RCA 62" mod p46770ck need
RCA 62" mod p46770ck need schematic, probably just for power supply. TV shut down and appears dead.
  • Anonymous Dec 26, 2008
    I have the same problem. Yo can push the button and it lights up for about 1 second and goes back off.
Now I know the rest of the story: After I went to see the TV I was told it had happened after a storm the next day the set was dead. She had already recieved the insurance money. She said she did not want to spend much money on it as she obtained the set at a garage sale for 60 bucks 6 years ago. As I looked into the circuit board I noticed evidence of water damage and looking up the case and on top, yup, thats why she got it so cheap. I do think it is lightly damaged. As a grandmother of a close friend I didn't Intend to charge her but she gave me some bucks and the insides of the tv. I'm sure their isn't much time on it. If any one wants some parts on a 1993 RCA mod p46770ck (48" screen) contact me thru snailmail @ Whiskers, rr1bx57a zip 64632 Include your ph.# and I will call you. (I don't use the computer every day)
Posted on Jun 29, 2008
I need a vizio vo370M schematic diagram
has anyone found a place to buy a t2d diode 94 or t2d 94 diode for a vizio vo370m power supply board, placment d106
Dec 09, 2011 | Vizio VO370M LCD TV
Tip
RCA, CRT Projection TV, ITC222 chassis Faults - models D52W.., D40W.., D56W..,...
RCA, CRT Projection TV, ITC222 chassis Faults - models D52W.., D40W.., D56W.., D61W..
· Symptom: No Convergence, Picture is bowed and distorted, colors don’t align.
The Fuse for the convergence power supply has blown
You'll also notice that the convergence settings have disappeared from the on screen menu. The fuse likely blew because of a fault on the convergence board. If you've never done soldering or dismantled a TV before this is probably not the best place to start. The back cover needs to be removed and the fuse (see picture) identified, the deflection/power supply board needs to be unplugged (label or mark all connectors beforehand) and flipped over and the fuse checked/replaced. You need a soldering iron and solder ****** or solder wick and a multi-meter to check the fuse. If you want to tackle it yourself see attached image for reference or get a quote from a repair shop (approx $200-$300 Total) the convergence board may also need repair.
  • Symptom: Dead Set - TV Tries to Start or intermittent dead.
The set could be in shut down mode due to a fault detected in the power supply, vertical or horizontal deflection circuits.
The common problems with this chassis that will cause a dead set or intermittent dead set symptom are, bad power supply capacitors, bad flyback, bad HV cap in horizontal output circuit and cold solders (on opposite side of board) especially under the flyback area. To gain access to replace any of these parts the back cover needs to be removed and the deflection/power supply board needs to be unplugged (label or mark all connectors beforehand) and flipped over.
These are only the most common problems and it could be any number of other faults.
If you have electronic (TV) repair experience check the items mentioned (see picture), otherwise it's best to seek a qualified RCA tech for an estimate/service call.
· Symptom: Erratic operation of set – turns off by self, the volume or channel changes by self or on screen menu appears intermittently.
Switches on the front panel assembly (FPA) problem.
What happens with this model is the FPA switches (one or more) start to conduct just as if someone was pressing the buttons. This in effect locks up the system control or causes it to initiate erratic commands.
The way to determine if the FPA is bad is to remove it by unplugging from set. This requires front panel disassembly.
Note: The remote will still work with the FPA removed so the set can be tested.
Hope this helped, johnnydiode, Fixya.
on Dec 08, 2009 | Televison & Video
Samsung LCD tv standby lite flashing on and off
Your power supply board is dead, u know basic electronics' and soldering? Most of the times, the power supply board just have dead leakages gases capacitors.These capacitors always bulges up on it top,or puff up on it top.Replaced these gases leakages capacitors will get your TV power stable,and work again.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Good luck in solving the problem
Jun 26, 2011 | Samsung Televison & Video
2004 mitsubishi DLP 62 "
the timer light part is misleading you Carlos, i think it is probably the internal power supply start up which is failing im afraid you will need a techie visit sorry,George.
Nov 03, 2010 | Televison & Video
Unit is dead I need power supply schematics
U will not find schematic,the tv corporation don't release them.Just take the tv aparts.Tries Websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.Just compare the power supply board in ur tv and the website that selling the power supply board.The picture look alike,ask the seller questions.Just buy and replaced it.U know how to solders?Just searches around the power supply board for those bulges and puff up capacitors.Replaced these capacitors will get ur power back.Most just reqiure replaced these capacitors to get the power back.
Apr 21, 2010 | RCA L32WD26D HDTV/DVD Combo
Have a 06 rca hd61w66 powers on but screen dont come on! makes a weird noise an shuts down! like sumthin is tryin to start up but cant! n i took back off tv to see an the noise comes from a boared on the...
Thats the Power Supply. You need to call a service man, please disconnect this unit from the Power, It is dangerous to leave it plugged in. what is happening is the set has developed a serious fault, to avoid a fire or explosion, the PSU has shut down the set. that noise you hear is the power supply struggling against the fault. trying to start. Please for safeties sake, get a "Quote" from a reputable, preferably an RCA recommended service centre.
Mar 28, 2010 | RCA HD61W66 61" Projection HDTV
Rca 42 in lcd it shuts off 5 sec after being turned on
This could be a power supply problem, these tv's use a series of switching mode power supplies usually mounted in the same circuit board , the light flashing is an indicator that this is the problem, but these boards are expensive so you may want to get the tv looked at before anything else. You do not mention if the sound remains in your description of the symptom, but just in case it does then a back light inverter could be at fault. hope this helps. thanks for leaving you feed back.
Aug 27, 2009 | RCA L42WD22 42 in. LCD Television
RCA Rear Projection TV P46770CK spark beneath chassis when power applied
It sounds to me that you may have a cold solder joint ( loose connection on the board ). I suggest you remove the board ( or seek professional assistance ) and solder any loose connections that you may find. That may correct the problem. Good Luck.
Ed
NC Electronics
Mills, Wyoming
Have a Great Presidents Day
Feb 17, 2008 | Televison & Video
Dlp sony
as set is dead the problem is in power supply or horizontal section. though it is a simple &less time taking. but if you have no TV repair experience, or any experience tracing circuit flow with a schematic, call in a tech to assist you with this repair. This tv set is not the place to be experiementing inside of. You probably have bad capacitors and transistors in the power supply or the sweep power supply. Good Luck.
Oct 02, 2007 | Televison & Video
RCA Projection TV MM52110 Won't Power Up
Being able to read a schematic and understanding how a TV works are two different things. These chassis that RCA used in these sets can be somewhat complex to troubleshoot. I would geuess that unless the power light comes on at all then you have a dead power supply in the TV.
Apr 14, 2007 | RCA MM52110 52" Rear Projection HDTV-Ready...
Televison & Video Logo
117 people viewed this question
Top Televison & Video Experts
