Question about Dryers
Dryer will not start.
Dryer will not come on. When you push the control knob in to start it
there is a buzzing noise coming from it but it will not start.
    Novelist:
  • 161 Answers
Usually a motor problem or a switch on the motor. The switch is not usually available seperately. Putting a new motor in is not always worth it as it can cost as much as $175
Posted on Jun 29, 2008
When I push the "Start" button there is a buzzing
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Jun 15, 2011 | Fisher and Paykel DE06 Electric Dryer
I have a maytag dryer that will not start. When I push the start knob, I get a buzzing noise that sounds like there is something wrong electrically behind the control panel. I took off the panel in the...
http://allrepairmanuals.com/maytag-dryer.htm?model_number=MDE308DAYW
Hi, what you describe indeed sounds very bad, and should be looked into asap, to do this yourself you will need a service and repair manual, accordingly i have provided a link above for you to obtain one.
You will need to be very careful, as with any electrical fault, the service manual has troubleshooting steps for you to follow so you can isolate and repair your problem.
Buzzing noises usually have to do with the motor, or gears belt etc.
Also to help below is a DIY website that will help you also
.http://www.acmehowto.com/howto/appliance/dryergoe.php
Feb 01, 2011 | Maytag MDE308DAYW Electric Dryer
I turn the start knob and it just makes a buzzing sound
heatman101
Jun 06, 2010 | GE DBSR453EBWW Electric Dryer
When pushing dryer start button, a slight buzz is
the noise is coming from the motor,if you can spin the drum by hand and it moves freely you have a bad motor and need to change it out,next time send model number and the brand name of dryer,if it doesn't spin,the belt could be jammed up or something stuck in the blower wheel,let me know how you make out
May 13, 2010 | Dryers
Dryer turns on runs awhile shuts off push knob again & buzz noise at motor push again & no noise or no dryer on , wait couple hrs. push knob, cycle starts over same result
the motor is defective starts runs overheats and kicks out on safety when it cool u can try again
i would check for something restricting the movement of the drumm as well a bad berring on rollers or broken or worn glides something in the blower area could give thge same results
try to open the door see if u can turn the drum freely
if u cant ( a compleate tear down is required to check for obstructions or worn parts if none found the motor ir the problem this should be done unplugged and buy a qualified repair man
(solv ya prob)
Oct 17, 2009 | Maytag Dryers
Buzzing noise when i turn the timer switch
heatman101
Oct 06, 2009 | Bosch Nexxt WTMC 3300 Electric Dryer
Whirlpool dryer makes a buzz noise when push
pull motor switch out(the one with wires go in motor) best use compressed air.... lint is stopping lever... this all happens after you turn breakers off...hi hi
Aug 27, 2009 | Whirlpool ET8CHEXSQ Dryer
My dryer makes a buzzing noise when I push the start button
My Hotpoint dryer is seven years old and did the exact same thing. When I got over the anger and the thought of spending 4 or 5 hundred dollars to replace it I started messing with it. I finally decided that since it buzzed when I tried to start it there was current there. The only other thing it could be was the drying cycle knob.
I held the start knob and let it buzz while I slowly turned the dryer cycle knob to the right. As I turned through each cycle it would hit "off" and the buzzing would stop and then resume as I moved past the "off " setting. On the third trip around the dryer "started" and has been working since. Maybe something got out of kilter. Apparently the problem was in the knob that controls the drying cycles.
Mar 24, 2009 | Hotpoint NVL333EY Electric Dryer
Hot Point Dryer does not come on but you can hear the noise by the start knob like a low buzz
Feel the outer cover at rear of the dryer at the bottom,if it starts to feel warm then the heater is working, the buzzing noise could be the motor trying to start, or noise from the relay, if the heater does not come on then could be timer faulty or faulty start relay. It is a a process of elmination.
Dec 09, 2008 | Hotpoint TDC32 Electric Dryer
Dryers Logo
Top Dryers Experts
