Question about Refrigerators
Have a Whirlpool ED25RF (XFW01) refrigerator that recently stopped working from time to time. Found that tapping on the control panel would make the fridge work again. A little research pointed to either a faulty cold control or frost timer, but not sure how to access the control panel. Already unscrewed the 4 screws and 2 hex screws holding the cover plate in place, but it still seems to be firmly fixed onto the top. Anyone know how to access the control panel?
  • Anonymous Apr 05, 2009
  • 24 Answers
SOURCE: freezer cold but not fridge
too much ice bulid up will stop enough cold air being blown into the fridge.Try turning it off letting all ice melt then turn it back on again and set thermostat at a lower temp.There may be ice you can't see.
Posted on Oct 08, 2008
jcpark50
  • 52 Answers
SOURCE: Refrigerator not cooling, frosting up
You might try GE customer service and ask where to locate the defrost timer,since that sounds like your problem.
Posted on Nov 07, 2008
lenwest
  • 150 Answers
SOURCE: refrigerator will not get cold, but freezer works
Make sure your fan is working ,its located behind the freezers back wall. If it is working the vent from the freezer down to the refrigerator may be blocked (usually with ice).With out a fan you have no circulation but your freezer may look likes its working,it may last 3 days.Also if you can move everything out unplug it turn it off w/ doors open untill all traces of ice are gone this will free up any clogged tubes. Good luck.
Len West
Posted on Feb 27, 2009
Sea Breeze
  • 4655 Answers
SOURCE: Amana Refrigerator Model ABB2222FEQ Control Panel Cover
Yes, I can help you and send you the service manual also, Thanks, Sea Breeze
Posted on Jun 16, 2009
  • 86 Answers
SOURCE: Whirlpool side by side refrigerator ED25RF stops running
It sounds as if the thermostat may have gone bad.
Posted on Apr 19, 2010
Refrigerator whirpool is only working after tapping on the front control system panel? which part has to be replaced?
Whirlpool side by side fridges with the control panel across the fridge section have thermostats that will fail. Tapping on that control panel will cause the fridge to work temporarily. You will need to replace the refrigerator thermostat if you see small black specks under the thermostat.
Oct 21, 2016 | Whirpool Refrigerators
Model ED25RF freezes items in bottom crisper drawer. Other parts and drawers ok.
We run across customers that have this trouble from time to time with there refrigerators. The first question i usually ask if the have changed the temperature setting recently. If not try a over night defrost, open the doors and unplug the refrigerator over night. That seems to take care of the problem. Its also a good time to give it a good cleaning. Don't forget to clean your condenser coils to.
If it helped join or Google Plus please.
On Time Appliance Google
Jun 30, 2015 | Whirlpool Refrigerators
Ed25rf
Water collecting in the bottom of the freezer is usually caused form a condensate drain blockage. Remove the back panel and there should be no ice around the drain. if there is pour hot water in and around the drain to clear it and flush it out. This should get things fixed.
Jul 23, 2014 | Whirlpool Refrigerators
Refrigerator stops working until I roll the switch to off and back on
ummm hi bill.well u played with the stat and it worked for a while.so i reckon thats your problem.change stat and try good luck.ali
Aug 21, 2012 | Whirlpool Refrigerators
I have a Whirlpool ED25RF refrigerator that stopped cooling. Lights work. At first i noticed the freezer would be completely melting items the refreezing eventually the whole unit quit working; refer
sounds like your compressor was failing with a bad contact and has now stopped working, will cost as much to repair as replace. At least newer fridge save costs in electricity, yeah sucks to have to buy another, sorry not much else you can do
Jun 09, 2012 | Whirlpool Refrigerators
Whirlpool GB22DKXGW00 stopped working while connected to a power inverter during a recent power outage. The light still works so I know it's not an outlet issue. Fan's not moving, no humming, just silence.
I would check your defrost timer it will be located at the bottom of the ref under the kickplate. You can manually advance it by hand and see if the unit will kick in. If this doest not correct the problem then I would assume that you have a bad temp control or a shorted compressor winding. You can try tapping on the control panel by your temp control with the back of a screwdriver and see if the unit will kick in. Hope this helps _MJ_
Mar 04, 2010 | Whirlpool Gold White-on-White 21.9 cu. ft....
I have a whirlpool model ED25RF that stops working and defrost every couple of days. Later it will turn itself back on and start working fine. What may be causing this?
That sounds like the defrost timer inside the fresh food section part number 482493 is slowing down and on its las leg, Sea Breeze
Oct 20, 2009 | Whirlpool Refrigerators
Model ed25rf compressor not running door on
If the compressor isn't running , tap the thermostat and seeif it starts . If so , then thermostat is problem . If not , overload/relay on the compressor . Both are inexpensive .
Jul 19, 2009 | Whirlpool Refrigerators
Refrigerators Logo
291 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
