Question about Lexmark Wheelwriter 1500 Typewriter
Beeping noise The typewriter will always beep one time when it reaches the same point on every line. How do I turn it off?
  • Lexmark Master
  • 3,594 Answers
Sounds like the rt. margin is set at that point. Tab to the far right then press the rt. mar. key it is on the L. side of the keyboard.
DickyO
Posted on Jun 29, 2008
Why is this brand new typewriter acting out?
Return it to the point of purchase as defective right out of the box.
May 16, 2014 | Lexmark Wheelwriter 10 Series II...
Stops typing mid line
Type to the stopping point, press the margin release key space to the desired location, press R. margin key.
Jan 08, 2014 | Olympia Mastertype 3 Typewriter
We have ibm wheelwriter 3000. When typing it makes a beeping noise. Tried to release margins, but still beeps
If it beeps on every key stroke try code "S" If it beeps once in a while it may be the spell check code "1" will turn that off. If it always beebs at the same place the R. margin is probably set there. Space all the way to the R. and press R. mar key.
DickyO
Aug 16, 2011 | Lexmark Wheelwriter 3000 Typewriter
Humming noise after turning typewriter on
If that is all that happens, no lights, no beeping you probably need a power supply or a board. If there are lights and beeping we need to know what it's doing.
DickyO
May 05, 2011 | IBM Wheelwriter 6 Typewriter
Swintec 8016 Typewriter making grinding noise all functions froze
Try some WD40 on the silver shafts that the carrier slides on they do get very gummy.
DickyO
Apr 26, 2010 | Swintec Office Equipment & Supplies
Right margin
Hi:
On all IBM Wheelwriters the right margin can always be typed through. The only indication you will get when you reach the right margin is a beep tone. To set the right margin, space to the desired point and depress the right margin key once.
Andrew
Jul 16, 2009 | IBM Wheelwriter 30 Typewriter
I turn machine on; it beeps 6 times and the
Usually means bad keyboard. You can try re seating the connections,but almost always you will nedd to replace the keyboard. You can order a replacement board or send yours in for repair. If you are handy and can do the exchange yourself.
Jun 16, 2009 | Office Equipment & Supplies
Carrier stays to the left
Look inside the machine and make sure nothing has fallen into it that may be blocking the carriage from reaching it's "home" position. Sometimes a lift off spool will fall off and do that.
Apr 16, 2009 | Brother GX-6750 Typewriter
Pitch Beeping
make sure the printwheel is locked in place, and the cover is closed. otherwise it is probably the main board or power supply. take to a repair shop for evaluation
Aug 14, 2008 | Brother EM-530 Typewriter
Beeping
It most likely beeping because it cannot make its resetting movement. That is,it cannot "find-out" where its left margin is. There may be something hindering the actual movement of the print carrier. Check inside the typewriter by lifting up the top cover and move the print unit by hand. It should be able to move from the left to right-hand side of the typewriter unhindered. The shaft that the print unit moves on should be clean and it may have gathered dust etc,so give it a wipe with a clean cloth (lint free) with a small drop of light oil on it.. Replace the top cover and switch on the machine
Nov 05, 2007 | Nakajima AE-740 Typewriter
Lexmark Wheelwriter 1500 Typewriter Logo
110 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
