Question about Jenn-Air JCD2389G Side by Side Refrigerator
JCD2389GT WATER ON FLOOR UNDER UNIT
  • 1 more comment
  • paulng0711 Aug 02, 2008
    my jcd 2389g have water on the floor for awhile now the freezer wooking but the refrigerate does not cold
  • Anonymous Aug 08, 2008
    I have the same problem. When I open the freezer door and look at the vent thing on the bottom back water pours streams out. Sometimes it's alot and once it collects it spills out onto the floor. Often it freezes around the rack and then I crack out the ice with the rack- areal pain nit to mention it's killing my floors!!!
    I've had the repair man out for other weird things like not freezing stuff they fixed that or so it seemed. Sometime it get really loud or silent and I wonder if it's working. Sometime it's tooo cold sometimes not cold. I think my warranty is out now. :( Paid good money for this one but I think it's on it's last limb!
  • trish2202 Aug 15, 2008
    I have watter leaking out from underneath my side by side. There's nothing inside, but there's quite a bit coming from underneath.
  • 943 Answers
Hi thanks for the question it would seem that the problem is with the drain hose, going to the drain pan very common problem with all fridges let the fridge thaw 24 hrs let the ice melt in the drain cavity clean after thawing make sure the hose is in the pan vac *** under neath & coils thanks the appliance doc
Posted on Sep 17, 2008
Washer bouncing while spinning
Make sure the unit is leveled and on a solid surface. You may have to brace the floor up under the washer if the floor is too flexible. To test this place a glass of water on the floor in front of the washer. if the water vibrates and ripples in the cup the floor is weak. Manufacturer's came up with this test.
Jan 22, 2014 | Dryers
JCD2389GT
WHAT IS WRONG WITH YOUR REFRIGERATOR?
small_4_1.jpg For a detailed Refrigerator illustration, click below.
redarrow.gif Side by Side
redarrow.gif Freezer on Top
redarrow.gif Freezer on Bottom
redarrow.gif Under counter
Warning!To avoid personal injury or even death, always disconnect yourappliance from its power source--that is, unplug it or break theconnection at the circuit breaker or fuse box--before you do anytroubleshooting or repair work on your appliance. Also, because somecomponents may have sharp edges, use caution while working on yourappliance.
It's stopped completely
It's not cool
Cooling is poor
It's noisy
It leaks
The freezer compartment is icing up
The food in the refrigerator freezes
There's water dripping inside the refrigerator
The refrigerator never cycles off
The ice maker has a problem
There's an ice- or water-dispensing problem
Aug 12, 2008 | Jenn-Air JCD2389G Side by Side...
Where's is the defrost drain for Jcd2389gt
Click Here=> Maytag JCD2389GTW Freezer Compartment is where you see the drain begin inside freezer and behind panel labeled location 20. The other end of defrost dran comes out below refrigerator and near condenser fan motor. How to clean a defrost drain Click HERE=> How to Fix Fridge Water Leak, Thanks Sea Breeze
Much more on this page=> Leaking Refrigerators!
May 05, 2012 | Jenn-Air JCD2389G Side by Side...
Carrier Infinity AC indoor unit in the garage is leaking water on the floor. There is no ice on the coils, The drain is not clogged. There is no water in the coil area. I turned off power to the...
It seems as though you have an unrelated water leak....
Often the water supplies are copper tubing....
Copper tubing and concrete do not get along well...
but hey it lasts till the warranty is up....
and they can't see it from their house...
heatman101
Jan 16, 2011 | Carrier 52CQ315 Air Conditioner
I have an Amana BRD18V1 or V2, bottom freezer. About every two weeks it leaks water on the floor on the right hand side and i have to defrost the bottom part to get about an inch of ice out. I trust...
I assume you mean water leaking on floor of bottom freezer? There should be a small hole in floor in back to drain defrosted water down to pan under unit. This line might be clogged with food or frozen water. Carefully pour some hot/boiling water down tube to clear. You should see it empty into pan under unit where fan evaporates it.
Jul 15, 2010 | Amana ABB1927DE Bottom Freezer...
Water on the floor under the freezer side of unit
It happens to all those old refrigerators. There is a shield separating the drip container and freezer through a small hole. Check if it is blocked. This won't do much of the work and may not be stopped even if you do something. If you can, have a new refrigerator.
Apr 21, 2010 | Amana 22.6 cu. ft. Side-By-Side...
Have Liebert DH125 down flow unit with one (1) alarm
ive worked on many liebert units therss a water sensor on the bottom of the unit basicly the units pan try to find that switch and mayb cleen under it or if it s aprob depinding on the age
Apr 08, 2010 | Heating & Cooling
Water leaking under floor when dishwasher runs
check the water to the unit it is locate under the door open the panel 2 -4 screw take flash light turn the unit on and see where the water come from ... it might be also from under your sink.
Jan 01, 2010 | Dishwashers
Water on floor under unit & ice bottom of freezer
By going online, saw several posts re this problem. In short, the water drain was clogged and there was also a problem with the defrost timer. Service man blew out the drain line with compressed air and installed a new timer. Voila! Problem fixed. Interestingly, the serviceman found a wad of what looked like putty, but was sticky like gum in the drain area. He said he had never encountered anything similar.
Aug 04, 2009 | Jenn-Air JCD2295HES Side by Side...
Water coming into refrigerator
Evelyn,
More than likely (I can't be sure from here!), your icemaker "motor module" has failed. This module controls the amount of water that goes into the ice tray. If the timer fails, the water valve can stay open. Also, if this is a new unit, or a used refrigerator you just installed, all you may need is to reset the timer on the motor module. The icemaker must be removed to do that. The tray fill time varies with the local water pressure. If your water pressure increases for some reason, the time must be shortened to avoid overfilling the tray.
Jan 17, 2009 | Rival 38651-C 6-Quart
Jenn-Air JCD2389G Side by Side Refrigerator Logo
200 people viewed this question
Top Jenn-Air Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Jenn-Air Refrigerator Expert? Answer questions, earn points and help others
