Question about Frigidaire Refrigerators
We have a Refrigerator Model FLSC238DS Serial # 4A73108503 that we purchased on 9/01/07. With the dispensing of ice or water, we see small white plastic specs on the side of the glass or deposited on the ice. What can be done to eliminate this contaminated water or ice?
  • 58 Answers
Unplug the power cable , then empty as if you are using it
Posted on Jun 27, 2008
    Brigadier General:
  • 3,614 Answers
You can put a filter/purifier on on the water line before the connections to the ref.
I have just purchased a Samsung 636L Refrigerator and my icemaker doesn't seem to work. Help please.
Hello Roseanna;
My name is Peter. I am a retired field service refrigeration technician.
I require the complete model number to see what you have. The model number is on the wall in the fresh food (refrigerator section)
First, if you have just purchased this unit is it is under warrantee, where a service technician will come to your home at no charge and fix the problem.
I am going to take a guess, having serviced Samsung refrigerators for years, the type icemaker that you have. I believe you may have a ice maker in a small compartment.
Usually a ice maker will start after the temperature is above 40 degrees F. If this is the ice maker I think it is; in the front of the ice maker, on the bottom, there is a small red square button. This is the ice maker cycle button.
Push the cycle button and listen to hear the water fill the icemaker. Hopefully, the installers had just never done this.
Do you have a water dispenser? Is the water dispensing?
If you do not have a water dispenser, then perhaps the installers either did not connect the water line nor turned the water valve to open.
If the ice maker does not cycle, and the water supply is open, chances are you have a bad ice maker.
I have gone on service calls where the unit was delivered one day and I am there the every next day. On these service call I have found bad compressors, bad control boards, and yes - bad ice makers.
Oct 29, 2014 | Refrigerators
I purchased a new whirlpool conquest and have had on for two days. i have water coming out of the water dispenser but still no ice production. There is no water in the chute leading to the ice maker. ...
Maybe it won't call for water until it goes through the cycle. Try putting water in the ice mold and see if it starts working when it freezes and dumps the ice. Make sure the water line is open by swapping the wires on the dual water inlet valve. Then the water dispenser will send water to the ice maker and you'll know the valve and line works.
Sep 01, 2010 | Whirlpool Gold White-on-White 21.9 cu. ft....
Whirlpool Refrigerator water leak through Ice dispenser
You need to remove the ice maker and open the front carefully. It has small micro switches inside it and it sounds like one that opens the water control valve is stuck in the on position. Be careful not to loose the arm spring and how that goes back together as you take it apart. Sea Breeze
Sep 18, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Ice Maker Works, Water Dispenser Doesn't
I have a whirlpool side by side. water and ice in front. ice working and water not. the hose is not frozen and it is not humming when you push the water dispenser. It would give us water and quit but now we have nothing.
Jun 25, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Just Purchased a Whirlpool Fridge Side-by-side?
it will start making ice within 24 hrs you should be able to get water out the door but it wont be cold but it takes 24 hr for the box to get cold and stabilized
Dec 28, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Ice Maker doesn't work
i press ice dispenser . and ice will not come out an light goses dimm please help
Sep 01, 2008 | Hotpoint HSS25GFP Side by Side...
GS6SHEXMLoo side by side ice dispenser not working
On advice from the tech I removed acess door. It was covered by frozen moisture.
I removed the motor it was full of water. I verified 120 volts at plug to motor from control
by depressing the door switch and ice dispenser lever at same time. The motor ohms out
but because of amount of water removed from it I am going to replace it and see what happens.
Aug 05, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
GE Arctica (PSS26NGSB) ice and water dispenser
need to call ge at 1800-386-1215 some of these sxs have a door insulation issue that they will either send replacement doors to an authorized service company to exchange at no cost to you or offer a rebate for a newer model. yours might be in this group
have your model and serial number out of the ref located in the refrigerator section, about 4-5 inches from the celing down the right side and call and see
Apr 12, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerators Logo
60 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
