Question about Vizio L32 32 in. LCD HDTV
Hd receiver does not work now
I have an hd vizio television. Just over a year it does not have any hd channels. I already talked tech support. They are clueless. Everything is plugged the way it always was. I rechecked all connections. The screen is green. I have an antenna on my roof and could get many channels in hd. What is the problem?
Brian
  • awbean12 Jul 07, 2008
    vizio L37 no hd Tuner just blue screen not a set up problem was working for awhile
    Sergeant:
  • 280 Answers
The tuner could be the problem. If the set is plasma or LCD will determine what may be the problem. they work in very different ways. make sure that the setup is set for 16.9 then do and auto program. Don't know that this is your problem not a lot of info on the model so at best this is a guess.
Posted on Jul 07, 2008
Screen seems stretched. How do I fix it?
60'' Vizio TV screen is stretched in 'normal' screen mode on HD ...
https://answers.yahoo.com/question/index?qid...
Jul 21, 2013 - Ive had this tv for almost a year and the screen has never given me problems, but just recently all the HD channels are stretched. ... If your Vizio is like my 47" it has 4 Picture Modes - Wide, Normal, Zoom and Panoramic. ... Why isnt my viziotv able to play full screen hd channels?
TV Problem: The picture on my television is stretched out on the ...
Aug 23, 2008 - It is a High Definition Vizio TV. The center of the screen is clear, but the television stretches the image out on the sides. Is there anyway to fix ...
How to Fix the Most Annoying Features of Your New HDTV ...
Dec 31, 2015 | Vizio VA Televison & Video
We have a 4 year old Visio HD TV. Recently we had time when both the HD channels and going up and down using the channel surf buttons did not work. The low Def channels would work and entering the channel...
I don't believe that it is cost effective. BUT, if you have Comcast, you will now need a cable box to watch most channels now. I believe they stop at about channel 12 without the box. It's their way to stop cable thieves, but it's an inconvenience for the rest of us.
If this isn't the case, you might want to try to contact Vizio tech support www.vizio.com. or try to reset the TV - unplug the TV, press and hold the power button for 30 seconds, repeat. Plug it back in and see if it helped.
Apr 22, 2011 | Televison & Video
Cannot adjust picture size on vizio
If the picture size isn't changing with the television's picture size adjustment setting there could be a few things going on. Check to see that you're in the right input on the television i.e. if you are connected to a high definition receiver make sure you are not in the tv/tuner input (tv display would say analog channel 3 or 4). Make sure your tv is switched to the high definition input i.e. component 1 hdmi 1 and etc. If you are in the high definition input already check and see that your cable box or satellite tv receiver is set to the proper resolution. For example if you have a 720p television make sure the cable box is set to 720p not 1080i. Last but not least look for the hd zoom # button on the cable remote. The button may also say format or aspect.
Aug 19, 2010 | Vizio P2 42 in. HD-Ready Plasma Television
I have a VIZIO LED/LCD VF551XVT hooked up to a motorola HD DVR with a HDMI cable. When I switch from standard Def to High Def channels I lose the sound. If I turn the TV off/on the sound returns but if I...
I have the same set, same problem with one of my MOTOROLA boxes, but not with another. I have a SONY TV that works fine with this new MOTO box, but the new VIZIO does not. The audio is coming through the HDMI cable just fine, and the fact that it works when you cycle power on your TV means it's the SYNC between the TV and the BOX. I have the identical problem and am taking back the MOTO box for another one. I spoke to VIZIO for about 45 minutes trying different things. They think it's the MOTOROLA box, COX (my cable company) thinks it's this particular box, who knows.
Feb 01, 2010 | Vizio VF551XVT 55 in. HDTV
Vizio pixelation in hd nt all channels
Usually a TV that pixelates only on some channels is a problem with the signal levels coming into the TV or the cable box. If you are using a cable box then definatley the signal is the issue..
Nov 11, 2009 | Vizio VA26L 26 in. LCD HDTV
Older person cannot handle two remotes
You can program most satelite remotes to work on any device. Most are universal. If not, I suggest purchasing a universal remote. You can view remote codes online to program your device to your remote. New ones come with instrucions and codes.
Let me know how I can further assist you if necessary
Aug 18, 2009 | Vizio Gallevia GV42LF 42 in. LCD...
Vizio Model#:L37HDTV10A After unpluging the HDMI cable & reconnecting it back, I don't have no more HD picture. The Component cable & HD antena works but no HD brodcasting with HDMI connection....
Is the HDMI port 2 work? Try to turn it off and turn it back on. If it is still not working then the HDMI ports have gone bad. You will need to replace the main board.
May 11, 2009 | Vizio L37 Television
Vizio 42'' LCD having intermittent fuzzy screen on stdrd channels
you might have an overheating problem- make sure you have adequate ventilation around your tv
Nov 25, 2008 | Vizio GV42L 42 in. LCD Television
Digital channels freeze
I also had this channel 5-1 freezing problem and spoke with Vizio support a few times. They thought the problem was the SSID code from the local CBS station and said they would try talking with them. I am not certain if they did this or not, but, as of mid December, my Vizio no longer has this problem.
May 06, 2008 | Vizio GV42L 42 in. LCD Television
Philips 32pt television screen format off center, to the left
For me it was the cable box settings...
I'm not a tech person, so take this for what its worth. I had the same problem with my Vizio and my Time Warner Cable HD/DVR box using the HDMI cord connection. HD channels were always fine, and non HD channels were fine until I went to an HD channel and back. When switching back, the non-HD channels would be shifted to the left as you describe. After much back and forth with both Vizio and Time Warner (each saying its caused by the other), I stumbled across the following fix...
I went into the cable box (scientific atlanta 8300) "settings", under "display," under "output resolution." There was a list including 480i, 480p, 720p, 1080i, and "auto select." I unchecked both 480 options and left 720 and 1080 checked. Problem solved. The other "Display" menu settings are as follows: Picture Size = Stretch, Aspect Ratio = 16x9.
Hope this helps.
Mar 27, 2008 | InFocus SC-MANGRY-106H MANUAL PULL DOWN
Vizio L32 32 in. LCD HDTV Logo
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
