Question about LG DH404E Dehumidifier
Goldstar DH404EM5 Dehumidifier
When I plug the unit in nothing happens. The outlet has power, the removable water container is all the way in and makes contact with the red interlock button but the unit will not power on. It worked fine last season but now I have this problem.
  • rdorn Nov 16, 2008
    I have exactly the same problem. Less than one year old. The unit is in my furnished basement. Not abused etc.
  • 210 Answers
SOURCE: Goldstar Dehumidifier model# DH305Y7
You can check to to see if the bucket switch is not stuck. Could also be a bad capacitor, discharge it and test it.
Sgt 48
Posted on Jun 02, 2008
  • 3 Answers
SOURCE: M7DH45B2A Dehumidifier
The fall may have knocked out some wiring -- open the unit (remove back panel, then remove front by taking out screws inside) and see if any of the cables to the front panel or control board came out.
Posted on Jun 22, 2008
We just had the same problem with an LG. Worked well for two years, then this year the fan blows without taking any moisture out of the air. The inside of the base is rusty, as if a chemical was spilled (refrigerant, perhaps?!?). Everything else looks pristine.
LG sucks! I just went out and dropped $300 on a new (non-LG) dehumidifier.
Posted on Jul 29, 2008
  • 4 Answers
SOURCE: Goldstar DH304 Dehumidifier
Take cover off. First check the fuse on the circuit board. If it's blown replace it. That should get the motor running, the motor might be or is going out. If the motor is bad you'll have to replace the motor. If the fuse is good and the motor is good, unhook the wires on circuit board that go to the humidity control switch. If the unit comes on with the humidity control switch unhooked, you'll have to replace the humidity control switch. Sears has them for about $11.50. Hope this helps.
Posted on Jul 11, 2009
heatman101
  • 43501 Answers
SOURCE: I purchased a lg dehumidifier
There are many reasons why a dehumidifier will not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
Posted on Jan 27, 2011
Hi, we have an older model Goldstar. It shows on the inside label Model DH40. Is this a dehumidifier? We would appreciate a response. It has a holding container which we assume collects water. Please...
Yes, you have a 40 pint Goldstar Dehumidifier. The holding tan., also referred to as a bucket fits into the bucket holder on the front of the unit. When installing it, be sure it fits "squarely" in to the holder from top to bottom. The bottom should not tilt down at all, when installed properly.The unit will not operate without the bucket being installed properly.
Hope this helps you, Ken and thanks for choosing FixYa.
Aug 20, 2011 | Goldstar Dehumidifiers
My goldstar dehumidifier it not working when i turn it on the machine n have no power. what can i do. in need help please
A couple of things can cause your problem.
The water collection bucket is not installed properly or is full. Remove the bucket and empty it if necessary. Then carefully reinstall it, so that it fits "squarely" in to the holder from top to bottom. It must make firm contact with the bucket safety removal switch on the back wall of the holder. Also, while you have the bucket out, check inside the top of the bucket for a float valve (if yours is so equipped), as it may be stuck in the UP position, Jiggle the handle to get to return to the DOWN position.
If all of the above fails to solve the problem, check the outlet the unit is plugged into, to make sure there's still power to it and that the circuit breaker for that outlet hasn't been tripped. If it has, unplug the unit, before resetting the breaker.
I hope the above helps you to troubleshoot & solve the problem. Thanks for choosing FixYa.
Aug 15, 2011 | Goldstar DH304 Dehumidifier
Dehumidifier fails to run a full cycle, the unit is plugged in and fails to run for more than 5 minutes. you can unplug the unit and plug it back in and the same thing happens again. i have tried different...
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
heatman101
Feb 06, 2011 | Goldstar DH504EL Dehumidifier
Auto shut off prevents dehumidifier from working even though there is no water in container.
Here is a tip that explains what can be happening to make the dehumidifier show that the bucket is full when it is not.
Dehumidifier Problem It shows Bucket Full
heatman101
Dec 02, 2010 | LG Goldstar 30-Pint Dehumidifier
I have a fairly new DH65E. Plug it in and it gets no power - nada. Outlet ok - must be in unit - any suggestions?
Yes the control board is shot...this has happened to a number of units that I have worked on...better to throw it out and get a new one...
You can also check out this dehumidifier tip
heatman101
Aug 27, 2010 | Goldstar DH304 Dehumidifier
Our dehumidifier keeps running without any water coming from the unit. The pipeline to the outside is clear. The container for excess water is dry. Is the unit gone?
Yes it seems that it is toast....just to be sure check out this tip...
There are many reasons for a dehumidifier2_bing.gif to not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier2_bing.gif.
http://www.fixya.com/support/r4662409-dehumidifier_running_but_no_water_in
heatman101
May 14, 2010 | Goldstar DH5010B Dehumidifier
My DH504ELY7 unit quit working.
look for A fuse probably gonna be internal or a lil breaker or a reset button
Feb 22, 2010 | Goldstar DH504EL Dehumidifier
NO POWER WHEN PLUGGED IN, NO DIGITAL READ OUTS
1) check power outlet
2) remover cabinet and check glass fuse on power supply board that power cord attaches to.
Jan 04, 2010 | Goldstar DH504EL Dehumidifier
I have a Goldstar GHD30 dehumidifier. I have not used it in awhile. I plugged it in to run it today and it does not turn on. I cleaned the screen and tried different outlets, nothing works. HELP!
Check the condensate collection bucket. If the bucket is not inserted correctly the dehumidifier might think the bucket is full and thus not turn on.
Aug 30, 2008 | Goldstar DH504EL Dehumidifier
LG DH404E Dehumidifier Logo
82 people viewed this question
Top LG Dehumidifiers Experts
Bill Long
Craig Butler
Craig Butler
Gil Shultz
Are you a LG Dehumidifier Expert? Answer questions, earn points and help others
