a small fuse. This is a 6.3 Amp 125 volt fuse. You can replace it with a 6.3 Amp 250 volt fuse from your local Radio Shack. A four pack costs between $3 and $5.
Make sure that you check that it works before putting it all back together. Check for any loose connection cables while you're back there. I found a few when I did this.
Was this helpful?
Yes
No
Popular Solutions for Panasonic CT-32SL13 32" TV
Questions and Unsolved Problems for Panasonic CT-32SL13 32" TV
Do you recommend Panasonic CT-32SL13 32" TV?
Answer
Answer
It has problem in the power supply parts.Supply is coming even for the tube.. but electronics does... (More)
Answer
picture keeps getting narrower across the screen
Answer
Panasonic CT32SL13G 2003 - problem - tv won't turn on
Answer
Well bought this TV; (Panasonic CT-32SL13 32") a while ago off of a friend, worked great up... (More)
Answer
How to change the fuse on a panasonic CT-32SL13G - FixYa
Describe your Standard Televisions problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Standard... Experts
Top TV Repairmen
in Dallas, TX
(316) 283-8873
(316) 838-0811
Authorized Warranty On Rca,Integrity In Sales...
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
close
Add to My Products
Add the things you own to your My Products collection and get product information, solutions to problems, manuals & guides, tips and how-to's, reviews & ratings and local repair service - all in one easy place.
Step 1: Select a category & subcategory
Appliances Cameras Cars Computers Electronics Home Audio TV & Videos Tools
Appliances Cameras Cars Computers Electronics Home Audio TV & Video Tools
Step 2: Select a product and click on add
I can't find my product
select
Cancel
close
Success!
Add another product
Close
close
Save This Product
Enter your email address
We will not share your email. Privacy Policy
I agree to the FixYa Terms of Use
Send to friends
Your name:
Your email:
Your friends email addresses: (e.g. Julie@email.com)
(Separate email adresses with commas)
Message:
Cancel
