Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
Openers I am trying to program a new keyless and it does not seem to accept. I have managed to blank out all the other remotes and none of them seem to want to reprogram??? Thanks Michael
    Champion:
  • 244 Answers
Did you buy right keypad? To get remotes working, hit LEARN or SMART for 1 second and push remote button. Light should flash. Repeat for each remote orkeypad (If you have the right one).
Posted on Dec 29, 2009
How do i program the door opener feature?
Not all car systems can communicate with all door openers. But the proceedure it an invite has to come from the head unit. Usually the directions are on the unit, get a ladder, a light and assistant. Best to have all remotes handy.
So some head opener units have two buttons, some have one that gets pushed for different time durations, to access different functions...Long press usually wipes all codes. Short duration invites remotes, one at a time.
So, the car thing, I suggest getting the opener to re accept an existing remote, so that you know and can see the lights flash, etc as it accepts the remote, then the remote functioning the door...
Do the head unit accept and have assistant do the car one...if no function you should know that you had done everything correctly..
Also include keyless entry pads, if you cleared all and reaccept remotes, the keyless are essentially a remote.
Oct 18, 2010 | 1997 Lincoln Continental
My garage door sytem was working fine. I lost a remote, so after getting a new one, I programmed it into the door opener. After that, i found the remote I programmed worked, but my wife's remote did not....
Ted, it sounds like normal garage door function. Here is my take, you were pushing the button in a fashion that was to clear all remotes. This is done through either pushing wrong button, or pressing the programming button for too long.
Sometimes you need an assistant to be able to activate the wireless key, soon enough after pressing programming button. Get a ladder and a light, climb up and read the directions carefully on your opener. Try to add just the keyless system.
If that does not work,Get an assistant, and do the whole process again, including the keyless.
There are two distinct processes, adding and clearing, and it may be easy to invoke the wrong one.
Your system uses rolling code/invite system. Rolling code relates to a handshake betewen each remote and the base. The code is changed at each use, for each remote. (the keyless /wireless also).
Been there, done this. all for an additional second or two of button press.
Oct 16, 2010 | Sears Craftsman LiftMaster Chamberlain...
I am not able to use the hand held lock/unlock now. The driver door lock tries to work, but it won't. If I push the lock down manually, it will lock all locks. What could be wrong?
Note:
Entering the programming mode cancels all learned keyless remotes, so none of the
previously programmed remotes will work. You must reprogram all of the keyless
remotes once you are in the programming mode. You must complete each step within 5 seconds of the previous step to keep the
system from exiting the programming mode.
1. Turn ignition switch to ON (II)
2. Press the LOCK or UNOCK button on one of the remotes. (An unprogrammed
remote can be used for this step.)
3. Turn ignition switch to LOCK (0)
4. Repeat steps 1, 2 and 3 two more times using the same keyless remote used
in step 2
5. Turn the ignition switch to ON (II)
6. Press the LOCK or UNLOCK button the same remote. Make sure the power door
locks cycle to confirm you are in programming mode.
7. Press the LOCK or UNLOCK button on each remote you want to program. Make
sure door locks cycle after you push each remote button to confirm system has
accepted the remote.
8. Turn the igniton switch to LOCK (0) to exit programming mode.
9. Test remote(s)
Mar 07, 2010 | 2002 Honda CR-V
1999 lincoln con
SECTION 501-14B: Keyless Entry/Computer Operated Locks 1999 Town Car Workshop Manual GENERAL PROCEDURES Programming —Keyless Entry Keypad Code
  1. Enter the permanent factory keyless entry keypad code.
  1. Press the 1/2 button within five seconds to activate the programming mode. Holding the 1/2 button for more than two seconds will erase all stored customer codes. The existing codes do not need to be erased to program new codes.
  1. Enter the new five-digit keyless entry keypad code.
  1. To associate the new code with personality positions 1, 2 or 3, press the 1/2 button within 5 seconds of entering the 5th digit of the new code for position 1 or 3/4 button for position 2 or 5/6 for position 3. The door locks will lock and unlock confirming the new code is programmed.
  1. If another code is to be programmed, begin entering the code within 5 seconds of the last button pressed.
  1. After all new keyless entry codes are programmed:
    • Press keyless entry keypad buttons 7/8 and 9/0 at the same time to exit the program mode.
    • Wait for 5 seconds; the driver door module (DDM) will exit the program mode automatically.
Programming —Transmitter
  1. Cycle the ignition from OFF to RUN four times within three seconds. The locks will then lock and unlock, confirming program mode has been entered.
  1. NOTE: When the first keyless entry remote transmitter is programmed, all other keyless entry remote transmitters are erased.
    Press any button on the transmitter to be programmed.
