Question about Kicker Car Audio & Video
MY KICKER IMPULSE 2252XI BLOWS fuses. - Kicker Car Audio & Video
3 Suggested Answers
  • 18 Answers
SOURCE: kicker impulse 254 amp red light on top?
1st check all of your wiring, make sure the remote wire is hooked up, check to see it the RCA's are hooked up. I know this sounds stupid, but i've done it a thousand times, check to see if you hooked up the speakers. If you checked all of those and still nothing, double check your ground. Make sure where you have it grounded, you have all the paint sanded away and its a good grounding point. The red light on the top of the amp, its not a protection light is it??
Posted on Apr 03, 2010
  • 13 Answers
SOURCE: I have a kicker impulse ix702 that keeps blowing
Take a volt meter, put it on continuity, cross it between the battery and ground term. on the amp and make sure you get no buzz, now cross it with the remote term. and make sure no buzz. Make sure the only thing hooked up is the battery and ground then take a wire and cross it between the battery input and the rem. to turn it on and see if it blows. Make sure all other cables are removed.
Posted on Sep 08, 2011
Kicker amp 350.4 blows fuses
Check your wiring for any exposed. Make sure there are no wires touching and that you have the proper gauge wiring for that size amp. I used 4 gauge with that same amp and never had an issue.
May 20, 2016 | Kicker ZX-350.4 Car Audio Amplifier
06 kicker zx750.1 fuses melted opened amp and 2 capacitors blown
Better off getting it repaired through kicker.....Most of the time you cant find parts for their amps online or anything. Was the amp 2 ohm stable????? Is it still under warranty????
Mar 17, 2012 | Kicker 06ZX750.1 Car Audio Amplifier
I have a kicker impulse ix702 that keeps blowing its fuse when I turn it on.
Sep 04, 2011 | Kicker Car Audio & Video
Amp getting hot sound distorted fuses blown wires not touching
make sure that you have installed a wire fuse inbetween your battery and your amplifier that is the most common reason for blown fuses. without that extra fuse your amp is getting a non limited amount of power from the battery.
Jun 02, 2010 | Kicker IX702 Car Audio Amplifier
Kicker impulse 254 amp red light on top?
Apr 03, 2010 | Car Audio & Video
Multible amp wiring
Its always a better idea to use a distribution block when splitting your power source to multiple amplifiers-but you asked if it would work not what a good idea is -so to answer you yes it will work -im not recommending it but sometimes ya gotta do what ya gotta do
May 22, 2009 | Kicker CVR12 Car Subwoofer
No power
If your grounding isn't good enough you won't get enough power. Make sure you've sanded and scratched the area thoroughly and it's touching the chasis of the car.
Apr 11, 2009 | A D S Car Audio & Video
Schematic
Try manualsparadise.com or go to the Kenwood web site and look in the support section.
Dec 18, 2007 | Kenwood KAC-848 Car Audio Amplifier
Car Audio & Video Logo
327 people viewed this question
Top Kicker Car Audio & Video Experts
Tygh Duval
Tygh Duval
hoyzee1
Are you a Kicker Car Audio and Video Expert? Answer questions, earn points and help others
