Question about Microwave Ovens
Microwave died while opening door. Electrical/Electronic problem perhaps? Model is N710E.
  • Microwave Ovens Master
  • 9,098 Answers
If it goes dead or blows the breaker when you plug it in or open or close the door, then there's a problem with a door switch or door switch mount.
If you or someone you know decide to look into it, we have critical safety information, info on door switch diagnosis and replacement, and disassembly information at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
The more specific links of interest:
http://www.microwavedisplay.com/safety.txt
http://www.microwavedisplay.com/disassembly.txt
http://www.microwavedisplay.com/doorsw.txt
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Jun 29, 2008
My oven turned in mode demo. Do you know how to turn it off?
Perhaps if you gave the manufactures name and model # it would be easier to give the correct answer. Perhaps reading to book that came with unit would provide the answer.. Perhaps.. unplugging unit wait a bit then plug it in again will reset the unit... Lots of perhaps.. never heard of a demo mode, what would be the point of that with a microwave... sounds like something is broken such as the door switch or a Ckt. Board fried or the megatron died...
Nov 25, 2015 | In Microwave Ovens
My Magic Chef microwave oven blows fuse when i open door
If you're blowing fuses from opening the door that is the sign of a electrical short . You'll need to call a electrician to check it out. Changing the fuse in this unit can kill you. There's a capacitor that holds stored electrical energy that is dangerous. My good friend died from trying to change the fuse in his. Get a professional to check it.
Feb 05, 2015 | Magic Chef MCO160UW White Over-the-Range...
My Kitchenaid microwave model YKCMS1555RSS-1 continues to run. The microwave will only stop once the door is open or the unit is unplugged. Any ideas what this could be?
One of your three door switches is bad. They are cheap. replace them all. Careful some are normally open and some are normally closed. Don't get them confused or you will get other symptoms like a blown fuse
Dec 30, 2014 | KitchenAid Microwave Ovens
I have a Russell Hobbs RHM2018 microwave oven with grill and the turntable will not stop going round and the light stays on until I unplug it? Once plugged back in it carries on in the same way? If I
The switch for the turntable does not disengage anymore. Could be a relais, could be an electronic switch. When opening the door, a second switch, in series with the other one, connected to the turntable motor disengages, stopping the motor. The light is switched on, because you opened the microwave. Perhaps you never noticed this, but it is the normal way that should work.
Aug 31, 2014 | Microwave Ovens
Whirlpool over microwave combo has burning smell in microwave
Probably fragments of food burning on the waveguide cover.
Jul 31, 2017 | Microwave Ovens
How do you replace the handle
follow this steps and fix it. see the pictures attached. God bless you2f4dab72-f574-4367-8631-e2d40f813792.gif
Open Lever
If the microwave door won't open the open lever might be broken. This part can be replaced separately.
Enter your model number to see parts for your microwave.
Help me find my model number
Door Spring
If the microwave door won't open the door spring may have broken. The door spring is located inside the door and keeps downward pressure on the door hook.
Door Latch
If the microwave door won't open the door latch might be broken. The door latch is inside the microwave. The door hook, which is part of the door, engages with the latch to keep the door closed during operation. If the door latch or actuator breaks the door may not open.
Door Hook
If the microwave door won't open the door hook might not be releasing properly. The door hook is installed inside the door and normally releases when the door is opened. The hook is made of plastic and will break over time. When this happens it will need to be replaced, it can't be repaired.
Button Spring
If the microwave door won't open the button spring might be broken internally. The button spring can be replaced.
Button
If the microwave door won't open the button might be broken internally. The button can be replaced.
Handle Actuator
If the microwave door won't open the handle actuator might be broken. This is a plastic part which can become brittle over time. This part is connected between the door button and the door latch assembly.
Jun 18, 2013 | KitchenAid KHMS147 Microwave Oven
I have a amana road range microwave and the door won't close . AMV3204VAB-0
proceed according . God bless you
Open Lever
Door Spring
Door Latch
Door Hook
Button Spring
Button
Handle Actuator
Apr 02, 2013 | Microwave Ovens
Over the range microwave oven
The problem is the release spring is broken or the button is sticking, pick up a small can of electronic cleaner attach straw and spray into the button crevis to break down the crud, grime, and dirt this should help release the mechanism.
Apr 23, 2012 | Panasonic NNH965BF Microwave Oven
My new panasonic microwave model NN ST 340w has the internal light on when I heat up food. However when I open the door to put food in or take it out, the internal light does not turn on. What can I do?...
Your oven light is busted or damaged. You can buy the replace at the any electronic shop. Just open the top cover then you will see the light you will going to replace
Aug 15, 2011 | Panasonic NN-H664 Microwave Oven
Microwave Ovens Logo
46 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
