Question about Kenmore Elite 22.4 cu. ft. Bottom Freezer Refrigerator with Adjusta Cube Ice Maker
I have a Kenmore model 106 9555710 SxS - no wate through door
My kenmore has stopped dispencing water from the door. The ice maker still works. For a while the first time you used the water it would take a few seconds to start dispencing. However, now it never starts. I hear the click of the switch when the lever is pressed and you can hear a low hum while the lever is pressed.
  • 481 Answers
Check inside the bottom of the refrigerator for water, the water line goes thru the back of the refrigerator and it may have cracked and leaking inside instead of going to the dispenser.
if not then water is most likely frozen in the line going thru the back of the refrigerator. look behind the pans in the refrigerator and there should be a coil of clear plastic water line, this is the reservoir that chills the water for the dispenser. sometimes it will freeze up if the refrigerator is very cold.
Posted on Jun 28, 2008
Kenmore Coldspot model#106.53359300 the ice maker not making/dispencing any ice, help?
Make sure the metal lever on the ice maker is in the lower on position. Check that the water valve for the 1/4 inch supply line is attached to the fridge and to the valve . Screw that water valve all the way in and then all the way out.
Jun 06, 2016 | Kenmore Refrigerators
Our ice maker leaks water and forms mini iceburgs inside our frezer. It appear to a water leak leading to the ice maker. What part should we replace to fix this problem. It is a Kenmore SxS 26' SS...
Your water valve probably has a drip like a bad water faucet.The water valve is cheapest and your only 2 parts options are the ice maker AND the water valve.
Sep 08, 2011 | Kenmore 57703 Stainless Steel
I have a kenmore side by side refigator and with built in ice and water in front door. The water does not fill ice maker or dispence out the door. The water stoped first at door then about one year later...
you might need to open the water pip and clean the volve on the bottom of your fridg. its get clug some time but if its not working then your valve need to be replace..get me your model # i get you the part#...
911servicetoday . com
Jan 01, 2010 | Kenmore 21.7 cu. ft. Side-by-Side...
Kenmore 56541 side by side icemaker nor making ice The in door water dispencer works Arm on tray is on no water getting to tray
1.Bad water valve located in the back bottom of refrigerator.
2. Frozen fill tube going into back of ice maker. (common problem)
3. Ice maker not cycling. Pour water into ice maker cavity until near filled.
Wait a few hours and see if it dumps.
4.In rare cases, the switch in the ice maker body fails. Ice maker will cycle but not tell water valve to refill.
Oct 24, 2009 | Kenmore Refrigerators
Kenmore by Whirlpool sxs water in the door. Ice maker 106.565424
The water control valve for the ice maker side is your most likely reason. If filling ice maker with tap water and allowing to freeze. If it dumps then the water control should fill. if not the valve is not working. Sea Breeze
Oct 16, 2009 | Kenmore 57029 Side by Side Refrigerator
Kenmore Galaxy Ice Maker Not Making Ice
Sounds like you have a bad water valve. It will have a dual water valve on the back where the water connects to the unit. You can take the wire plugs and swap them around. Then push the water in the door leaver. hold it for around 4 sec. Then see if the ice tray has water in it. If it does, you have a bad valve. If not you ice make is bad, turned off or the freezer is not cold enough to operate. ( It has to be 5degrees or lower before the ice maker will try to operate)
Please rate this solution if it helps. Thanks
Aug 19, 2009 | Kenmore 57029 Side by Side Refrigerator
Kenmore side by side water dispenser has stopped
Most likely need to replace the water inlet valve. The water supply line should be directly connected to it. There are 2 valves bracketed together, 1 for the ice maker and 1 for the water dispencer. You will probably have to buy both valves, but want to do this anyway as the second valve will fail soon. Hope this helps.
Jun 14, 2009 | Refrigerators
ICE MAKER NOT GETTING WATER AND ICE IS NOT DISPENCING EVEN IF WE
first check if you have frost build up in freezer 2 could be ice maker 3 water valve
Apr 05, 2009 | Kenmore 57029 Side by Side Refrigerator
Ice maker
I have kenmore two door fridge. My icemaker is not working but the water dispenser is. Model#DU800DWGQ1 Serial#FJ1814737
May 14, 2008 | Refrigerators
Kenmore Elite 22.4 cu. ft. Bottom Freezer Refrigerator with Adjusta Cube Ice Maker Logo
201 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
Arnel
Arnel
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
