Question about Canon PowerShot S500 IXUS 500 Digital Camera
Lens not opening
When i press to power my cannon the green light comes on then the screen comes on but it shows dark and it makes a funny noise like trying to open lens and it powers off
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Canon Master
  • 102,366 Answers
  • 76 Answers
SOURCE: The lens and remains open and zoomed, but will not
sounds like the battery isnt given it enough umphs to turn it on and off. try going into the compartment and pull up the spring alittle to make better connection on the battery terminal. or it could be the motor to the camera is wearing out and needs replacing. the beeping sounds like the battery issue tho.
Posted on Nov 28, 2009
t00nz
  • 4738 Answers
SOURCE: my cannon is showing a black screen in the camera
Your correct in your assumption. A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open).
To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help:
Posted on Feb 14, 2010
  • 11967 Answers
SOURCE: lens is projected out fully and stuck, clicking
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Aug 12, 2010
t00nz
  • 4738 Answers
SOURCE: My cannon powershot SD1100 IS
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ... Unfortunately, many cameras that fall prey to this can only be corrected by professional repair. But, here are some things that you can do that may correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty, they're worth a try.
Posted on Feb 27, 2011
  • 11 Answers
SOURCE: '"The lens of my cannon
This is basically the infamous Canon "E18" error, which has been around for quite a while.
I would type out my own suggestions but since it's such a common error I'll just direct you to a nice long list of solutions already compiled elsewhere: http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Posted on Mar 01, 2011
When I try to turn on camera it makes funny noises, the lens tries to come out and open but seems to be stuck, after a couple of attempts it stops and turns off, What can i do
My Olympus Camera when switched on the lens comes out and in 4-6 times then it goes off without the LCD screen showing anything, please help me repair it. my address misiani_bon@yahoo.com
Aug 24, 2009 | Olympus FE-280 Digital Camera
SD550 camera not focusing correctly. Green focus square sometimes shows up, sometimes not, either way, it's not clear even on the digital screen prior to taking the shot. Camera does make a slight click...
to make the green square show up just press the shutter button until half (this is called the half press) when the green square shows up then it means that the camera has focused already, if not repeat the process til green square comes out you can press the shutter button fully to take picture when you see the green square...
Jul 06, 2009 | Canon PowerShot SD550 / IXUS 750 Digital...
Green light flashes but funny noise comes up and no picture comes
there are two possible problem that you may have. First, your main board may be defective (this is the cheaper of two evil) and second your sustainer boards (these are the two boards on the sides of the TV use to power up the screen). you can get parts from vizparts.com or vancebaldwin.com if you want to do it yourself. If you're not familiar with it, you can call ITI at 888-248-2708 and they could have a couple of techs go to your home and do it for you.
Jun 16, 2009 | V, Inc. Vizio P50HD Plasma Television
Lens will not retract. orange and green lights come on, but preview screen remains dark and lens will not retract when I trun it off.
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try:
May 02, 2009 | Cameras
My camera worked fine one day, then it was in my purse. When I went to use it the light was on and the screen said there was a lens error. Everytime I try to turn it on now it makes a grinding noise and...
Hope you purchased an extended warranty. I've had two Cannon's with the dreaded lens error. Probably what happened was that while it was in your purse, somehow the power button got pressed. The camera powered up, tried to extend the lens, then stripped the gears or broke whatever mechanism extends the lens. The sad part is that if it's not under warranty, it probably not worth dumping $100.00 + into fixing it. Too bad, it's a nice 8mp camera with some pretty good reviews. I feel your pain.
Feb 22, 2009 | Nikon COOLPIX S200 Digital Camera
Optio M20 Camera: Press on/off button to power up camera, the camera opens the lens cover, turns on a red led inside the lens, cycles the lens out and back in,then makes about 5 little popping noises. The...
i got it!!! on my cam i hold down the menu button at the same time power on, it will showup a " ver 1.00" and lens move a little maybe u have to do it 2 times but second time it should work
Mar 29, 2008 | Pentax Optio M20 Digital Camera
Les extended, screen remains black
tuen on camera then press display a few times. it sounds like the display is just turned off. the lens system should be open.
Jan 03, 2008 | Pentax Optio S50 Digital Camera
Digital camera
The following blog outlines some repair options for a lens error. They won't work for all cases, but they're worth a try:
Dec 28, 2007 | Cameras
Lens stuck out; camera won't stay on
I have the same problem. Its actually because the On/Off button got pushed in somehow and its stuck. At this time right now, im not sure how to make it unstuck, but sometimes it will stay on. But when you push on, since its being held down, its stuck that way and immediately turns off because its still being held down constantly. Maybe try using a thing needle to try and push it out?
Nov 13, 2007 | Kodak EasyShare M853 Digital Camera
Canon PowerShot S500 IXUS 500 Digital Camera Logo
42 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
