Question about Haier XQG50-11 Front Load Washer / Dryer
The Drum turns, but no heat, is it ok? Different machine, same problem. I've switched out the timer, thermostat/fuse assembly, and element. Though the feedback for this machine was great when I bought it, I now see a lot of "dryer quits after 2 years". Having replaced these parts and seeing no improvement, I'm wondering if it's time to give up and buy a Bosch dryer (the washer part of the Haier works fine). Thanks for any help! Jeremy
  • Jeremy56 Jun 28, 2008
    It's a 110V machine...
  • 481 Answers
Check your breaker, sometimes if one side of the 220v breaker trips and not the other then the dryer will run with no heat. if you have a voltage meter then check the outlet itself for a full 220v.
Posted on Jun 28, 2008
Replaced all parts for dryer because of no heat dryer runs drum turns had breaker and wiring going into dryer everything ok still no heat could wires be backwards going to replacement parts?
Electric dryers have as many as three thermal fuses. See if you might have missed one. One next to coils, one next to drum and one near the lint trap at air outlet. All three have different trip settings.
Jan 04, 2016 | Dryers
No heat
Hi.
If it is turning but not heating, check the thermal fuse if present. The fuse is also tested checking continuity. If the fuse is OK, check the thermostats in the heater assembly. If the thermostats are good, they will read zero or very low impedance at room temp.Depending on the model there are two or three thermostat/thermistors in the appliance.
If even thermostats are OK, check heating element. It must have continuity.
If element is OK, check wiring, then fan, then go for the timer control.
Here all parts.
Regards.
Ginko.
Feb 27, 2011 | LG DLE2516 Electric Dryer
Runs turns but does not heat
It could be the heating element, a safety limit, a control problem, or an electrical problem. A heating coil is used to warm the clothes as they get tossed gently inside the drum. A blower mounted on the motor pulls air through the heating element into the drum and out the exhaust. The element gets old and brittle with use and eventually needs replacement. That is what you check first. On gas dryers vibration and age will cause the ignitor to crumble and fail. If it turns out the element is fine then one of the safety's might be blown. These safety's are set to a certain temperature
for the dryer to operate safely. The drum temp control for cotton is 160f. A limit on the heater housing is 250f. If it fails another smaller limit is mounted nearby that blows at 300f. If that temp exceeds 350f a duct fuse mounted on the blower housing opens and kills most dryers. On gas dryers the duct fuse will kill the gas assembly but the dryer will still run. If all of those safety's are good the timer could be the problem. The timer has a terminal on it that runs down to the heating element. If you suspect it is bad you can check it with a meter. That leg of the timer should have continuity with other terminals on the timer at different spots on the timer. Turning the timer and checking for continuity will give a clue. If you cannot get continuity with any other terminal on the timer at any position on the dial then you have a burned contact in the timer. If that turns out to be good, you would need to inspect the electrical outlet for proper power to the machine. On American models the motor runs on 120 volts but the heating element must have 240 volts. If you have more questions just post a comment. Good luck on repairing your machine. I have some repair photos: HERE
Aug 09, 2010 | Roper REX4634KQ Electric Dryer
The dryer does not heat?
It could be the heating element, a safety limit, a control problem, or an electrical problem. A heating coil is used to warm the clothes as they get tossed gently inside the drum. A blower mounted on the motor pulls air through the heating element into the drum and out the exhaust. The element gets old and briitle with use and eventually needs replacement. That is what you check first. On gas dryers vibration and age will cause the igniter to crumble and fail. If it turns out the element is fine then one of the safety's might be blown. These safety's are set to a certain temperature
for the dryer to operate safely. The drum temp control for cotton is 160f. A limit on the heater housing is 250f. If it fails another smaller limit is mounted nearby that blows at 300f. If that temp exceeds 350f a duct fuse mounted on the blower housing opens and kills most dryers. On gas dryers the duct fuse will kill the gas assembly but the dryer will still run. If all of those safetys are good the timer could be the problem. The timer has a terminal on it that runs down to the heating element. If you suspect it is bad you can check it with a meter. That leg of the timer should have continuity with other terminals on the timer at different spots on the timer. Turning the timer and checking for continuity will give a clue. If you cannot get continuity with any other terminal on the timer at any position on the dial then you have a burned contact in the timer. If that turns out to be good, you would need to inspect the electrical outlet for proper power to the machine. On American models the motor runs on 120 volts but the heating element must have 240 volts. If you have more questions just post a comment. Good luck on repairing your machine. I have some repair photos: HERE
Aug 02, 2010 | Dryers
Dryer not heating
usually when the dryer is not heating is because the heating element has break. you can purchase a heating element kit with insulators at a parts appliance store.requires taking the dryer apart and removing the drum. the heating element is behind the drum. if your handy you should have no problem. good luck!
Jul 25, 2010 | Roper REX4634KQ Electric Dryer
Dryer is not heating
May 30, 2010 | Whirlpool LEN2000PW Dryer
Dryer tumbles but no heat. no low heat or hi heat
Feb 02, 2010 | Dryers
No heat drum turns no heat blower works no heat
Feb 01, 2010 | Dryers
I am not getting any HEAT???
It could be the heating element, a safety limit, a control problem, or an electrical problem. A heating coil is used to warm the clothes as they get tossed gently inside the drum. A blower mounted on the motor pulls air through the heating element into the drum and out the exhaust. The element gets old and briitle with use and eventually needs replacement. That is what you check first. If it turns out the element is fine then one of the safety's might be blown. These safety's are set to a certain temperature
Jan 12, 2010 | Dryers
Dryer not getting hot
Jan 07, 2010 | Dryers
Open Questions:
See all Haier XQG50-11 Front Load Washer / Dryer Questions
Haier XQG50-11 Front Load Washer / Dryer Logo
243 people viewed this question
Top Haier Washing Machines Experts
Gerry Harvey
Gerry Harvey
Owen Barnes
Are you a Haier Washing Machine Expert? Answer questions, earn points and help others
