Question about Samsung CLP-500 Laser Printer
Samsung CLP-500 stopped printing in color. It won't print with half full cartriges that were working fine before, and not even with newly refilled cartrigdes. A test page is black and white only
  • keboard tric Jun 28, 2008
    Printer worked fine for several years, then stopped printing color. cartriges are newly refurbished. Error message is" replace balck toner" but black toner is fine and prints ok.
    printer set up preferences are still "color", etc.
    That does not work. Error signal is now "replace Black Toner" which I responded with by refilling the cartridge, replacing it and it still says to replace and the status is still listed as 0% full. The diagnostic demo sheet check still prints only in black and white - which strikes me strange as it insists that black is empty.
  • Samsung Master
  • 6,487 Answers
Try this one:
If the printer gives you an error message after you have installed the chip like “incorrect toner” or “invalid toner” or any other error message, then you need to SWITCH OFF the printer, wait a few seconds, then switch it back ON and hold down the MENU button while you are powering it back on.
If your printer will only allow you to print in black only mode, then go to your printer settings, click on PROPERTIES and then restore to printer defaults.
Hope that helps........
Posted on Jun 28, 2008
  • jackiemp17 Mar 17, 2011
    thank you thank you thank you!
    Genius:
  • 1,011 Answers
Sir,
The cartridge needs a chip, or to be remanufactured. Since it was "refilled", you can get it working again by putting a chip in it. Once the chip is replaced, that reading will go to 100%.
The toner on this machine has to have the chip/fuse replaced to reset the count.Ask your retailer about the chip.
Thanks
Good Luck
"Don't forget to rate the Solution"
    Master:
  • 497 Answers
Have u tried updating ur driver
    President:
  • 2,712 Answers
Seems to be an issue with the logic card, in that the info is not being sent/read by the colour mechanism (provided all printer settings are correct). If a hard reset as outlined by marked does not work, try a clean boot (with latest drivers from manufacturer's website) as outlined in my articles here:
For XP:
http://www.fixya.com/support/r545614-installation_problems_clean_boot_install
For Vista:
http://www.fixya.com/support/r643558-clean_boot_in_vista
If all this fails, I would recommend you get in touch with with an authorized service center to get this issue sorted out...
    President:
  • 1,257 Answers
If everything is ok with your cartridges then it might be settings problem.try uninstalling the printer software through add/remove in control panel and then remove drivers from device manager ,now restart your system and then install drivers and software for your printer again from the cd..
    Brigadier General:
  • 3,614 Answers
Color problems stem from your print cartridge or from your printer settings. Obviously, as a cartridge runs out of ink, colors will fade or disappear. Nozzles can also clog. Most printers include software utilities (including one for cleaning nozzles) that let you clean and align cartridges and print heads. You can usually access these utilities from an Advanced or manufacturer-specific tab in the printer’s Properties dialog box. Run both utilities several times if necessary.
If you’re sure the cartridge isn’t to blame, make sure you have updated drivers and the correct paper type for your job. Next, check the print quality and paper type settings in your printer Properties dialog box and in your application’s print settings. Printing Draft quality jobs can often result in strange color output. Your printer’s configuration utilities may also have color management controls. Find them either as part of your printer’s Properties dialog box (click the Color or Advanced tabs) or in a separate application installed as part of the printer setup process. Use these to adjust Tone, Brightness, Levels, and other settings.
  • micromaster
    micromaster Jun 28, 2008
    necessary.
My Samsung CLP 315w refuses to print a whole A4 page. Stops half way then message comes up paper jam but when I open back / front, paper not jammed and when I close it document continues printing then...
most likly hood is your exit sensor is faulty. The printer work in this way. if it does not print out all the document. it will print again. that is why you kept getting this same issue after a jam open and close door it will print again.
replace the exit sensor it will help.
Apr 16, 2010 | Samsung CLP-315W Laser Color Printer
Samsung CLP-315W Color Laser Printer will print only half page
http://www.fixya.com/support/t3934542-exit_sensor_problem_samsung_clp_315
Mar 23, 2010 | Samsung CLP-315W Laser Color Printer
Just had my color cartridge refilled, and reinstalled correctly. However, the printer will not print with the color cartridge in, but will print with the black cartridge only.
your newly installed cartrige which is the colored one is not detected or mybe damage....may i ask if how many times did you refill already your cartrige?refilling a cartrige can cause damage to its circuit i suggest purchase a new colored cartrige and see if it works.
Oct 09, 2009 | HP DeskJet 845c Printer
I HAVE A SAMSUNG CLP 300 and I've replaced the black ink with a factory refill and a competitive refill. both cartriges make the black indicator light come on.This problem is only with the black Byron
It is not possible refill because this cartridge have image sensor or ic it is not able to print change your black cartridge and buy new one then solve your problem
Jul 20, 2009 | Samsung CLP 300 Laser Printer
I have to CLP-300n printers, Not even a year old
Black development roller has worned out,need to replace.roller is inside drum.common problem.
Jul 03, 2009 | Samsung CLP-300N Laser Printer
Will not print color
So it worked until you replaced the cartridges with refills? Defective. Take them back
Jun 21, 2009 | Samsung CLP 315 Laser Printer
Printer will not print
if you refiller the tone cartriges yourself or by someone else then mabye the chips need to be reset. An easier way is to tape over the three copper pins on the right side then turn the printer off and when turning on hold the menu key until it says uncheck consumables mode. Unfortunatly in this mode you will not know when you are out of toner until it doesn't print right but it can get you thru in a pinch.
Feb 14, 2009 | Samsung CLP-510 Laser Printer
Colour Printing on a Samsung clp 500
Try unplugging printer from the power and connecting it back.
Try also extracting all toners and putting toners back.
Oct 30, 2008 | Samsung CLP-500 Laser Printer
Clp 300 paper jam
i had the same probelm with my printer, i found that you need to clean the roller at back of the printer and i have had no problems after that.
i always use refilled toner it works well for me but other might not like it depends on the size of your wallet!
Jun 24, 2008 | Samsung CLP 300 Laser Printer
Samsung clp-510n printer
1 Could be toner on the contacts (inside the printer) that mate with the contacts on the cartrdige.
2 Are you sure they are 510 toners and not 500 ones ?? 510 toners have a chip that identifies the cartridge (Colour, Capacity) and maintains a count of the pages printed.
500 toners have a reset fuse that resets the toner counter in the printer, and a resitor that identifies the capacity
3 Are they new cartridges, remanufactured, or 'home refiled'.
if either of the later two, were the chips replaced ? - if not the cartridge still thinks it has printed its full life of pages.
Nov 28, 2007 | Samsung CLP-510 Laser Printer
Samsung CLP-500 Laser Printer Logo
260 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
