Question about Bose Companion 2 Computer Speakers
Speakers won't work
I just bought some bose companion 2 speakers for my gateway gm5626 computer and they won't produce any sound, i have it hooked up to my rca jacks on the back of my computer and still nothing
  • bonbon56 May 11, 2010
    Try plugging in a pair of headphones or other speakers and see if they produce sound.
    If they don't, then it is most likely a problem with your audio driver. In that case, find the driver, and reinstall/redownload.
    If other speakers or headphones work, try:
    • reinstalling audio drivers
    • ebooting both your computer & your speaker system
    • checking for cuts or tears in the speaker system wires
    • disconnecting all of the wires in the speaker system and then reattaching them
sodeep
  • 3267 Answers
SOURCE: Does a companion 5 bose speaker have a fuse?
You will need to change entire power supply/distribution circuit since you have managed to fry it all with twice the voltage required by the system. Speakers should be OK only the circuitry needs to be rectified and too by a professional/expert technician ...........sodeep
Posted on Mar 31, 2009
fixyathing
  • 341 Answers
SOURCE: Bose Companion 5 Speaker System won't work
check if the volume control needs to be replaced. volume controls gets bad in due time coz of the carbon layer which gets thinner and thinner till it gets cut off
Posted on Aug 12, 2009
SOURCE: Control Pod for Bose Companion 5 speaker system
I had the same problem right out of the gate, the volume dial on my control pod for my Companion 5 wasn't working, however, the touch pad and LED worked. I called Bose customer service and was instructed to:
First, unplug the power directly at the back of the woofer while the unit was on;
Next, I was instructed to unplug the control pod, visually inspect for any damage/defect;
Finally, re-seat the control pod on the back of the woofer and then lastly plug the power cable back into the woofer.
It worked like a charm. I hope this is helpful!
Posted on Jan 26, 2010
SOURCE: Bose Companion 3 series II speakers aren't producing sound (imac)
from what I've read, the imac has a 3.5mm (.138) jack while the Bose jack is 1/8 (.125). very small difference in size (.013), but enough to cause problems.
Posted on Nov 18, 2010
  • 357 Answers
SOURCE: Can I hook up the Bose Companion 2 series speakers
Well if you currently find the sound of the Bose acceptable and your inbuilt HD TV speakers poor, then the answer is yes. Should you not like the sound of the Bose, plugging them into an HD TV won't make them sound any better :-)
Just use the headphone out of your HD TV to connect. You may find you need to enable the headphone socket/volume via the menu settings on your HD TV
Posted on Jan 16, 2011
Can I hook up the Bose Companion 2 series speakers to my HDTV and get acceptable sound?
Dec 14, 2010 | Bose Companion 2 Series II Multimedia...
Problem hooking up bose speakers
mcdevito75 here, The HP speakers that came with your computer work fine, the bose speakers work fine on your other computer, the plug on the Bose speakers is a little shorter than the HP speakers, and only the right Boss speaker is working, HMM, Check the Bose speakers, both of them for a volume control 1 of them may need adjustment on this particular computer. If that"s not it, I would speak to a Radio Shack, Staples etc.
Jul 04, 2010 | Bose Companion 2 Series II Multimedia...
Would like to know how to open speaker cabiant.Bose companion 2.
currently trouble shooting Bose Companion 2 computer speakers, no sound from speaker, would like to know how to open cabinet to see if wires are attached to speaker?
May 24, 2010 | Bose Companion 2 Computer Speakers
I have the Bose companions 3 series 2 speakers feedback problem
Another possibility: make sure both speakers are at least ten inches away from any router.
Sep 16, 2009 | Bose Companion 3 Computer Speakers
Bose companion 2 speakers not working with the HP slimline
Speakers are speakers. They should not need configuring if they are funtional and powered up. The speaker out jack does not know the difference from bose to sparkamatic.
Aug 31, 2009 | Bose Companion II Computer Speakers
Crackling sound coming from speaker w/controls
are you sure this is not coming from the component and not the speakers? what head unit are you using
Jun 22, 2009 | Bose Companion 2 Series II Multimedia...
Bose Companion 3 - Is getting power but no sound
Are you using the usb cable to power the speakers?
Feb 16, 2009 | Bose Companion 3 Computer Speakers
Dec 26, 2008 | Bose Companion III Computer Speakers
Bose Companion 2 Computer Speakers Logo
526 people viewed this question
Top Bose Audio Players & Recorders Experts
jjcicala
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
