Replacing ballast board
Hi! My VPL-CS4 powers on intermittently - every 2-3 weeks. In researching the solution I read your answer to the problem "LED won't come on and only faint hum is heard". How does one replace the ballast board? Got any suggestions?
I want a ballast board part number 913700808905 EUC120P/H11 where can i get one its for a samsung dlp tv
Posted on Jul 28, 2009
  • 682 Answers
Ballast board is difficult to obtain better ask good service center for help.
Posted on Jul 08, 2008
Green light is continuesly bling but the projector is not given the display
1,Check the fans ,whether each fan is running,when you turn on the projector
2,if the fans run, then ,check the lamp or lamp ballast
Have a nice day!
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
Jerry
Lampdeng Limited
Dec 11, 2014 | Sony VPL-BW5, VPL-ES5, VPL-EW5, VPL-EX5,...
No power on light
That's interesting.. After researching that model I can tell you that it has an intergrated internal power supply(transformer) which does contain a fuse. It is located where your power cord plugs into, inside the unit, start with that. Was it plugged into a surge protector? When you had the power failure the second time was there a fluctuation of power, ie your lights in your house flickering on or off or increasing, decreasing in brightness? This will help me determine if it's something else. Also be sure to check your power cord, look for any kinks, breaks, chips in insulation. Anyway Good Luck
Sep 29, 2007 | Sony VPL CS4 Multimedia Projector
I replace one new lamp C121 but no power in my projecteur lamp
the thermal fuse 1-900-222-47 could be the issue see service manual
Jul 23, 2012 | Sony VPL CS4 Multimedia Projector
VPL-HS50 shuts down after few seconds
It must be a problem with electric connection. you should check whether it is OK or not. If it is okay, read instruction manual.
Jun 27, 2012 | Sony VPL-HS50 LCD Projector
My sony projector vlp-cs4 is no power on... Please how to do?
hi,
check the power cable first. also check the power at the wall out let. if all ok, the ur projectors smps power supply have some problem. check the same if found faulty replace it. for any assistance feel free to contact through fixya.
ok
Dec 26, 2010 | Sony VPL CS4 Multimedia Projector
Hi I have a problem with my Sony VPL-CS4 LCD Projector. The problem is, when turning on AC the LED's: LAMP/COVER and TEMP/FAN turns on blinking, and consulting the torubleshooting section of the manual, it...
Attend to the issues. Lamp cover may mean the cover is not fitted correctly or the switch is faulty like wise the fan issue may mean no rotation so it will not start.
Nov 06, 2017 | Sony VPL CS4 Multimedia Projector
JVC DLP MOD#HD55G466 what is the voltage from power supply to ballast and into the lamp.I have no voltage to the lamp could it be ballast?
Ballast board gets voltage from power supply connector CN90BL and volts readings are as follows:
Pin-1 = 380V DC
Pin-2 = Ground
Pin-3 = 15V DC
and output of ballast board would be 12,000 volts AC that goes to lamp to generate spark in its electrodes to produce high bright light.
If you get volts on input of ballast board but still lamp does not fire up then ballast board is not working.
Ballast board part number is QAL0765-001 and available with tv-part.com for $125
Hope these info will help you.
Thanks.
Nov 16, 2010 | Televison & Video
The tv picture goes out
Sounds like the ballast has gone out. Samsung recommends replacing the smps board(power supply board) when you replace the ballast because it is the smps that takes out the ballast. replacing just the ballast ,machine may work ok for a short time but will destroy the new ballast fairly quickly.
Dec 30, 2009 | Samsung HLP4663W 46" Rear Projection HDTV
It won't turn on. The TV has been intermitant for a about a week.
Hi.
Try first leaving the TV disconnected from power for several hours. Also test on a different main, eventually using an extension.
If the problems started intermittently last week, then there is probably a fault.
If there is no power at all it is a faulty power supply.
If the TV instead is in standby, then the set must be tested to find the fault.
Common faults may concern convergence, PSU, ballast board, control and signal I/O.
Here all parts for your set.
Oct 13, 2009 | RCA G27669 27" TV
1,904 people viewed this question
jasbo
jasbo
