My Canon Pixma MP130 skips a line during document printing so alternating half is blank. I have replaced both ink tanks thinking it was the problem but it did not solve it. I used the deep cleaning but still did not fix the issue. During copy mode, the second line appeared to be distorted. Thanks for the help. Respectfully, Roger Sabatchi
SOURCE: canon IP400
paper will not load
Posted on Jan 11, 2008
SOURCE: Canon Pixma MP 800 printing Issue (heavy black line on opposite side of print page
I have exactly the same problem with a Canon Pixma MP800, I have cleaned the rollers, changed the ink cartridges and reset the printer. It will print a few pages cleanly then dump black ink on the roller which leaves a heavy black line on the back of the page. It fades away after printing about 10 pages and then a few pages later appears again. The printer is two years old and it looks as if I must buy another. Should I buy another Canon?
Posted on Jun 03, 2008
SOURCE: Canon PIXMA iP4000 Will not print red Deep clean won t work Other colors OK
remove print head assembly. clean off.
print head not on cartridge.
Posted on Jun 21, 2008
  • 26 Answers
SOURCE: how to scan documents then email them
To scan and send the documents via. e-mail. First of all you must run the setup from the cannon cd (comes with printer), use full installation (recommended option) complete the installation.
If this is already done then :-
1] Put the document that you want to scan in the scanner,
2]Open "control panel" and open "scanners and cameras" folder. (switch to classic view if needed)
3]Switch on the printer (if it's on only then proceed to next step)
4]You will see your scanner icon (if necessary refresh the screen)
5]Open it and click "next"
6] (OPTIONAL) Select scan image type.
7]Click "next".
8]Choose a place to save your image.(default is my pictures)
9]Click "next"
10]and now image scan starts, at last click on finished.
11]Now open your e-mail account, choose "compose mail" fill in the details
12]now select "browse" (for gmail) or select upload file
13]select the address of the image where you saved it (default my pictures)
14]click ok.(you can only upload 1 file at a time)
15]send the mail. !!
16]Thus, you can send image by scanning like as stated above .
Posted on Jan 07, 2009
SOURCE: Improper printing
I cannot install the set up program in my computer because I am using Window Vista
Posted on Feb 22, 2009
Why does canon 860 pixma printer have 2 black ink tanks? only one seems to be used,
The big black tank is pigment based ink used mainly for printing text documents and copies and the smaller black is dye based ink used along with the color inks during photo printing.
Dec 30, 2009 | Canon PIXMA MX850 Multifunction Printer
No colored printing ???
Check if you have enough color ink. take the ink cartridge and shake it.
Look for any black dusk or small pieces of paper inside. You might use a hoover carefully.
other solution:
Uninstall the printer driver and re-install it again. make sure you start the PC after the Uninstall.
hope it helped
Aug 27, 2009 | Canon PIXMA MP130 All-In-One InkJet...
Canon PIXMA MP130 printing blank pages & cartridge jammed message
Hi You can Try
Error Code 5100 Yes see lots of this errors
Solution 1:
Clean the timing strip.
Solution 2:
The purge cap (the white sliding mechanism that the print head parks to when it's not in use) may be not lubricated well enough .
Lubricate the sliders with some white grease (don't get it on the small wipers or the black caps); this repair probably require to remove the right panel off of the printer to gain access to the purge mechanism.
All The Best: Pineworks
Mar 11, 2009 | Canon PIXMA MP130 All-In-One InkJet...
Canon PIXMA MP130 "check ink tank" message
Have you put in new ink cartridges? It may be all you need.
Nov 05, 2008 | Canon PIXMA MP130 All-In-One InkJet...
Full ink cartriges print a few lines and skip a few lines
well..did you run a test page?
or clean the print heads?
or recalibrate them?
recommend all these steps for you
and as my 2200th solution, you are entitled to a FREE tuneup for good. find out more about that service here
Mar 23, 2008 | Canon PIXMA iP90 Mobile Printer
Confirm that the ink tanks are installed properly When replacing the ink tanks, confirm that the new ink tanks are installed properly. (See the illustration below this paragraph for ink tanks recommended for this model.) If the ink tanks are not locked into place, paper may not be fed properly, or ink may not be supplied to the print head. sj402022.jpg
Ink Tanks:
- BCI-24 Color
- BCI-24 Black
  1. Make sure the power is turned on.
  2. Lift the Scan Unit until it locks into place (1). The Print Head Holder moves to the center.
  3. Open the Paper Output Tray (2).
  4. Open the Inner Cover.
  5. Check if the ink tanks are installed properly.
    Ink tanks installed correctly
    Ink tanks installed incorrectly
  6. When installing the ink tanks, push the top of the ink tank until a click sound is made.
    Note: If the ink tanks are not installed properly, paper may not be fed properly, or ink may not be ejected.
  7. Close the Inner Cover.
    CAUTION: Press the center of the Inner Cover until the cover locks into place.
  8. Return the Scan Unit to its original position. The LCD displays a message asking if you replaced an ink tank.
  9. Press [+] to select [NO] and exit.
Jan 09, 2008 | Canon PIXMA MP130 All-In-One InkJet...
I have blank lines through my printouts
Run the cleaning cycle. If that doesn't work, try to use an alcohol soaked swab on the print head. Some of the jets are clogged.
Oct 27, 2007 | Canon PIXMA MP130 All-In-One InkJet...
