Question about Kenmore Washing Machines
Changed belt now pump wont work - Kenmore Washing Machines
    Genius:
  • 1,028 Answers
Be sure belt is around pump pulley properly ..also be sure pump lever is in notch on cam bar ..
Posted on Jun 28, 2008
I'm attempting to do a timing belt change on my 2004 Chevy Aveo. The problem is when I took off the old timing belt I forgot to loosen the tension using the water pump. When I tried to install the new...
Yes,there is a special wrench that fits the water pump. You have to loosen bolts on pump and put wrench on pump and turn pump to get belt on. Then tighten pump till marks line up on tensioner,then tighten the pump back down. Be sure to roll the engine around twice and recheck timing marks on crank and cams.
Mar 12, 2015 | 2004 Chevrolet Aveo
2002 Honda Civic ex wont start
After so many over heats.a car sometimes cant handle.
after constant over heating your cars rubber gaskets could have gone bad and turned brittle letting in oil into spark plug well #1
for your spark plug problem i would recommend changing your valve cover gaskets.
and for the over heating and not turning on.
i believe you blew a head gasket.
Feb 07, 2013 | 2002 Honda Civic
Fuel pump wont kick on
relay? all drive belts on motor?
Oct 05, 2012 | 1998 GMC Sierra
When do I replace the timing belt and water pump on a pontiac 2008 G6?
The timing belt last for a while. Probabbly change between 100,000-120,000. The water pump dont need changed until it is broke. When so, your heat wont work or your car will overheat.
Feb 16, 2011 | 2008 Pontiac G6 Sedan
If my water pump needs to be replaced will there be other changes I may need to do?
in most cars the water pump is outside the engine and is driven by the serpentine belt (that also drive the generator and air conditoner) ... so its a good idea to change that belt since it involves no increase in labor (they may charge for it but it takes no more effort to install a new belt then the old) ... also inspection of the belt tensioner and idler pully is a more than a good idea .. they may have frozen pivots or bad bearings that will cause later failures ...if they are in good shape then no need to change them unless they are available at a reasonable cost .. most off the shelf antifreeze contains silicates and thats responsible for most water pump failures .. silicate free antifreeze is available but at a higher cost .. thats money well spent... some cars have the water pump driven by the timing belt inside the timing belt housing .. now that can involve much more labor .. its prudent to change the timing belt and any warn idler or tensioner pullies while you are at it ... timing belt driven water pump repairs are expensive but those extra parts wont add a lot to the bill but will increase long term reliability greatly ... on a few cars the whole front end must be removed in order to change the water pump or even thermostat .. thats additonal labor ... hope you dont have one of those ..
Jun 30, 2010 | Cars & Trucks
How hard is it to change water pump and timing belt
its a pain. not really any room to work and if you get one of the pulleys off by one tooth it wont run right. its completely do-able though depending on your mechanical ability. my eclipse required a special tool to loosen the tension pulley on the timing belt but we found a way to get around it.
Jun 27, 2009 | 2000 Plymouth Neon
I need directions to change my water pump
drain engine coolant.relieve belt tension .and remove the drive belt.remove upper fan shroud.remove fan or fan and clutch assembly.remove water pump pulley and coolant hoses from water pump.remove water pump bolts.then remove pump from engine.pay attention to bolts location because they are different lenghts.clean water pump gasket mounting surface dont scratch .or pump gasket wont seal and leak .apply sealant to water pump bolts.install water pump with new gasket.if gasket paper put a sealant on it.torque water pump bolts to 30 ft lbs.if you got a 2.2L engine torque water pump bolts to 18 ft lbs.install coolant hoses on pump .install water pump pulley.install fan and fan clutch assembly.install the drive belt .and the upper fan shroud.fill the radiator with coolant.then run engine to check for leaks.WARNING AS A SAFETY PRECAUTION REMOVE NEGATIVE BATTERY CABLE SO CAR WONT BE CRANK BY ACCIDENT. ALSOOOO DONT FORGET TO TURN OFF RADIO FIRST BEFORE DISCONNECTING BATTERY SO YOU WONT LOSE YOUR RADIO CODE.
Jun 01, 2009 | 1999 GMC Jimmy
Changed timing belt 94 civic ex 1.6, now wont start
first make shure the fireing order is correct 1 3 4 2, make shure you have the timeing set right
Apr 02, 2009 | 1994 Honda Civic
Washing Machines Logo
37 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
