Whirlpool washer washer won't agitate or spin.
  • 2 more comments
  • lori1096 Jun 28, 2008
    I can hear the motor running. It is a Whirlpool washer that is about 13 years old. No problems ever until now.
    Do I need to take the washer apart to get to the motor coupling?
  • lori1096 Jul 07, 2008
    Does black soot underneath the washer mean that the problem is something different that the coupling?
    You have been very helpful. I bought the coupling part last week. Now I am trying to unhook the hose from the faucets. I know it shouldn't be hard but for some reason, I am having problems with the cold water hose. I will keep at it though! Thanks for all you help!!
  • 481 Answers
If you hear the motor running then it might be the coupling between the motor and transmission. minor problem, inexpensive to fix.
i need more info to speculate further.
Posted on Jun 28, 2008
  • 3 more comments
  • Mike Durland
    Mike Durland Jun 28, 2008
    yes it is the coupling, you can buy one for about $10
    look under the machine and look between the motor and transmission you will see a round rubber hockey puck looking coupling with 2 plastic pieces on either side of it. that is it.
    to replace it you have to take off:
    water pump (two metal clips, no tools required)
    motor (two bigger metal clips sometimes held by screws)
    just line up the motor shaft when reinstalling everything.
  • Mike Durland
    yes, you have to take it apart.
    you can lay the washer down on its side and look under it to see all the components i was talking about.
  • Mike Durland
    Mike Durland Jul 07, 2008
    • the black soot is actually rubber from the worn coupling. it is another sign of a bad coupling.
    •  i hope i have been more than just helpful.
  • Mike Durland
    here is a breakdown of the area
  • Mike Durland
    they can be very hard to remove. if you cant remove it from the house then maybe you can from the back of the washer.
I have a Whirlpool Gold washer (MOD# GSQ9669LW0). The washer makes a grinding noise below when in operation. Spins when agitating, but not in rinse mode. Water still pumps out in final spin.
This machine can get items stuck in the drum, the bearings can go bad etc. https://www.repairclinic.com/RepairHelp/How-To-Fix-A-Washing-Machine/38-5-620929-/Whirlpool-Washer-won-t-spin-GSQ9669LW0.
Oct 16, 2017 | Whirlpool Washing Machines
My roper top load washer model rtw4440vq fills with water but wont wash, spin or drain
see this causes and fix it. God bless you
Motor Coupling If the washer won't spin or agitate the motor coupling might have failed. The motor coupling connects the motor to the washer transmission. It is designed to fail if the washer is overloaded in order to protect both the motor and
Drive Belt If the washer won't spin or agitate, check the drive belt. If the belt is broken or if it isn't tight on the pulleys the washer won't spin or agitate properly.
Drive Motor If the washer won't spin or agitate the drive motor might be defective. This is not common. Check all of the other related parts to this symptom before replacing the motor. If the motor is visibly burned out or physically damaged, replace it.
Stator Assembly If the washer won't spin or agitate the stator assembly might be burned out. The stator is essentially one half of a motor, it interacts with the tub by creating a strong electro-magnet. If the stator burns out the washer won't spin or agitate. Check the stator for continuity. This part is often misdiagnosed.
Door or Lid Latch Assembly If the washer won't spin or agitate the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Door Lock Motor and Switch Assembly If the washer won't spin or agitate the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Motor Control Board If the washer won't spin or agitate the motor control board might be defective. The motor control board provides power to the motor as well as direction and force. If the motor control board is defective the washer may not work at all or function properly.
Sep 30, 2012 | Roper Washing Machines
Whirlpool washer WTW5510VQO will fill, spin and drian but won't agitate, just makes a clicking noise.
If this is just clicking then the agitator bearings stuck or something is jamming it.
Jun 05, 2012 | Whirlpool Washing Machines
Washer won't spin
Assuming this is a top load washer, the most common cause for the agitator not spinning is a worn and/or broken drive belt. This is located on the bottom of the machine. A youtube video link below shows how to replace a typical drive belt. If the belt is good, the problem is either a bad clutch in the motor or a bound up agitator.
Dec 17, 2011 | Whirlpool Washing Machines
What should i look for on my whirlpool washer if it hums but won't spin, agitate, or drain?
The motor may be shot if it is getting current and won't operate the washer.
Nov 04, 2011 | Washing Machines
WASHER FILLS WITH WATER, THEN WON'T AGITATE. TURN KNOB TO SPIN AND IT DRAINS THEN SPINS. STILL WON'T AGITATE
WASHER FILLS WITH WATER, THEN WON'T AGITATE. TURN KNOB TO SPIN AND IT DRAINS THEN SPINS. STILL WON'T AGITATE please show me a diagram
Jun 14, 2011 | Whirlpool LSR7333 Top Load Washer
Washing Machines Logo
29 people viewed this question
Top Washing Machines Experts
