Question about Panasonic Cameras
I have a Panasonic DMC-F27 digital camera using a SanDisk. I keep getting "disc error format yes or no". I don't want to lose my pictures, so should I select yes or no? Thank you
  • nicknameme Jun 28, 2008
    So, is there anyway to retrieve the pictures
    I already tried putting the disc into the card reader on my HP printer and got the same message on my printer disc error
    Thank you so much for your input though.
    I really would like to retrieve the pictures already on the disc
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 114 Answers
For sure if you select yes, you will lose your pictures. Formatting erases everything from your card and you cannot get them back.
Posted on Jun 27, 2008
  • Marinos
    Marinos Jun 28, 2008
    I would suggest to use a card reader for your sandisk card and copy all your pictures to your PC
Is there a long lens for the Panasonic DMC-F27?
Camera is currently equipped with a Leica 12X zoom lens. I would like to be able to take pcs. from a greater distance than this lens permits. Can you recommend a lens that I can attache to the Panasonic DMC-F27 that will enable me to do so? Thank you!!
Apr 14, 2013 | Panasonic Lumix DMC-FZ7 Digital Camera
My Panasonic Lumix DMC-FH1 digital camera will not let me delete photos,
First : is it the same to other SD Card?If yes thenSecond: is it happened to other SD Card?if the second answer is YES -> it might be the I/O part of the camera
but if the second answer is NO -> try to re format that SD Card it might contained a faulty fat (file alocation table)I hope it help
Dec 07, 2011 | Panasonic Lumix DMC-FH1 / DMC-FS10 Digital...
My panasonic camera DMC-F27 is showing "memory
Hi pblac11,
This could be a problem with the format of the memory card , or the memory card is not formatted as per the requirements of your camera.
I would give you a way out to try and see if it works , as I have been through this problem myself too.
Using a card reader device , connect your memory card to your computer and make sure it gets detected in your computer.
In case you are using windows xp , vista or windows 7 , you will find the removable drive relevant to your memory card being detected.
Now all you have to do is try and format the card in a mode that is different than the current one.
For e.g if your memory card has been formatted by NTFS file system , then try changing the format to the FAT32 file system.
and if it's FAT32 already , try formatting the card with the NTFS system and then try and insert the card in your camera after it has been formatted successfully.
The above solution has helped me , hope it helps you as well..:)
Your feed back would be appreciated.
Jun 21, 2011 | Panasonic Lumix DMC-FZ7 Digital Camera
I have Panasonic Lumix FX9 and I have an original 16mb memory sd card that is working but when I put another card the camera says "memory card error please check tha card" and I don`t know what...
Welcome to FixYa.
One possible reason why do you get a "memory card" error is because the memory card is not yet formatted for camera use. Try to format the memory card using the camera itself. Do not use another camera or PC's when formatting the memory card,it may cause another error because it will not recognized by the camera.
Try also to clean the memory slot by using a soft and dry cloth. Then turn on the camera again.
If the message still persist, you neen to contact Panasonic service center.
Please let me know if you have any questions or if this solution was helpful.
Thank you for using FixYa.
Apr 15, 2011 | Panasonic Lumix DMC-FX9 Digital Camera
Hi: I have a lumix/Panasonic DMC-FS3. I keep getting a message "Memory Card Error. Please check the card." Nothing has happened to the card. What could cause that?
Has the memory card ever worked in this camera? If yes, try downloading all the pictures to your computer then format the memory card using the camera setip menu. If this is a new camera, Make sure the camera can use the SD HC type memory cards. Some older cameras cannot read the SDHC but are fine with the SD cards.
Nov 21, 2009 | Panasonic Lumix DMC-FZ20 Digital Camera
Replacement lens cap for Panasonic Lumix DMC-FZ7 digital camera
Please see below for a link to the Lens Cap with String. This is an original part direct from Panasonic. Used specifically with this camera.
Lumix DMC-F27 Lens Cap with String
Mar 26, 2008 | Panasonic Lumix DMC-FZ7 Digital Camera
Cameras Logo
53 people viewed this question
Top Panasonic Cameras Experts
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
