Question about Microsoft Windows Vista Ultimate Edition
Error 1721 Trying to install a VPN that is made specifically for Vista (and works on one of my other computers running Vista) but I get the error 1721 message. I've already run the msiexec/unregister and regserver commands. What next? Chilly
  • mohammed shaik Aug 15, 2008
    hi ,
    I am trying to vpn client 5.0 version, in 64 bit windows vista machine...I was getting 1721 error ..can any one please help me out
    Novelist:
    Scholar:
  • 160 Answers
This page applys to XP,
http://support.microsoft.com/kb/891985
but the solution should be similar. If you've done the registering, the next suspect would be something corrupt in your VPN package.
Try a fresh download or copy of it, and be sure you run as administrator during the install.
Posted on Jul 18, 2008
Hi, when i try to install cisco vpn on my xp machine, it is throwing 1721 error.
Cisco VPN Client for Windows Vista, release 5.0.0.340, does not support the following:
blank.gifMicrosoft Windows NT, 98, and ME.
blank.gifSystem upgraded from Windows XP or earlier Windows operating systems to Vista. (Clean OS installation required.)
blank.gifCombination of Cisco Unified Video Advantage 2.1.2 and McAfee HIPS Patch 4 Build 688. To avoid system failures, uninstall either of these two applications, upgrade McAfee to the latest version, or use VPN Client 4.6.x.
blank.gifStart Before Logon.
blank.gifSmartCard authentication.
blank.gifIntegrated firewall
blank.gifInstallShield.
blank.gifAuto Update.
blank.gifTranslated Online Help. Online Help is provided only in English.
blank.gif64-bit Windows operating systems. For x-64 support, customers should explore with their Cisco sales representative the use of the next-generation Cisco AnyConnect VPN Client.
Nov 04, 2010 | Microsoft Windows XP Professional
I'm trying to install the Cisco VPN client to a Windows 7 (32bit) computer but keep getting a Windows Installer 1721 error. Any advice is much appreciated.
Dear User ,
Follow the Steps below to resolve your problem
1. Click on start and the search bar right next to it , type Cmd 2.As the CMD appears in the search list . Right click on that and Click on Run As Administrator
  1. At the command prompt, type msiexec /unregister , and then press ENTER.
  2. At the command prompt, type msiexec /regserver, and then press ENTER.
  3. At the command prompt, type exit, and then press ENTER to close the command prompt
Try to install it again ,Just in case it fails ,follow the steps below 1.Right click on the VPN setup file and click on Run as admin
Good luck
Thanks and regards Aboobacker S
Sep 28, 2010 | Computers & Internet
Am getting 1721 errors on my computer, can you tell me how i can fix it ?
Here you go. This is long winded but should fix you up.
Error 1721 is a common problem for many different Windows systems, shown when the installation you're trying to perform develops a problem and needs to be fixed. If you have this error, it's recommended that you're able to first fix any problems that could be inside your Windows system, and then cure the specific issues that the Windows Installer program has on your PC. This tutorial is going to show you exactly how to do that...
This error will typically show like this:
  • Error 1721. There is a problem with this Windows Installer package. A program required for this install to complete could not be run. Contact your support personal or package vendor.
The problem with this error is actually caused by a very simple issue - the Windows Installer program that is used to install the various files & software onto your PC is actually damaged or corrupted & preventing your system from installing the program you want. This can be caused by a number of problems, including everything from having corrupt registry settings to the Installer program on your system being damaged. To fix this, you first need to make sure that Windows Installer is okay, and then get rid of any further system errors on your computer.
The first step to resolving this error is to "register" and "unregister" the Windows Installer on your system. This is a program which installs all the programs that you want onto your PC, and is constant on every Windows installation. The problem that often causes error 1721 is the way in which Windows often cannot read the Windows Installer program, because it's not "registered". Registering a program basically tells Windows where to look for it on your system, and it's often the case that this stored reference is either damaged or deleted by accident. To ensure this is not a problem, you need to be able to type the following into your system:
  • Load up "CMD" (click "Start" > Run > type cmd)
  • Type msiexec u/unregister
  • Type msiexec /register
  • Try reinstaling the program you wanted to
If you try this and find it does not work, then it's recommended you then use a program by Microsoft called the "Windows Installer Cleanup Utility". This is a new program which basically cleans up all the settings and options associated with the Windows Installer program; meaning that if you have any problems with the Windows Installer on your PC, they should be fixed. You may also wish to install Windows Installer 4.5, which will basically upgrade the Windows Installer program on your system, which should resolve many cases of the 1721 error.
