Question about Refrigerators
Frost on upper dr and ceiling frigidare frost free upright freezer already installed door insulation kit & sealed heat exchanger entry into cabinet and drain line has trap
  • 828 Answers
Check the door gasket for seal by closing the door on a dollar bill or some other stiff thin paper. As you slide it around the door it should have resistance.
Posted on Jun 28, 2008
Model EEV-163F Whirlpool Upright Freezer. Defrosted this week, already seeing ice buildup. Freezer is cold and appears to run fine, but frost buildup seems excessive this quickly. Frost throughout
This freezer is not frost free. Being an upright limiting the amount and frequency of opening the door will reduce the build up of ice. Ice is expected and depending on humidity and quality of seal around door affects the amount of ice.
Using a thin ribbon check the seal integrity around the door. Confirm nothing is prohibiting the full closure of the door.
Adjust door if necessary. Replace seal if defective. Freeze open unsealed items in a frost free freezer before locating frozen food in this unit.
These units are likely located in the garage where the humidity is high. If used only as needed planning transfer between this and the kitchen unit frost can be minimized.
Being a conventional freezer not frost free freezer burn is less likely and frozen food will not dry out as quickly. Confirm that the freezer maintains about 0 degree F.
This unit is likely more efficient and will maintain the food frozen longer in the event of power outage.
Hope this helps?
Jun 24, 2017 | Whirlpool Refrigerators
Frigidaire upright freezer door will not seal
Hi Chris, this is AP! Thank you for your post.
I understand you are having trouble with the door sealing on your upright freezer. Many times this can be caused by the freezer not being leveled. If the freezer is not leveled during installation, the door may be misaligned and not close or seal properly, causing cooling, frost, or moisture problems. To level your upright freezer use a carpenter's level to level the freezer from front-to-back. Adjust the plastic leveling feet in front, 1/2 bubble higher, so that the door closes easily when left halfway open. I hope this information has been helpful.
Mar 02, 2014 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Upright freezer, non-frost free. We are having to defrost it frequently as in monthly. We used to do it once a year if needed. Frosts up quickly, especially on ceiling with snowflakes falling from...
. More than likely you have a bad freezer door seal gasket . If the freezer door does not completely seal when closed , the outside (humid) air enters the inner compartment. As the air is cooled , the water molecules freeze and form the frost you are experiencing . Only one of two things can be wrong . It is either the seal itself , or the door is warped due to excessive force or bad door hinges keeping it from closing properly . There is one more possibility but only if the door has a mechanical latch . If this is the case , the latch might need to be adjusted or replaced .
Feb 18, 2011 | Refrigerators
Freezer not cold enough
TRY PUTTING A DOLLAR BILL BETWEEN DOOR SEAL,IF ABLE TO PULL OUT YOU HAVE A BAD SEAL,TRY TOP,SIDE,BOTTOM,IF SEAL IS OK TRY CLEANING CONDENSOR WITH BROOM OR VACUMN HEAT ATTRACTS LINT,DUST WHICH RESTRICTS PROPER AIRFLOW.GOOD LUCK
Sep 28, 2010 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Frigidare Model No. FFU1464DW2 is leaking water on ground floor, can you tell me where to find the drain pan and what is causing this? Many thanks.
Most likely it is leaking because the drain in the back of the freezer is clogged. The most likely source of excessive water drainage is a bad door seal which causes frost to build up.
Nov 19, 2009 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Frost free freezer with ice in the bottom and water dipping off bottom door hinge
Frost Free Freezer have an automatic defrost, which is essentially a heating element which melts any ice. If your door seals are in poor condition or something is preventing the door from sealing the ambient air may be melting the ice more than the drain can accommodate. Check the drain in the bottom of the freezer. Humidity can also cause more water to accumulate, especially if the door seals are not sealing.
Jul 10, 2009 | Kenmore 20.3 cu. ft. / 575 liter Upright...
Frost free freezer is frosting up
Your door seal is not sealing properly . Check and use a hairdryer to soften the seal and the magnetic portion should seal itself against the cabinet .
Jul 07, 2009 | Nor-Lake Freezer Norlake Refrigeration 6'...
Frost in Kenmore frost free
Although you say the seal is fine, this is almost certainly due to air getting in. With the door closed check that there isn't a tiny gap with a strip of thin card or plastic. Of course if air is getting in then it must also be getting out somewhere else so probe all around the seal.
Oct 01, 2007 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Refrigerators Logo
140 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
