Question about Kodak EASYSHARE CD33 & Printer Dock Series 3 (Pack) Digital Camera
Kodak EasyShare Printer Dock Series 3
My printer will only print half of the picture, the bottom half. I changed the paper and the cartridge and it still doesn't print but half the picture.
Please advise how to fix.
Thanks, Pat
  • Anonymous Feb 02, 2009
    I have the exact same problem, and also tried to change the cartridge and paper. I also went to the Kodak website and did not get any solution.
  • schwarhm May 02, 2009
    I was able to take the printer apart but I couldn't figure out what platic lever everyone is talking about repairing that's connected to the shaft.
  • 31 Answers
If the boundary between the blank half and the printed half is a sharp line, a wire to the print head may be broken or disconnected. If the boundary is irregular (wanders up and down an 1/8 inch or so), the problem is most likely a broken plastic lever on the end of the shaft that moves the print head. The plastic lever is keyed to the shaft by a flat on the shaft. The plastic has a tendency to split at the edge of the flat, resulting in the lever slipping on the shaft. This in turn results in one side of the print head not contacting the paper with sufficient pressure. The other end of the shaft has a thick plastic sector gear which is much less likely to break.
I fixed mine by making a clamp from a metal spacer (made from split tube about 1/8 inch long) and force fitting it over the part of the plastic lever that fits on the metal shaft (on the end towards the inside of the unit). There is just enough clearance to do this without hitting the print head frame.
To remove the plastic lever, first remove two screws from back of unit, then pull up on top of unit, unplug two ribbon cables from circuit board and remove top. Then unplug two remaining ribbon cables from circuit board, and three screws holding circuit board. Lift circuit board and fan/fan-holder as one piece. Finally, disengage tab on plastic retainer on end of metal shaft, rotate tab straight up and lift shaft up and to the side (may require a little wiggling). The plastic lever slides off the metal shaft.
Posted on Mar 20, 2009
Printouts are missing top/bottom half of picture. Tried replacing cartridge and/or paper but to no avail.
make sure on your program that you are using to print your pictures, that you have the correct photo size. You could have it set for like a 4X6 for an example, where you might need a 5X7
Apr 18, 2011 | Kodak EasyShare Printer Dock Series 3
Printing Issue
It has dust or built-up goo on the feed switch. Try some canned air
Jun 11, 2010 | Kodak EasyShare Printer Dock Series 3
Kodak Easyshare Printer dock series 3 not printing full picture
throw out your printer and buy another brand. if you call18002356325 the call goes to manila and chances are you will be talking to some one who only speaks partial english and knows nothing about kodak products but will read to you from these internet instuctions that you just read !!! kodak has become a very anti-american company in so many ways!!!
Aug 04, 2009 | Kodak EASYSHARE Plus Series 3 Thermal...
Kodak easyshare printer dock 3 prints only the bottom half ?
maybe the settings are set to print a picture on paper that's twice as big as the paper you'r eusing? like, if the settings are set for 8x10 paper and you're using 4x5...
that's just my guess.
Aug 04, 2009 | Kodak EasyShare Color Photo Printer Dock
Picture only prints on one half of page
Try printing a testpage just press print + cancel and make sure you have a paper loaded
Nov 15, 2008 | Kodak EasyShare Thermal Photo Printer
Kodak EASYSHARE Printer Dock
Well it's not looking to pomising by reading all of the other people who are having the same problem. But could you please tell me how to fix my printer in is only printing half of my pictures no matter how many times i reprint them and it also doesn't pick up the printing paper very well i have to help it along. So if you could PLEASE tell me how to fix this problem on my own it would be greatly appreciated. Please respond As Soon As Possible Please and Thank You. I have the Kodak Easy Share Printer Dock Series 3.
Patricia Davis
Nov 03, 2008 | Kodak EASYSHARE Printer Dock Thermal Photo
Only half of picture is printing
I have the same problem where only the bottom half of my photo prints. It worked fine for a long time. I even tried flashing the printer up to the 2.11 firmware version from 1.90 - still nothing. Changed paper and cartridge. NOTHING. Tried attaching it to both my PC & MAC and even print stand alone picture from camera and a SD memory card on the side. NOTHING.
I think the problem is with Kodak... My trouble started when I decided to move my Dock Printer from PC over to MAC. The new drivers have you flash the Firmware. To do this, you first must hold down the Print and Red EYe Button (The button directly to the right of the big print button) with the power cord unplugged and then plug it in holding the buttons in for 2 seconds afterward.
This put the printer into Edit mode and allows the firmware to upgrade the printer. Once I did that, THAT'S when my problem started. I think these crappy printers can NOT self calibrate and they must be factory set. Most likely, they need to do it at the factory themselves and are all to happy to charge you to ship it off and do it for you.
THANKS KODAK!
What a POS.
Mar 20, 2008 | Kodak EASYSHARE Printer Dock Thermal Photo
Cameras Logo
1,019 people viewed this question
Top Kodak Cameras Experts
Tony
Are you a Kodak Camera Expert? Answer questions, earn points and help others
