Question about Fisher and Paykel IWL12 Top Load Washer
Cold water continuously drips
My IWL12 cold water continuosly runs. It is a slow drizzle that doesn't stop unless I turn off the cold water feed. If I try to run a load the cold water will not run but just continues to drizzle. The hot water is working fine.
    Genius:
  • 1,028 Answers
Fill valve bad foreign matter (sand ,rust )has gotten through filter screen and settled in fill valve not allowing it to shut off completely..(hope i get this right) to acess remove screws on rear of console and lift console forward and up valve mounts underneath console may need to lift top up to acess lower fill hose connection ..remove plug on front corners of top remove phillips screw underneath top lifts up and tilts back
Posted on Jun 28, 2008
We have a brand new rheem 40 gal elec water heater, after installation we have water leaking from the base of the relief valve, pooling up in the plastic fitting and making it way over the side all over...
Water heater should be set in a drip pan.
Otherwise, put 1 gallon bucket under TP release pipe to catch water.
http://waterheatertimer.org/Water-at-bottom-of-water-heater.html#drip-pan
When you say relief valve, I assum you are talking about brass valve located on top of tank or near top of tank. This is TP valve and a pipe connects to this valve and runs down to within 6" of bottom of tank. TP valve has a small lever on it.
If you are talking about tank drain valve located at bottom of tank, then add a comment.
Following information is for TP valve.
Dripping TP valve can be caused by 3 different thing:
1) Obstruction inside TP valve. Open TP valve for a moment to flush away particles and slowly lower lever back down. See if water stops dripping, if not, then replace TP valve
2) Defective TP valve: replace TP valve. Turn off electricity to water heater. Let heater cool for several hours so you do not get scalded. Close shut off valve located above tank on cold side. Open tub spout to relieve pressure, open tank drain or open TP valve and empty water below TP valve level. If TP is located on top of tank, not much water has to be drained. Tank is under press when hot, so be careful. Put teflon tape on new valve and install with big pipe wrench by turning clockwise until TP valve is very tight.
3) Overheating tank. TP valve is temperature-pressure valve. If tank water is over 150 degrees, the TP valve starts drizzling hot water to relieve tank pressure.
Lower tank pressure two different ways:
a) turn down thermostat
http://waterheatertimer.org/How-to-adjust-water-heater-temperature.html
b) install expansion tank on incoming cold water line
http://waterheatertimer.org/Water-at-bottom-of-water-heater.html#expansion-tank
Dec 19, 2010 | Rheem Water Heater Pressure Relief Valve
Cold Water extremely slow to fill. Had same problem with hot water some time ago and I have turned hot water off at tap and always choose cold water. Now I have turned hot water tap back on and use warm...
sounds like both valves r faulty .try cleaning inlet hose filters and if that doest work must b valves. buy and change cold first to save u money,if u dont use warm often.please reply 4 more help.p/s turn off power b4 working on unit dont want any acciedents.
Apr 08, 2010 | Fisher and Paykel (IWL12)
No cold water from bathroom tap
Sounds like you need to replace your shower valve, especially if this is the only fixture in the house being affected. You could try to replace the cold water cartridge first. Hope this helps
Jul 06, 2009 | American Terminal Etc B 100 T Taps
Fisher & Paykel Washine Machine is filling up hot and not cold?
As nice as these machines are, I've read bad things about Fisher & Paykel reliability. It sounds to me like you have a bad solenoid.
FYI, you should leave the water lines on (both hot and cold) all the time, no need to shut them off unless you're unhooking the machine to move it or work on it. The machine should control the temperature itself.
Jun 14, 2009 | Fisher and Paykel (IWL12)
Ge washer
Dear friend,
ngfam at you service!
You can not fix this problem your self!!!
This sounds like it will only fixed by service then you will be happy again!!
Yes sounds like you need service!
Call A&E Factory Service /They service nation wide
And are available 24/7 for making appointments!
If the appliance is 10 years old or more,it may make sense not to invest any money to fix it!
Happy to assist you,
PS. PLEASE GIVE ME A GOOD RATING BEFORE YOU SIGN OFF!
Aug 26, 2008 | Whirlpool GST9679P Top Load Washer
Fridge
Clean the door seal and ensure that there are no gaps between the sealing surfaces of the door seal and the refrigerator, if there is, relatively warm moist air will continually feed condensible moisture to the cold gap in the seal and the condensed water will drip on the floor. If the door seal its self is broken or torn it will have to be replaced to stop the drip.
Hope this helps.
Mar 16, 2008 | Refrigerators
Kenmore wash macine
its in your cold water line valve to the washer if it works good with hot water the valve are incoming line being blocked when you turn it on the pressure comes in fast then when pressure is gone water slows down so when its off the pressure builds back up it runs fast then slow
Feb 27, 2008 | Washing Machines
F&P Smart drive 9
I had the same problem.
You probably only have cold water connected and you need to "program" it for cold water only.
By default it expects both cold and hot water connected and even though you can select "cold" it will still error if not hot water supply is present.
Call Fisher & Paykel customer care and they will tell you how to re-code it for cold only.
Oct 05, 2007 | Fisher and Paykel (IWL12)
Fisher and Paykel IWL12 Top Load Washer Logo
147 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
