Anyone know the total charge of 134a refrigerant for a 2002 toyota sienna?
    Scholar:
  • 104 Answers
The vast majority of vehicles take 2.25 lbs R-134a
Posted on Jun 28, 2008
How much freon does a 2002 Chevy Tahoe take with a 4.8 v8.The system has already been evacuated and is ready to be recharged.
Should have a sticker on the radiator core support that shows how much it takes . But if your's is missing here
Refrigerant System Capacities
Application
Specification
Metric
English
PAG Oil GM P/N 12378526 for United States
PAG Oil GM P/N 88900060 for Canada
Accumulator Replacement
-ml*
- oz*
* Add 60 ml (2 oz.) of PAG oil, plus the equal amount of oil drained from the accumulator.
Compressor Replacement
60 ml
2 oz
Condenser Replacement
30 ml
1 oz
The Delphi replacement compressor is precharged without PAG oil.
The Denso replacement compressor is precharged with 237 ml (8.0 oz) of PAG oil.
Evaporator Replacement
90 ml
3 oz
Evaporator, Rear Replacement
90 ml
3 oz
If more than the specified amount of PAG oil was drained from a component, add the equal amount of oil drained.
Total System PAG Oil Capacity
240 ml
8 oz
Total System PAG Oil Capacity with Rear A/C
330 ml
11 oz
R-134a
Refrigerant Charge
0.8 kg
1.8 lb
Refrigerant Charge Utility with Front and Rear A/C
1.2 kg
2.7 lb
Refrigerant Charge Suburban with Front and Rear A/C
1.4 kg
3.0 lb
Mar 15, 2017 | 2002 Chevrolet Tahoe
A/c for 2004 toyota sienna le not working
AC problem diagnosis should always start with a pressure test. AC problems are not usually solvable by DIY.
How To Find and Repair AC Leaks EricTheCarGuy
Mar 22, 2015 | 2004 Toyota Sienna
134a pressure
134a is a refrigerant...
Different type of dryer. The picture totally threw me at first.
http://www.ingersollrandproducts.com/am-en/products/air/compressed-air-treatment/non-cycling-refrigerated-dryers
Mar 09, 2014 | Ingersoll Rand Dryers
2002 Toyota Sienna
I have found a 2002 toyota key with the chip on it. Please let me know where you lost them!
Dec 28, 2011 | 2002 Toyota Sienna
Ho many pounds of LOW pressure refrigerant does the 2000 toyota sienna take.
If you are talking about the pounds PRESSURE (PSI), it depends on the ambient temperature. That information is what is on the dual set of gages that you see refrigeration techs using. If you are talking about the weight of the refrigerant to fully charge an empty system, there should be a sticker under the hood, near the AC system that tell you the type and how much to charge the system, it will also tell you how much and type oil to add. That all pertains to a completely empty system. The amounts specified by the Toyota are very important.
Also, you know that an empty system has to have the system purged of air and moisture, That has to be done by pumping a vacuum on the system for about an hour. That usually provides a vacuum of about 22"hg. If you have replaced a major component or have disconnected any connections you will have to do that. Knowing exactly how much oil to put into the system is a challenge unless you know that there is no oil in there now. So it take some expertise and equipment to charge a system correctly.
ALSO, IT IS IMPORTANT THAT I TELL YOU AND THAT YOU KNOW THAT IT IS AGAINST THE LAW TO CONTINUAL RECHARGE AN AC SYSTEM THAT HAS A LEAK OF REFRIGERANT. THE LAW SAYS YOU HAVE TO CORRECT THE LEAK BEFORE YOU CHARGE THE SYSTEM.
Thanks for using FixYa.
Gaker
Jul 12, 2011 | 2000 Toyota Sienna
Does a 1994 4runner use A/C refrigerant R-134a?
it take's 134a, if empty total charge is 1.62 lbs.
Jul 06, 2010 | 1994 Toyota 4Runner
Doe s anyone knows how to charge R12 Ge model
Keep looking for the access on the high and low side. Some of the valves look a little different but you should be able to find where to hook the gauges. R12, R22, and 134a all charge the same way and use the gauges and hoses. just make sure you have pressure temperature chart.
I hope this helps
Apr 20, 2010 | GE 21.7 Cu. Ft. Top-Mount Refrigerator...
2002 toyota sienna sliding door does not open since I went to the dealer
This is simple - go back to the dealer and tell them it worked when you took the car in ... and now it doesn't work and you expect them to do the repair for no charge.
Mar 21, 2010 | 2002 Toyota Sienna
A/C light inside of van blinks does this mean it
there may be an error with the compressor. since AC is especially complicated, have someone check the compresser and your hoses first, as you may also have a leak, and adding more 134 would be a waste of money.
Jun 12, 2009 | 2001 Toyota Sienna
2002 Toyota Sienna cabin air filter??
Unfortunately, no.
Toyota began installing the cabin air filters in the Sienna product starting in 2003.
Feb 25, 2009 | 2002 Toyota Sienna
Heating & Cooling Logo
75 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