  1. If additional keyless entry remote transmitters are to be programmed, repeat step 2 within 7.5 seconds.
  1. To exit program mode, turn the ignition to START or wait 7.5 seconds.
Programming —Remote Memory Activation NOTE: This procedure must be completed within 5 seconds.
  1. Press the SET button on the driver door panel.
  1. Press any button on the keyless entry remote transmitter to be associated with a memory setting.
  1. Press the 1 or 2 memory button on the driver door panel.
Programming —Autolock and Horn Chirp
  1. NOTE: This procedure must be completed within 30 seconds.
    Turn the ignition switch to RUN.
  1. Press the UNLOCK button three times.
  1. Turn the ignition switch to OFF.
  1. Turn the ignition switch to RUN. The doors will lock and unlock to confirm entry into program mode.
  1. Press the UNLOCK button once to toggle the Autolock feature on or off, or twice to toggle the Horn Chirp function on or off. The horn will chirp to confirm toggling of the Autolock feature.
  1. Exit program mode by turning the ignition to OFF, START, or wait 7.5 seconds.
Apr 07, 2009 | 1999 Lincoln Town Car
Alarm goes off when key open the door
Dealer is correct that you have too replace the bcm, so i would tell you to call junk yard and get one. Cheap $ 50.00 put it in by yourself. Right hand side of the glove compartment. behind the fuse box with couple connectors on it, or have some person with knowledge to do it.
Apr 02, 2009 | 2003 Chevrolet Venture Passanger
Reprogramming remote and key
if its early 05 round heart shaped remote it needs programming into system at dealer with Tech2
later 05 to 07 had square (rectangle) shaped remote
1.2 ID Code Additional Registration
Note: This procedure will add additional remotes to the Keyless Entry Control Units memory. A total of 4 remote transmitters may be programmed into the Keyless Entry Control Units memory. When a total of registered and newly registered remotes exceed 4, the oldest one shall be erased.
Step Action
1 Note: Make sure that all the doors are closed and unlocked. Insert the ignition key into the ignition switch.
Open the driver's side door.
2 Turn the Ignition key to the “ON” position and then to the “LOCK” position three times
(The key should remain in the “LOCK” position)
Note: This step must be carried out within five seconds.
3 “CLOSE” and “OPEN” the driver’s doors once (Leaving the driver’s door in the “OPEN” position)
Note: This step must be carried out within five seconds after step 2 is completed.
4 Wait for 8 seconds (This wait time is critical)
5 Turn the Ignition key “ON” and then to the “LOCK” position once and turn key to the “ON” position (The key should remain in the “ON” position)
OR on/lock once
Note: This step must be carried out eight seconds after step 3 is completed.
6 “CLOSE” the driver’s door
The HAZARD lights should flash 3 times (This acknowledges the Keyless Entry Control Unit has entered programming mode)
7 Operate the lock or unlock button of the transmitters to be programmed; a flash of the HAZARD lights indicates the remote has been successfully programmed into the control unit
8 The HAZARD lights will flash approx 4 seconds after pressing the remote button to indicate the Keyless Entry Control Unit has exited programming mode.
Mar 26, 2009 | 2004 Isuzu Rodeo
How to program the keyless entry for my 1996 Acura TL.
Hi, Stacie,
here's the instructions for a 97 TL - I hope they're the same.
Note:
none of the previously programmed remotes will work. You must reprogram
all of the keyless remotes once you are in the programming mode.
You must complete each step within 4 seconds of the previous step to keep
the system from exiting the programming mode. You must program remotes
within 10 seconds of each other
2. Within 4 seconds press the LOCK or UNOCK button on one of the remotes.
(An unprogrammed remote can be used for this step.)
3. Within 4 seconds turn ignition switch to LOCK (0) position
4. Within 4 seconds turn the ignition switch to ON (II)
5. Repeat steps 2, 3 and 4 two more times using the same keyless remote
used in step 2
6. Within 4 seconds press the LOCK or UNLOCK button on the same remote.
Make sure the power door locks cycle to confirm you are in programming
mode.
7. Within 10 seconds press the LOCK or UNLOCK button on same remote.
8. Within 10 seconds press the LOCK or UNLOCK button on all other
remotes you want to program. Make sure door locks cycle after you push
each remote button to confirm system has accepted the remote.
9. Turn the igniton switch to LOCK (0) to exit programming mode.
10. Test remote(s)
Hope this helps :)
John
Mar 26, 2009 | 1998 Acura TL
Keyless remote
Note:
all of the keyless remotes once you are in the programming mode. You must complete each step within 4 seconds of the previous step to keep
used in step 2
mode.
10. Test remote(s)
Dec 24, 2008 | 1998 Acura TL
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
53 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
