FixYa.com
Tags:
LG WM-2277HW Front Load Washer
Model WM2277HW leaks (by 3 users)
posted by jtyre93 on Jun 27, 2008
My washer leaks out the back and on to the floor. I have already cleaned the filter locate at the front of the unit. Is there a filter located at the back of the machine. My wife spoke to a technician at LG and they said there was. If there is one I do not no where it is.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
2 Other Users Have The Same Problem
Comment by redgreen_fan, posted on Aug 04, 2008
Water just gushes out from under the washer, same model. I've got a service person coming but I don't give it much hope. I have gone through 4 washing machines in 4 years, WP, Maytag, and LG. None are worth a d*mn. I'm thinking about giving up and just going to the laundry mat.
Comment by Guest, posted on Jul 30, 2008
leaks from the bottom of the washer
Clarification Request
by gwol, posted on Jul 28, 2008
Could you please describe the amount and location of the leak in a little more detail?
Solution #1
posted on Aug 05, 2008
Not Rated (0)
gwol
Rank:Guru Guru
Rating: 92%, 164 votes
Leaks from the bottom of the machine are usually related to a sump issue.
You will have to remove the rear panel from your machine to see leak happening. Do not reach into the back of the machine while it is powered if possible. Be extremely careful.
The rear panel is held on by 4 screws, with these removed the panel will pull away from the back of the machine.
With great care you will need to start the machine to observe where the leak is coming from.
At the very bottom of the machine is a black rubber tube that attaches to the bottom of the tub. It splits and goes forward towards the drain pump & filter unit and it also goes towards the back of the machine and attaches to a white air chamber which connects to the fill switch via a long black rubber tube.
Leaks will usually occur in the rubber sump hose; at the air chamber; at the pump connection or pump; or in the drain hose. Careful inspection of these points should reveal its location.
Leaks coming from the tub area can either be a center tub seal or from the inlet water at the top of the machine traveling down along the tub.
Further clarification of the leak location is needed for further diagnosis
Was this solution helpful? Show your Appreciation by rating it:
Can you Help with these Washing Machines problems?
Washing Machines
Washing machine Hoover AM120...
whatever program I use, machine... Answer This...
how to access intenet through...
sir i hav purchased lg mobile... Answer This...
"service unavailable"...
I have a full complement of... Answer This...
Would like to hear more about...
I was wondering if you could... Answer This...
Thank you
Wolfster- Thanks for providing... Answer This...
Repair Service
Find Washing Machine Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
