Looking for blue projection tube for rca model p52923 tv
  • cadet48 Jun 28, 2008
    Thanks for the info.going to order
  • 8,617 Answers
You can get a blue tube for your rCA at the following link, leave them a email and state the model number of your set and what your needing
http://servicemanuals.vstore.ca/
Posted on Jun 28, 2008
  • Sonny Berry
    Sonny Berry Jun 28, 2008
    Youre welcome glad I could assist you.
Then i turn my rca tv on manually it wont come on
How old is the RCA TV. Is it an LCD Projection model or the older CRT (3 tubes - Green, Red and Blue) type projection model?
If LCD it could be a bad lamp or power supply. If a CRT it could be one of the Tubes is bad or again a bad power supply.
Nov 09, 2014 | Televison & Video
I have an RCA 52 inch rear projection tv. Model # HD52W59 The blue CRT is arching inside the tube and I get no picture on the TV at all. Is the blue CRT gone bad
Yes,the blue CRT is dead,arching indicate the high voltage not going through the CRT tube anymore.Try website like Tvrepairworld.com,check if u still can buy refurbish crt tubes.
May 23, 2010 | RCA HD52W59 HDTV Projection Television
My RCA D52W20 turn on with a blue screen and then turns off within 3 sec's. It goes off like someone has switched off the TV. The light blinks and goes off. Can anyone help
Your blue tube has a short. What you are seeing is the TV turning on and the blue tube going to full brightness. It then draws enough current that the television's protect circuits shut it down.
Need the full model number which should include a BYX or just YX followed by a number. Going off the D52W20BYX1 the blue tube would be part number 263049 which https://www.encompassparts.com still has a few for $220 before shipping.
Jun 29, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Rca D52W20 blue screen when turned on
Almost certainly the blue picture tube is bad. This is a huge job to replace and quite expensive. Generally it is not worth doing.
Mar 26, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Water looking droplets on inside of blue lens
droplits are more than likey air. sound like a glycol leak on the blue tube. look for liquid underneghth the tube. THis would require replacement of blue tube.
Dec 10, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA D52W19 only Blue lamp firing
Shorted Blue picture tube or video ic on blue CRT board.
Sep 01, 2008 | RCA D52W19 52" Rear Projection Television
RCA Projection TV Model P52923
Good Day, Ajejo;
Sorry I'm not Circuit City, but work for them for many years down here in TX.
The chassis number is the best way to find out information about the TV. The CTC195K3 is very commonly known to have bad 'flyback'. The crusting you indicated on top of said transformer is the indication that it is defective, I've changed 80-90 of them over the years.
So, job well done, your wife must be proud of you.
Part information: Location; T14401, Part Number; 239111, Name; IHVT, Integrated High Voltage Transformer.
Caution when replacing the fly, looking at the bottom, the pins are shaped like a horse shoe. At the closed end there is an separate pin. Make sure new has the extra pin (for focus), Iv'e had many lately that does not have it.
Good Luck, big IRISH. PS; good job good eye let me know.
Jul 11, 2008 | RCA P52926 52" Rear Projection Television
Rca 60'' p60928
The set does not have a blue lamp. The set has a blue picture tube. I have found that the best RCA parts distributor is Union Electronics at 1-800-648-6657. The picture tubes in projection sets are very fragile and dangerous to handle. The new picture tube will come dry, so the lens assembly and seal will have to be assembled onto the new tube and then filled with fresh coolant. The set will then need a complete realignment, everything from screen and focus voltages, bias and drive, yoke and ring position to convergence circuits. If you have no experience in any of the above, do not attempt to replace a picture tube. Allow a qualified tech to handle it for you.
Aug 28, 2007 | RCA P52926 52" Rear Projection Television
Televison & Video Logo
109 people viewed this question
Top Televison & Video Experts
Electro Med Services...
