Question about Panasonic PT-45LC12 45" Rear Projection HDTV-Ready Television
Panasonic PT-45LC12 just turned off?
I was watching tv and it just turned off.. Lamp is good, I checked it. but when you push the power button it just blinks green.. I don't hear the fan kick on .. that is what I think it is, the fan is out. does the tv have a sensor that if the fan doesn't come on that the tv won't come on?? If you agree that it is the fan where do you suggest I get one?? Any help you could give would be great.. Also, while the green light is blinking there is no sound what so ever. Any help you may have would be great.
Thanks,
Chris
  • danimarie1 Jul 01, 2008
    Exactly the same thing is happening to us!
Having the same problem, after some research, came across this: http://www.fixya.com/support/t142873-panasonic_pt40lc12_blinking_green_power
Not a tech, so I'm going to look into it further on how hard this is to do.
Posted on Jul 02, 2008
New Bulb... No Screen...
Ballast Board ,it is what turns Lamp on! Call Encompass Parts for Part or look them up online they have website. Call 1-800-638-3328 Ok I looked it up Part# is LSEB3062A1 which showed No Longer avaliable,So try UED 1-800-648-6657 and Look on E-Bay under Electronics For Ballast Board.
Nov 19, 2009 | Panasonic PT-45LC12 45" Rear Projection...
Pt-45lc12
It looks like a problem with a tube (projector light) I suspect the green one. Pay attention to flickering on the lights and post me the results.
Nov 01, 2007 | Panasonic PT-45LC12 45" Rear Projection...
Panasonic PT-45LC12......won't turn on
Its ballast supply issue that need to be replaced/ repaired.
Ballast supply drives Lamp in TV.
Jul 06, 2009 | Panasonic PT-45LC12 45" Rear Projection...
Lamp reset
Pushing the - volume button on the tv and split above the play button at the same time for ten seconds or - volume on the tv and the split control button at the same time. The lamp reset message should come on.
Nov 23, 2008 | Panasonic PT-50LC14 50" Rear Projection...
Panasonic TV
Good Day,christie511;
It sounds like the lamp is in need of replacement. You could call a service company to replace the lamp, but it is so easy to replace the lamp ones self. So, call Panasonic and order the lamp, they will send to your home with instructions.
Three screws and your home free!
Good Luck, Big Irish.
Jul 08, 2008 | Panasonic PT-45LC12 45" Rear Projection...
Powerb button blinks and TV doesn't turn on
i think its time to replace your lamp if you have not done so.
you sould be able to get it from the front and also look at it most of the times you will see the broken glass pieces inside. only tool you will need its a philips screw driver.
Jul 03, 2008 | Panasonic PT-45LC12 45" Rear Projection...
Resetting lamp replacement warning
Turn the TV on and press recall to clear the warning. Then hold down the volume " - " button on the tv and the PIP (Play) button on the remote for ~ 5 sec
Apr 03, 2008 | Panasonic PT-45LC12 45" Rear Projection...
PT-45LC12 Problem after startup
When the lamp flashes 4 times this is what the error code means IC 2301 pin 11 has detected an LCD error which is caused by an error in the LCD power CBA. which means the lamp voltage has become more than 130 volts or less than 30 volts. Or the lamp current is more than 5 amps, or the lamp is cracked. Its one of thos 3 reasons that will make the lamp indicator blink 4 times. Hope this helps. If you need the service manual for this model you can get one emailed to you from the following link.
http://servicemanuals.vstore.ca/
Mar 31, 2008 | Panasonic PT-45LC12 45" Rear Projection...
PT-45LC12 wont power up
You have a bad lamp. The "clicking" sound you hear is the ballast (lamp power supply) attempting to start the lamp. The warning on Panasonics that comes up on screen does so when the life expectancy of the lamp is approaching. Otherwise your "clicking" sound and the red light on front are saying bad lamp. When you replace the lamp remeber to follow the instruction that Panasinc provides with the new lamp on restetting the lamp timer. This is usually done with the volume down on the TV and the PIP button on the remote.
Feb 26, 2007 | Panasonic PT-45LC12 45" Rear Projection...
Panasonic PT-45LC12 45" Rear Projection HDTV-Ready Television Logo
140 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
