One more question about the HP flat screen LCD monitor
Thanks for your help. I've already hooked up another old monitor to my PC. It works fine. I can reconnect the HP Flat Screen to my PC and I can get a boot menu, the desktop, etc. So I can get it to turn on with power and stay with power but the screen doesn't keep a display. I believe I've tried all of the HP website info troubleshooter info but it really only refers to a "black screen", not a "partial" black screen. I really appreciate your advice.
Thanks, Lisa
    Novelist:
  • 148 Answers
Thanks Lisa I'm glad I could help feel free to ask anytime... Be mucho blessed...Mark
Posted on Jun 28, 2008
Hp g72-227wm has a broken lcd screen i have a hp compaq le1711 vga flat screen hooked to my lap top it was doing fine i log off out of windows and shut down the pc when i turn it back on the flat screen...
Check monitor is set to correct input (VGA, DVI, HDMI) if it goes to sleep instantly.
Otherwise screen resolution is set too high. Boot into safe mode by pressing F8 during boot. Login and lower screen resolution.
Oct 03, 2012 | Computers & Internet
Laptop broken screen... plugged in Dell monitor,still doesnt work
You can switch to an external monitor or data projector by two methods. 1. Connect the external monitor to the laptop's video port, power up the external monitor first and the laptop. The video information will automatically switch to the external monitor. 2. If you power up the laptop first then you can switch the video output to the external monitor by pressing the Fn key and one of the Function keys, depending upon your make and model laptop. You can also toggle between the external monitor or both LCD screen plus the external monitor or back to LCD screen only by pressing the Fn key plus one of the function key. Here is a list of key combinations for some of the laptops :- IBM ThinkPad = Fn + F7 HP and Compaq = Fn + F4 Toshiba = Fn + F5 Dell = Fn + F8
Sep 03, 2012 | Computers & Internet
My newer flat screen monitor went black but works fine when hooked up to another computer and I have an older monitor that I hooked up and the older one works fine...??
That sounds like a display/resolution setting problem on your PC. I doubt there is anything actually wrong with the PC or the monitor, since both work with different combinations, so its most likely just a setting.
Some monitors don't display anything when they get a signal/resolution that is not compatible with their displays. I would try changing the display settings on your computer with your old monitor, then switch monitors and see if your newer monitor works.
Here's how to adjust the display resolution:
If in XP, right-click on the desktop and go to Properties, and select the tab for display settings and adjust/lower the resolution. If in Vista/Win7 right-click the desktop and select Screen Resolution/Display Settings and adjust it there.
Feb 15, 2010 | Rosewill R900J 19" Flat Panel LCD Monitor
My HP laptop's screen (the bottom end) continuously blinks
If you have already hooked up an external monitor absolutely its the ribbon cable connecting the LCD to Laptop If its less then a year old get the warranty for replacement
Aug 10, 2009 | HP Pavilion dv6000z Notebook
15" HP Pav. monitor turns on for a second but immed blacks out
Pls ask your dealer about the warranty..It depends as per the market.. If the light is comming then replace the AD card other wise The problem with the inverter card.. replace ...
Jul 06, 2009 | HP Pavilion F1503 15" LCD Flat Panel...
My gateway fpd1975w tft lcd monitor does not work. the power button just flashes blue and nothing comes on. i put an old monitor to my computer and it worked fine, and i hooked my monitor up to an old...
Restart the PC and get into SAFE MODE. Hit and release F8 many times right after turning on PC. If it works, then go into your video setting and either change the settings or remove the video driver. Restart the PC and you'll get 800X600 screen, then reinstall the video drivers. IF it won't go above 800X600, screen internals are bad, LCD toasted. I've seen that happen with LCDs and older monitors.
Jul 05, 2009 | Gateway FPD1975W 19" LCD Monitor
My HP LCD comes on when I turn on the power,but for few seconds.
The monitor has blown a capacitor, and if your good with a soldering gun and can locate the cap which will have the top rounded instead of flat, remove it and take it to the electronic store and they will give you a replacement. If the capacitor is bad it won't hold the charge and that's why you only see a second or two on the screen. Make sure you are capable of this kind of work, before you decide to do it.
Jul 02, 2009 | HP L1702 17" LCD Monitor
My hppavilion f1503 flat panel lcd monitor screen stay blank
The monitor should be plug and play, and you've already figured out that it's not your computer by plugging into a working monitor.
This is most likely the power inverter board in the monitor - this is common in many monitors. If the power light is blinking on-and-off, or just staying on with no image, that's the problem. There is a slight chance that it could be the light itself, but inverters fail more commonly.
If it's under warranty, send it back, if not, there are inverter boards for many common models of LCD monitors that are replaceable. The board can run anywhere from $50 on up. Depending on how old it is, you may find it better to just replace it with a gently used one from ebay.
Jun 04, 2009 | HP Pavilion F1503 15" LCD Flat Panel...
Acer LCD AL1716W Monitor shows lines
use 1440 x 990 resolution, the ratio of the monitor is 16:10
Dec 27, 2007 | Acer AL1715 (Black, Silver) 17" LCD...
Monitor clinks off and on(black screen)
I would start up in safe mode, and disable that driver. It sounds like it is a bad driver on your new pc. Then turn off the pc, hook up your new monitor and start up fresh. Your pc should automatically find the best compatible driver for you. If this won't do, can you please list the driver you did use? Maybe we can search for another one that would be compatible with your model monitor.
Oct 27, 2007 | HP Pavilion F1703 17" LCD Monitor
Computers & Internet Logo
50 people viewed this question
David Payne
David Payne
