Question about Fisher and Paykel Dishwashers
Have Fisher&Paykel model DD603. Top washer will not close. Partial water in unit. Will not turn on . Is there a service tech in 13815 area?
  • kmcampbell Jun 27, 2008
    Bottom washer working fine.
    Genius:
  • 3,422 Answers
Yes,
Here are the details:
(231)242-1190
www.ikenfixit.co
m
Posted on Jun 27, 2008
  • Priya darshan Jun 27, 2008
    Here is another one:
    (606)657-0351
    www.kwn-inc.com
    Please don't forget to accept the solution.
  • 58 Answers
Yes there is
  • adham said
    adham said Jun 27, 2008
    (231)242-1190
    (606)657-0351 don't for get the rating :-)
Fisher and paykel dd603
Flood switch is at the very bottom underneath the bottom draw in the base floor.Unplug cord.Open bottom draw all the way & squeeze a towel or sponge under the draw & soak up the water..The washer should work now..Why did it flood in first place?
Check that dishes are not stacked higher than top edge of the draw otherwise it can't seal.this can happen when children are asked to stack the dishwasher.Another cause is some models the seal is an inflatable tube that seals the top edge of the draws,it gets cut or sliced buy a plate that was stacked to high when you closed the draw.there should be no clunk of dished hitting when the draw is closed.
May 30, 2010 | Fisher and Paykel 23 in. DD-603 Built-in...
My dishwasher is model DD603 and it turns on by
There is a water leak in the bottom housing and a leak sensor detects to give a F1. Pull out the tube and put your hand in the front from the left ( only on this side has enough room to access) with the small towel to dry out the water on the bottom housing. After dry out, unplug the power for at least 24 hours so the sensor can be dried out and reset. However, make sure to fix the leak from the top seal, otherwise, it keep happening.
Oct 10, 2009 | Fisher and Paykel 24 in. DD603H W Built-in...
Continuous beeping and lock is intermittentyl showing on DD603, have tried turning off power, holding in lock button, turning off for 10 mins etc. CAnt stop it and driving us insane!! Can anyone hlpe us...
you need to Call the Fisher & Paykel customer service line and tell them that your Unit is Experience a Power Malfunction Usually its related to water leaking.
Aug 02, 2009 | Fisher and Paykel 24 in. DD603H W Built-in...
I need to repalce the elctrical supply cord and water supply line to my Fisher & Paykel DD603 dishwasher, but I'm unsure as to how to remove the terminal box cover. Could you please help? Thanks.
THIS IS SIMALAR TO THE BOSCH UNIT, IF THERE IS NO BOTTOM COVER TO REMOVE YOU NEED TO TAKE THE SCREWS OUT OR THE TOP INSIDE THAT HOLD IT TO THE COUNTER TOP, PULL THE UNIT OUT SLOWLY, TURN OFF THE WATER SUPPLY SHOULD COME OFF THE HOT SIDE OF YOUR FEED LINE TO THE FAUCET UNDER THE KIT SINK, THE WATER SUPPLY IS ON THE LEFT LOOKING AT IT AND THE ELECTRIC IS ON THE RIGHT IF YOU CAN PULL IT OUT ABOUT 8 INCHES YOU CAN GET TO BOTH CONNECTIONS TO BE ABLE TO DISCONNET PULL OUT ALL THE WAY GET BEHIND IT AND CHANGE WHAT EVER YOU NEED TO
May 29, 2009 | Fisher and Paykel 23 in. DD-603 Built-in...
E-mail for Fisher Paykel DD603 manual
Josh, you will need to have a Tech out to look at it... F/P will not sell you parts to repair it. The F1 indicates that the flood switch has been tripped. There are many possible causes for this but probably the upper drawer link support has broken and is getting stuck between the lid and the drawer in which case you will need a new lid and link support.
May 05, 2009 | Fisher and Paykel 23 in. DD-603 Built-in...
Fisher and Paykel DD603 service manual
Check to see if the Child lock is on...Check your email
Aug 28, 2008 | Fisher and Paykel 23 in. DD-603SS Built-in...
Fisher Paykel DD603
The top drawer on our DD603 top lid doesn't seal allowing water to spray out and down the sides.
Aug 10, 2008 | Fisher and Paykel 23 in. DD-603SS Built-in...
Dishwashers Logo
83 people viewed this question
Top Fisher and Paykel Dishwashers Experts
Brian Coughlan
Owen Barnes
Are you a Fisher and Paykel Dishwasher Expert? Answer questions, earn points and help others
