Question about Konica Minolta magicolor 2400 Laser Printer
2430 dl paper alot of paper stuck
Paper stuck in an area I cant get it out right before it comes out the top. I pulled and paper ripped help
    Champion:
  • 214 Answers
Hello
best way to check FU is take it out from printer,
first remove backside and left side cover, in backside there is a 4 small wires with 2 pin connectors you have to unplug connector, in left side there is a bigger withe and black wires, you have to unplug connectors. then open cover and remove *PC drum, also remove transferbelt, first remove 2 screws, 1 screw at each side, then unplug connector upper right and lift and remove transfer belt.
BE VERY CEARFUL WHEN OPERATING WITH TRANSFERBELT. DO NOT DAMAGE THE BELT.
then you cand remove 2 screws at each side of fusing unit, when moving the whole FU to right /maybe left, dont remember/ you can bull out the fusing unit. its a little tricky to take it out.
when you got the FU in your hands, you can inspect it, remove any paper, stuck. AGAIN, BE VERY CEARFUL, DO NOT DAMAGE THE RED ROLLER AND DO NOT USE ANY SHARP THINGS.
when needed you can also remove a few screws at the fusing unit and then you can take the fu a part to see whats wrong.
good luck.
Posted on Jul 01, 2008
Kyocera fs 3920 dn printer ripping paper when it prints
Hi, dear; it have to be something stuck in the paper path, do following way; make a copy after 2 second stop the machine,pull out the paper,see there have been rip on the corner, if yes check that area, if not do next copy after run for 4 second , stop the machine, pull out the paper check it again until you found out the rip happen, the paper chip should be there. good luck
Aug 31, 2012 | Kyocera 1102J12US0 Model FS-3920DN Small...
I have some small pieces of paper stuck in the fuser unit from a sheet that got stuck - how do i get them out as I cannot see them?
Start to dismantling it untill you are able to see the paper and then with tweezers remove the paper carefully
May 03, 2010 | Konica Minolta magicolor 2430 DL Laser...
RE: MP530 ALL IN ONE PRINTER ripped paper stuck in printer
Open the printer from the back you should see if there are paper scraps there. note that if you did not switch off the printer before pulling paper, the printer may damage. but try opening the printer from the back it could help.
Jun 29, 2009 | Canon PIXMA MP530 All-In-One InkJet...
Konica Minolta 2430 DL sometimes cartridge, sometimes paper jam
When the print cartridge contacts are dirty and the printer cannot detect/communicate with print cartridge.
Clean the contact points on the cartridges with a dry, lint-free cloth.
1. Open the top cover of the printer.
2. Remove the print cartridges.
3. Clean the copper-colored contact points on the cartridges with a damp, lint-free cloth.
Use a dry, lint-free cloth to remove moisture from the contacts.
5. Insert the cartridges back into the printer.
6. Close the top cover.
7. Try printing again.
If you still cant communicate try with new cartridge .
Hope this help. Please Rate My Response! Thanks!
PREM
Mar 23, 2009 | Konica Minolta magicolor 2430 DL Laser...
Transfer roller paper gets stuck and now it says black ink not installed when it is.
If you look on the right side of the toner cartridge you will see a green chip with three contacts on it. Clean the contacts with an eraser or rubbing alcohol.
Jun 28, 2008 | Konica Minolta magicolor 2430 DL Laser...
Konica Minolta Magicolor 2430 DL - Paper Feeding problem and Clicking Sound
right now, i dont know about the cliking noise, there can be many things causing this. but for hevy paper open cover, take out PC drum, under that there is a take-up roller, pull the little knob in right side and then move it to the right side, then you can pull out the take-up roller, then clean the roller and the plate, whats under the roller. installit back. if thats not helping, then you have to take the roller out again, and cut off two plastic sides.
it shoult help.
Feb 08, 2008 | Konica Minolta magicolor 2430 DL Laser...
Minolta 2350 DL laser printer stuck paper in rear user roller
sry, dont understand, where is the paper jam, in the end at the fuser ? or some where else?
Feb 05, 2008 | Konica Minolta magicolor 2430 DL Laser...
Konica Minolta Magicolor 2430DL--black line on right side of paper
Sry but you have to change drum cartridge, the line is caused form drums cleaning system, and it cant be repaired.
Oct 18, 2007 | Konica Minolta magicolor 2430 DL Laser...
Konica Minolta magicolor 2400 Laser Printer Logo
65 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
