Question about DFI Computers & Internet
DFI Infinity NF4 SLI won't start
I bought a DFI Infinity NF4 SLI on eBay (seller has 96.3% positive feedback). I moved it into a case that had been running a DFI Infinity NF4 Ultra until it got stuck, perhaps heat related. The SLI turns on for less than a second before turning power right back off.
DFI tech support suggested I clear the CMOS setup RAM which I did (over night). It still behaves the same way. All the fans spin up for a moment then stop. Most drive lights come on for a moment then go dark. I even went so far as to unplug everything: video, RAM, storage, front panel lights, ... Only the CPU, PSU, and power switch were still connected. It lights up for a moment then goes dark and silent.
The standby power light near PCI slot 3 is on. The RAM power light comes on momentarily with the fans and other lights.
What do I do to make this come up?
Thanks,
Steve Florkey
  • smflorkey Jun 30, 2008
    Thanks, Mike. Another PSU did the same thing. So far I have a lot of errors. I'll hope for a few more things to try.
    The two motherboards behave a little differently:
    The Infinity NF4 Ultra turns on and stays on until I turn it off or unplug it, but it gets stuck early in the POST. I just got a PCI POST reader so I'll use that to look see the sticking point which should help identify the solution.
    The "new" Infinity NF4 SLI turns on for only half a second before turning itself off. As mentioned at the top of this reply, I get the same behavior from a new Thermaltake 600W or the Silenx 450W initially used with the NF4 Ultra. This board came with the CPU installed with the AMD heatsink and fan (and too much thermal grease, but that was corrected when I swapped the CPU with the Athlon64 I bought with the NF4 Ultra).
    1G (2x512) of RAM is installed. Both motherboard power cables are connected. The motherboard is on 6 stand-offs with nothing else able to touch the solder side. An nVidia video card is in the top PCIe slot. The southbridge cooler and a case fan are plugged into the other (than the CPU cooler) two fan connectors. The front USB connectors' cables are plugged into the motherboard, but nothing is plugged into the front panel. Keyboard and mouse (KVM switch) are plugged into the back panel. Nothing else is plugged into this motherboard.
    If we cannot fix this at home, where is a good motherboard repair facility? I'd love to get both boards up (with new southbridge coolers).
    Thanks,
    Steve
    President:
  • 2,351 Answers
Hi steve, PC repair is trial & error. I suggest you replace the power supply or test the power supply in another PC that also uses 4 SATA drives & two PCI-E slots for starters. Two boards with the same problem is odd. You must have the CPU & fan connected, memory installed, ATA 24_pin main power plugg connected (Page 17 in manual). 4-pin_12v power connected which is located (Just to the left of DDR1 memory slot). Looking at you're board the power supply should be no less than 500w.
CPU must have thermal grease between CPU & heat sink.
Even though you have fans running & LED's on & flashing, the power supply seems to be the first item to check. Make sure the bottom of the motherboard is not touching the PC case.
Try the above & post you're finding here.
Good Luck!
Mike
Posted on Jun 28, 2008
Manual for LPUTNF4SLIDREXPERT
please help me find an online manual for this motherboard please mate hi brian i was wondering if u cud help me find an online manual for this motherboard (DFI LANPARTY UT nF4 Ultra-D) as im selling it on and want to check all the jumpers are in the correct positions please help me out dude, many thanks in advance for any help matey
Mar 27, 2013 | DFI LANPARTY UT nF4 SLI-DR Expert...
I want driver for this motherboard
Here are the links for the DFI NF4 driver you have requested.
Jan 26, 2011 | DFI NF4 ULTRA INFINITY Motherboard
Blue screen on windows 7 with geforce 210 and 1 GB
May be Your Problem due to corrupt RAM DDR Commonly reason of Blue Screen Problem is Ram Fault.So U can change Ur Ram May B Ur Problem Will Be Solve.
Feb 22, 2010 | DFI LANPARTY UT nF4 SLI-D Motherboard
I won an item on 1/29/10 on 2'nd chance from rockasouljewelry pd thru paypal.they sent mess.to ship as soon as positive feedback re'cd,I always leave feedback when item I get what I won.They said it is new...
This is Wrong Information. What is the Purpose of Feedback, if you offer it before getting the Stuff. This is Actually a Trick to get Positive Feedback to get Powerful Seller Tag.Once you leave the Feedback, you cannot change it to Negative. However, in case, you left a Negative Feedback, the Seller could send you a Form to negotiate and then you could change it to Positive.
Read :-
http://pages.ebay.com/services/forum/changes.html
It clearly states :-
Buyers should wait to leave Feedback for sellers until after they receive the item.
I hope it is clear that, he is trying to Play with words.
Let me know, if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Jan 31, 2010 | eBay Auctions
DFI infinity wont post
Hi...
When your computer continuos beeping the problem is the RAM you need to open the CPU casing and check the remove the RAM clean the dust then after that, reinsert the RAM to the socket, then turn on your computer. "good luck".
Regards
PCmania
Jul 13, 2009 | DFI NF4 INFINITY Motherboard
DFI NF4 INFINITY MOTHERBOARD NON BOOT
sounds like a hardware problem. try unplugging all external devices including keyboard and mouse but not monitor. test if it works. if not, open the side of the case and remove the little battery found on the flat motherboard for 30 seconds. then slide it back into place. now try to see if it works. if still nothing, check to see if there are motherboard jumpers (they will be 2 tiny pins on the board with a clamp over the top of them, you probably wont find them), if you see the jumpers, move the clamp to the spot that says "clear cmos" then put it back. or if your motherboard has a clear cmos button on the board, press it and try the computer. if it still will not boot, it could either be the flat IDE cable (for a hard drive or cd drive) or the power supply which means you will need to purchase either a new power supply or ide cable. if all still fails, i would say the motherboard is shot.
Feb 25, 2009 | DFI NF4 INFINITY Motherboard
Board stopped working
try one by one first the graphic card then with powersupply
Apr 21, 2008 | DFI NF4 INFINITY Motherboard
Computers & Internet Logo
748 people viewed this question
Top DFI Computers & Internet Experts
mukhtar21 shaikh
mukhtar21 shaikh
Tony
Steve Frost
Steve Frost
Are you a DFI Computer and Internet Expert? Answer questions, earn points and help others
