Question about Cobra 29 LTD CB Radio
New radio I'm new at using a cb. but i hooked up my cobra 29 ltd power is on it is connected to the antenna but there is no sound but i don't know what to do.
    Brigadier General:
  • 6,966 Answers
Assuming no hardware faults, start with the basics, on powering on the radio:
1. RG Gain max clockwise;
2. Ch 9/NOR to Normal;
3. Delta Tune to mid position;
4. CB/PA to CB;
5. Squelch to minimum counter clockwise;
6. Channel selector to desired channel.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Posted on Jun 30, 2008
  • Louie  Role
    Louie Role Jul 03, 2008
    Glad to be of assistance and appreciate the rating.
I have a cobra 29 lx le hooked to a francies 5.5 whip om my 2007 kw t 600 am getting anyenna warning both radio and antenna are new frustrated
Have the SWR or match on the system checked, high match does not mean a bad antenna but can be a open or short in the system for the antenna.
Dec 11, 2012 | Cobra 29 LTD CB Radio
I just purchased a cobra 29 LTD Classic mobile CB radio.Pro tuned high performance Mosfet Final I have a palomar 450 LD mosfet linear.will i have any problems?
Not if the power output from radio to amp is set correct and the jumper for coax is correct length and there is absolute perfect match between them and the antenna used. Afterthought: also the amp better be connected to something big enough to power it.
Apr 29, 2012 | Cobra 29 LTD CB Radio
Cannot recieve all the time
You will need an SWR meter to check your antenna. FIRST.
I would find help at a local cb shop.. They SHOULDN"T CHARGE to help you SET the swr. only if you need a part or something ..
I don't charge to SET SWR"s .. only if the cust needs a insulating washer or another antenna, or new coax, so-239 etc... I would be glad to help you.. let me know if we can -- CB Shop Temple, TX
Nov 26, 2011 | Cobra 29 LTD CB Radio
How to match a antenna to a cobra 29 LTD Classic
You are actually tuning the antenna to the vehicle it is mounted on here are some very good resources. http://www.rightchannelradios.com/pages/cb-antenna-tuning-guide-pv-c0-61.htmlhttp://www.wilsonantenna.com/swr.php
Be aware that if your radio has been modified it may produce a dirt signal that an swr meter may read as reflected power. In this case it may be more accurate set with a unmodified radio also if your radio is setup for a linear it may have a deadkey to low for the swr meter to calibrate correctly.
Hope this was of help.
How to match a cobra 29 ltd classic to its antena
Have Cobra 29 LTD Classic, no sound when hooked to antenna, no light or meter movement on the RF/SWR meter, DOES have power to radio and channel display, any tips to repair, or check for problem areas?
check the squelch by turning all the way both ways. check the external speaker socket. if it is the swicthing type it could be either bad conntact or dry joints. try an external speaker to see if that works. another thing is I believe it wont work if the microphone is not pluged in or connection fault there. Good luck.
Jul 25, 2010 | Cobra 29 LTD CB Radio
Cobra 29 ltd wont transmit until warmed up for a few minutes. audio is fine, just no power out the antenna jack and not showing any on the meter on the face of radio.
Take the cover off, then hook it back up,take a pencil with the eraser end,go around the circuit board pressing down while you are keyed up, and notice the meter, see if it goes up, sounds like you have a cold solder joint, take a ohm meter and check the finals, replace them useing heat sink compound,....enjoy..... hope this helps....
Mar 14, 2010 | Cobra 29 LTD CB Radio
Cant recive from than 100 ft away new antennae still nothing
I suggest that the radio needs to be realigned to receive. If the radio has been dropped or banged in any manner this could have caused your problem.
Jul 09, 2009 | Cobra 29 LTD CB Radio
I have a cobra 29 nw ltd classic i cannot hear or be heared
Start with the antenna that you have hooked to it, is it grounded, is the coax in good shape, is the connector in good shape. stuff like that.
Jun 14, 2009 | Cobra 29 LTD CB Radio
Cobra 29 LTD CB Radio Logo
176 people viewed this question
Top Cobra Radio Communications Experts
AnyMHz.com
AnyMHz.com
Iron
Iron
Are you a Cobra Radio Communication Expert? Answer questions, earn points and help others