It's also highly recommended that you use a "registry cleaner" to fix any of the errors that are on your Windows system. A registry cleaner is a type of software tool that basically scans through the registry database of your PC and fixes any of the problems that are inside it. The registry database contains all the settings, files and options for Windows, and is where everything from your most recent emails to your desktop wallpaper are kept. It's basically like a library for your system which is continually being used to help your software run correctly. Unfortunately, the registry is continually being damaged & corrupted, leading it to become highly ineffective and erroneous. To ensure this problem is not causing the 1721 error, you should clean through your system with a registry cleaner tool.
Sep 11, 2010 | Dell Computers & Internet
I have an Aspire 5050, I have bought a Kodak All in one printer. When I try to install it it gives me error code 1721. I was on the phone for 4 1/2 hours with Kodak and they advised that it is something...
Error 1721. There is a problem with this Windows Installer package. A program required for this install to complete could not be run. Contact your support or package vendor.
Sep 03, 2010 | Acer Aspire 5050-3242 Notebook
I am trying to get into my work computor and I am using pcanywhere with vpn client--when i try to connect thru VPN client I get the error message '' unable to contact security gateway'' what do I need to...
If you are duly authorised to remotely logon to your work computer, you will need to contact yourwork Network and Security administrator to get them to remove the corporate Network protections and firewalls for your specific device: you should not try to 'get around' this protection ...
Jan 01, 2010 | Computers & Internet
Cisco VPN Client for 32 bit vista
Download the latest version of the Cisco VPN Client. My version is 5.0.03.0530.
You can also try using the Microsoft "MSIZap" utility to ensure a clean uninstall. It is a command-line utility. You will need the original MSI install file from the Cisco VPN client to use MSIZap.
You can download it here: http://msdn.microsoft.com/en-us/library/aa370523.aspx
Sep 22, 2008 | Microsoft Windows Vista Ultimate Edition
Error 1721
What Is Error 1721? This is an error commonly witnessed when you try to uninstall a program using the "Add or Remove Programs" in Microsoft Windows XP. The message itself will read: "Error 1721. There is a problem with this Windows Installer package. A program required for this install to complete could not be run. Contact your support personal or package vendor."
Resolution #1: Reregistering the Windows Installer service It is known that if the Microsoft installation engine malfunctions or is internally corrupted, there is a possibly that you will not be able to remove programs that you used the Windows Installer, the service that administers the installation and configuration of programs, to install with. Thus, in the case of error 1721, it is necessary to unregister and then reregister the Windows Installer service to fix the corrupted parts of the engine. This can be accomplished through the Safe Mode by:
  1. Enter your computer in Safe Mode by:
    • Restarting the computer and pressing F8 after the BIOS information is shown
    • Select Safe Mode and Enter
    • Select your computer and Enter
  2. Log on as the local administrator
  3. Open up the command prompt by clicking Start, Run, and then typing cmd.exe and Ok
  4. At the command prompt, first unregister the service by typing msiexec /unregister and then hitting Enter
  5. Reregister the service by typing msiexec /regserver and then hitting Enter
  6. Type Exit to exit the command prompt safely
  7. Try to remove the program once again using Add or Remove Programs
I hope this helps you out. Thanks
Sep 04, 2008 | HP Pavilion dv6000z Notebook
Error 1721
Okay, lets begin. First off you were trying to install .msi packages? Second how new is the computer? Third how much stuff do you have on the computer? Finally forth Have you had any spyware/ viruses? I need this information to continue troubleshooting.
RCF
Aug 31, 2008 | Microsoft Windows XP Professional With...
Error 1721
Try the following regardless of the software as this is the common error message provided by Microsoft. Of course this won't rule out either a corrupt installer or incompatibility's
  1. Disable/Configure any anti-spyware or anti-virus software on your system during installation process. For example: Spybot Search and Destroy Program or Norton Anti-Virus
  2. Check to see if any spyware or adware is installed on your system blocking the completion of install process.
  3. Check to see if you find any unwanted entry in Add/Remove Programs or Internet Explorer - Add/On's section (Tools - Internet Options - Programs -> Manage Add On's). If you found one, remove/disable this entry.
  4. On Windows Vista, disable UAC (User Access Control) feature for your account
Aug 27, 2008 | Microsoft Windows Vista Ultimate Edition
Microsoft Windows Vista Ultimate Edition Logo
1,113 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
