Question about Sanyo Vacuums
Where/How do the Sanyo Transformax vacuums open to change the bag?
Use a hammer to pry it open.
Posted on Jun 28, 2008
How do we open the Sanyo Transformax 3 in 1 vacuum cleaner? The bag is full and we cannot get it open. I do not have a smartphone. Can you call me on my home phone?
besides the fact that you have not given a phone number ( very unwise on unsecured web pages) we don't make calls
you can get that information by ringing the local service agent yourself
Aug 13, 2017 | Sanyo Vacuums
Need to change bag
here's the link to the instruction manual; http://sanyoservice.com/pdf/images/SC-180E.PDF (it is for the sc-150 and sc-180) Check page 8 for details. Hope this helps :)
Jul 31, 2007 | Sanyo Transmax SC-150 Bagged Upright...
I am trying to change the bag on my sanyo transformax 3in1 vac, cannot open it how do i open it?
This video may help you. Also you might find the manual at this site: http://homeappliance.manualsonline.com/manuals/mfg/sanyo/sc15m.html
Nov 16, 2016 | Sanyo Vacuums
I just got a used sc-a102 vacuum and I need to
Greetings from GoVacuum.com,
The Sanyo Performax model SC-A102 use the Sanyo Upright Bags Part Number PU-1 Bag. We stock most of the parts for this Sanyo if you ever need anything.
Here's some links to the products on our site that will fit your vacuum cleaner:
- Sanyo PU-1 Upright Vacuum Cleaner Bag, Generic 9pk.
- Sanyo SC-A102 Performax Vacuum Cleaner Belts, 2pk. Part SC-BL3
- Sanyo SC-A102 Performax Vacuum Cleaner Exhaust Filters Part SC-FU1
- Sanyo SC-A102 Perfoxmax Roller Brush Part 6490002487:
http://www.govacuum.com/sanyo-bagless-upright-12-inch-replacement-roller-brush-beater-bar-sanyo-part-6490002487.html
GoVacuum.com can also special order any part that you require. I hope that this helps you. The Sanyo uprights are pretty good quality, inexpensive vacuum cleaners. They use metal in all the right places, and last longer, unlike models that use just plastic.
If you found this helpful, please rate it as helpful by clicking the 4 Thumbs Up Icons in the top right hand corner of the page.
Thank you!
Chris Jones
GoVacuum.com
Mar 20, 2010 | Sanyo Permax SC-A102 Bagged Upright Vacuum
I can not find how to get the canister apart to empty the dirt.
From the bottom of your machine going upwards past the handle that is on the canister portion of this vacuum, you will see that the top of that canister had a depression where you should be able to put your fingers in, and gently pull that lid back, opening the vacuum bag compartment. According to the manual, simply pull that back, exposing the bag. To remove the bag, pull the cardboard plate on the top of the bag, out towards the no open face. Throw away your old bag, and take your new bag, fold down the paper sides of the bag, then slide the new bag into the track completely. Close your lid, and you are done.
While you have this compartment open, it's a good idea to check your filter that sits below the paper bag.
Part numbers
Paper Bag: SC-P11
Filter: SC-F2
I hope this helps you.
Jan 20, 2009 | Sanyo Transmax SC-180 Handheld Vacuum
I have been given a Sanyo upright vacuum cleaner. It is a Performax 10.0 amps, Model SC-A102. I cannot locate bags for it. I live in Houston, Texas
Two solutions come to mind---1) Find a local vac store, NOT a department or big box store, and bring the bag to them.Sometimes on the bag is an identifying letter or number and on many you need to remove the bag to see it. Also bring your make/model info.Many manufacturer bags are for identical machines that have been labeled for a retail chain.Panasonic product with a Kenmore label for instance.
2) Ebay has some of the best deals and widest array of harder to find bags,filters and accessories.Good Luck-Scott
Oct 09, 2008 | Sanyo Vacuums
Sanyo vacum cleaner SC-815
The power cord does not stop and retracts automatically, how do I re-tension the cord,
Do you have copy of instruction manual or manual on repair?
Apr 19, 2008 | Sanyo SC-800P Bagged Canister Vacuum
Hi, my sanyo pulse 1500 bagless vacuum has very little suction.
If the vacuum will run without the hose attached, does the suction seem ok at the opening where the hose goes into? If so, then you have a clog in the hose or down below where the dirt is first sucked up. If suction is poor at the vacuum, then check the filters, they go bad after awhile.
Feb 24, 2008 | Sanyo Bag-Free SC-240 Canister Vacuum
Sanyo vacuum cleaner bag
We have the Sanyo Transfomax 3 in 1 vacuum and FINALLY found that one has to use a screwdriver at the edges of the "hand hold" just above the Sanyo name (between black and green parts), to pop open the cleaner in order to replace the bag or clean the filter.
What a miserable way to change a bag!
I know this is almost a year late...but I just found your request. Ta ta, Rita
Sep 16, 2007 | Sebo X4 Bagged Upright Vacuum
Vacuums Logo
1,137 people viewed this question
Top Sanyo Vacuums Experts
Gerry Harvey
Gerry Harvey
ray gallant
Thatvacguy.com
Are you a Sanyo Vacuum Expert? Answer questions, earn points and help others
