Question about Whirlpool Washing Machines
The spin cycle doesn't work. Someone recommended that we try looking at the button you push when you close the washer, that makes it stop when you open it. Any other ideas? What else could the problem potentially be? We're trying to figure out if this is a fix-it-yourself job or one for a professional.
  • 481 Answers
This problem is almost always the lid switch. it is something that a diy person can do. unplug the machine and locate the switch and follow the 2 wires to a plug (under the control panel usually).  if you want you can cut the wires and wirer-nut them together to test it. new switch +-$30
2 screws hold the lid switch to the case.
Posted on Jun 28, 2008
Motor won't turn on Samsung VRT Plus WF433B*GJ**
When washing heavily soiled loads, do not overload your washer in order to assure good cleaning results.
To add a forgotten item:
1. Press the Power button.
2. Press the Start/Pause
3. Wait for the door lock light to go out (Immediately).
4. Add the item, close the door, and press the Start/Pause
The door safety state continues for 15 seconds and the cycle is restarted.
ensure thorough cleaning,
To
Try washing bedding, towels, undergarments,
contact using the ActivFresh
GETTING STARTED
1. Load your washer.
2. Close the door.
Z_
Push the laundry into the drum completely to prevent the laundry from being caught in the door or
....... from falling out of the drum.
3. Press the Power button.
4. Add detergent and additives to the dispenser (page 20-21).
5. Select the appropriate cycle and options for the load (page 14-16).
6. Press the Start/Pause
7. The Wash Indicator light will illuminate.
8. The estimated cycle time will appear in the display.
The time may fluctuate to better indicate the time remaining in the cycle.
The actual time required for a cycle may differ from the estimated time in the display depending on the
water pressure, water temperature, detergent, and laundry.
9. Before your washer starts to fill, it will make a series of clicking noises to check the door lock and do a
quick drain.
When the cycle is complete, the door lock light will go out and "End" will appear in the display.
DO NOT attempt to open the door until the door lock light is off. To add a forgotten item, see
"Loading your washer" section (page 13).
When your washer is restarted after a pause, expect a delay of up to 15 seconds before the cycle
continues.
Pressing Power button cancels the cycle and stops your washer.
The pre wash, wash, rinse and spin indicator lights will illuminate during those portions of the cycle
Nov 28, 2013 | Samsung 4.3 cu. ft. VRT Plus , Steam and...
Spin cycle doesn't work
bad drain pump or clogged drain line. some units have drain trap you can clean,if so you can clean it out yourself but will make a huge mess if you don't pinch close the drain hose between the tub and pump.
Nov 12, 2011 | Haier HLP21N Washer
I have a Kenmore washing machine: Model 110 20722990. When it gets to the final spin cycle sometimes it works sometimes it doesn't. You can hear it going but the agitator is not moving and it does...
ok first, i need you to do a little test,,,put unit on final spin ,does it spin at this time ,,yes so pick the lid up every so lightly ,,did it stop ...put the unit in final spin again unit does not spin push down on unit lid and it spins..in both cases you have a bad lid switch.,,the part # is 3949238 the picture is how it look,,if you need help installing just repost...good luckonthejob5130_1.png
Sep 09, 2011 | Kenmore 24032\24036 Top Load Washer
F27 came up nearing the end of the spin cycle and just stops after it's spun but doesn't finish and release.
Close the washer and press the START/PAUSE/Cancel button to remove error displayed and restart the cycle. If it doesn't work, it means that the valve at the water entry needs to be replaced..
Hope this helps..
Jun 10, 2011 | Siemens WFXD8400UC Front Load Washer
Loses power in spin cycle
First lid must be down before washer start spinning. Remove any obstructions in drain hose and or straighten drain hose to remove kinks. Lid or other object hit timer knob and turned the washer off - Make sure the Timer knob is pulled out.
If the lid was opened with too much force when adding clothes, it may have hit the timer knob, pushing the knob in.
If a laundry basket or other object hit the Timer knob, the Timer knob may have been pushed in shutting the washer off.
Washer lid is not locked (Not on All Washers) - The lid must be closed and locked for the washer to operate. Once the lid is closed, make sure the desired cycle is still selected and then press the Start button and listen for the lid to lock.
Make sure there are no loose metal objects such as coins and paper clips in the lid opening area. Metal objects can prevent magnetic switches from reacting correctly when the lid is closed.
If the washer has not drained, it will not go into spin.
Use a flashlight to inspect the holes in tub for foreign objects like screws, nails, bra wires, etc. and remove if present.
Apr 03, 2010 | Kenmore HE2 Plus Front Load Washer
Washer won't spin
Raise the lid and look for a protruding tab along the edge that lines up with a slot when you close the lid. This tab actuates a safety switch that signals the washer that the "lid is closed" so it's okay to spin. If this tab is broken the switch never gets closed so the washer thinks the lid is up and will not spin for fear of someone attempting to add or remove an article of clothing and being hurt. The washer will fill with water and agitate, it will not make it through the spin cycle, however. When you find the slot, you can depress the switch with a small screwdriver and see if the spin cycle works.
Nick
Dec 27, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Washer will not drain
FYI: The lid must be closed for spin on older washer. It must be closed for wash and spin on newer ones. The lid has a striker in it that pushes against the lid switch arm. This switch allows for spin IF the lid is closed. The switch may have failed. Mechanically the striker may be broken or the actuator arm may be broken. The end that the harness plugs into has 3 holes. As you can see above the lid switch has 3 wires. 2 live wires and one green ground. You can jump the washer out using a horseshoe shaped wire or equivilent. Newer models have the ground wire on one end. Not good! Look for that before attempting to jump it out. At any rate their are 3 wires. One of them is always green and always mounted to the frame. The other 2 are live. You can jump them to magically make that puppy spin and pump. Not recommended to leave it that way. For testing purposes only. Some repair pix with manuals.
Sep 13, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Front load washer doesn't spin
My Maytag® Neptune® washer filled with water, but it won't spin or drain-what now?
Start by making sure the machine is plugged into a live (working) electrical outlet. Then check the appropriate circuit breaker and reset it if necessary (or check the fuse if you have a fuse box).
Next, inspect the drain hoses and remove any kinks. Take a look at the drain, too - if it's clogged, call your usual drain service person.
Then close the washer door and firmly press the START/STOP button. In a few moments, after the door locks, the washer should begin to spin. (For your safety, the washer will not tumble or spin unless the door is closed and locked.)
If this doesn't work, please contact Customer Service at 1-800-688-9900 for toll-free assistance and service scheduling if necessary.
Sep 02, 2008 | Maytag Neptune MAH5500B Front Load Washer
Washer won't complete spin cycle
Try pushing down lightly on the lid and see if the spin cycle starts back up. On mine, the same thing happened because the small plastic pin attached to the lid was just barely long enough to push the switch that tells the washer that the lid is closed. The spin cycle will only run when that switch is pushed, i.e., when the washer thinks the lid is closed.
Jan 06, 2018 | Maytag Neptune MAH6700A Front Load Washer
Washing Machines Logo
Dan Webster
Dan Webster
Sal DeAngelo
