Question about Sharp Microwave Ovens
Microwave simply quite - Sharp Microwave Ovens
  • William Miller
    William Miller May 11, 2010
    Please reply back with your brand and model number as well as more specific details of your trouble so we can help you.
The plate you put your food upon will not turn round in my Convection microwave which is 20 months old. It tries at times and gives a clicking sound. Can you please give me some solution and how come we dont get 2 years warranty as do other makes.
We can find no Sharp repairers where we live.
Posted on Jun 30, 2008
Cannot turn on the microwave oven. Getting E-10
E-10 = Control Board fault
This is usually associated to the main control circuit board. When this develops a fault it will quite simply disable the microwave. It can however be triggered by other less serious faults, for example the door switch can produce an E-10 error although this is rare. If it simply is not powering up then it is more than likely the main control board and needs to go to an LG repair centre to be properly repaired.
Hope this helps
Jul 15, 2011 | LG 1.2 Cu. Ft. Mid-Size Microwave -...
It sounds like you wer a victime of a power surge from the gride, ther ar protectors in the microwave called MOV's they simply short/explode thus blowing the maine fuse when the voltage goes to high, if your lucky take it to a good tech. the MOV's can be replaced and if they did what they wer desing to do the microwave should start up again...
Good luck
Jan 04, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker suddenly quits during cooking cycle and sometimes displays a PF ... other times simply no display
If it only runs a few seconds then fails, see this FixYa solution. even if your model number is different.
Otherwise, I would suspect the cooling fan may be failing or there is a bad connection.
Dec 31, 2010 | Microwave Ovens
The Panasonic microwave oven seems to work for a few seconds and then quits. I opened the unit and found the leads to the door activited swich was over heating and the plastic part holding the leads...
The reason is either a poor crimped connection, poor contact on the switch or a poor switch contact.
Replace the microswitch and put a fresh 'lucar' connector on the cable.
Hope that helps.
Dec 10, 2010 | Panasonic NN-P794SF Microwave Oven
Our microwave quit HEATING this morning. What can
Could be the magnatron/thermal cut out seek pro advice
Apr 01, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Micro wave simply quit. How an I check to see if
The fuse is located inside the microwave. You will need to remove the front panel to get to it. It will be located on the black power wire inside the microwave and installed inline. Make sure that the microwwave is unplugged before removing the front panel. Once you locate the fuse inside you will need to remove it and test it with a continuity tester to see if it is blown. If it is make sure you replace the fuse with the same amp rating you found. If the new fuse blows again then there is an electrical short somewhere inside the microwave.
Dec 24, 2009 | Emerson MW8778 Microwave Oven
CDA CM3SS fitted everythiong works except the
There are two possibilities. Either the magnetron and its accompanying transformer has failed or it could simply be the fuse that feeds the magnetron. This should be checked by someone that is familiar with the correct servicing techniques as there are some very high power components in this area that can be quite dangerous. But if it is just the 'high tension' fuse then at least the bill wont be too high !
Jul 04, 2009 | CDA Microwave Ovens
The microwave starts by itself and runs.
HI.although this is quite unusual, it can happen at times when the touch control becomes faulty. simply replacing the Touch control will fix this issue.
Touch control will run about $56.00
May 31, 2009 | Electrolux Microwave Ovens
Microwave Ovens Logo
52 people viewed this question
Top Sharp Microwave Ovens Experts
William Miller
William Miller
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
