Madallion mistubishi 1080 hd projection TV- wierd picture
I get great HD picture over satellite.  I hooked up Raku box and had great picture but next day, and the picture on everything but satellite is really bad with lines going through verticle, from nit Wii and Raku  ( from Netflix). What the heck did I do wrong ??
  • mikekcrade Jun 27, 2008
      I have done that.  I have used different rca  inputs, and same verticle lines for the Wiii and the  DVD,  and Raku, but Raku set  up at different TV works find.  The picture for the HD TV is great.
      are you saying interference from some other source ? If so why does the rest of the TV HD work so well ??  What should I do  ? I live in a pretty  big house and no neighbors are close by. IT must be something inside the TV ,  is it possible / or should I somehow reset the TV ? Will I screw  up the HD ??
  • 3,037 Answers
Did you have any weird power fluctuations. Try hooking the Wii and Raku box through a different input
Posted on Jun 27, 2008
    Master:
  • 848 Answers
You may not have received proper signal ..........there may be lot of attenuation and other particle which reduces the signal strength
    Brigadier General:
  • 3,614 Answers
If there was no settings has been changed, kindly check press the connections.
  • micromaster
    micromaster Jun 27, 2008
    try to adjust the screen resolution of the tv
Screen view area or size, font and channel logo are too large and outside the viewing area, how do we reset ?
Using your cable remote or satellite tv remote as well as the one that came with the television itself. Press the hd zoom # button on the cable remote. Satellite tv remotes will have format or aspect. For satellite tv receivers you may have to go into the menu on the satellite tv box to adjust the picture format i.e. 1080i crop and etc.
Make sure you have the television on the right input for hd and that the cable box or satellite receiver is displaying 1080 i.
Jul 20, 2011 | RCA L42FHD2X48 42 in HDTV TV
How do I get the HD on this model? Which cables/hook up should I use? I do not have a cable box or set top box but if these are required, please let me know. Thanks!
Your unit is HDTV ready but is not an HDTV. It is capable of displaying HDTV only through the component inputs. Your tuner is analog NTSC and will not receive HDTV or digital.
You could get an HDTV picture using a Blue Ray DVD and hooking up the component connectors from the DVD to the TV.
The only other way would be to get an HDTV tuner with a component output and hook it up the same way, component out to component in, and hook the tuner input to an off air antenna (receiving HDTV) or cable or satellite with HD signals.
Thanks for using FixYa and for the great rating.
hardrocko
Sep 21, 2010 | Sony KP-51WS510 51" Rear Projection...
It say 480 stretch on the screen how do I turn it to 1080 for my Hd tv
Make it sure that you have a 1080 signal from your source(eg. HD receiver, bluray player etc.). Try pressing format button on the remote until you get full picture . Or try changing the format or aspect ration in your satellite or cable box.
Dec 29, 2009 | Mitsubishi WS-65511 65" Rear Projection...
BLUE RAY 1080 (p) PLAYERS INHANCE VISUAL HD ON 1080 (i) tV
try to see if u have hdmi slots and check the highest resolution it can go.there is a higher resolution called hdcp,with not div x but dvi-d where resolution can go up to 20000
Feb 06, 2009 | Mitsubishi WS-65513 65" Rear Projection...
No Picture after Wii Play: 65'' Mitsubishi HDTV 1080 (WS-65511)
mmm try this.... do u guys have the yellow white red cables hooked up to the front of the tv from the wii console? try loosening them up. worked for me. let's see how long it lasts .... !!!!
Dec 27, 2008 | Mitsubishi WS-65513 65" Rear Projection...
I cant get high def 1080-i to work on my mitsubishi 55807
IYou have to have your comcast box tuned to a channel that is broadcast in HD. On your Comcast remote hit menu. This will bring up several icons, one is HD. Select that icon and it will bring up the TV Guide for just HD channels. Select one and tune to that channel. Once your on that channel use your original remote and hit menu, then advance features, then go down to video display and change it from 480 to 980 or 1080. Let me know if this helps.
Dec 15, 2008 | Mitsubishi WS-55807 TV
Great Picture But No sound
Good Day;
Look in owners manual pages 28-35, pay special attention to page 31 and make sure the antenna is connected to ANT-DTV input. Good Luck, big IRISH.
Sep 18, 2008 | Mitsubishi WS-65809 65" Rear Projection...
HD Hookup on Dish Network 2nd Location
In order for you to receive HD broadcasting you must have a HD-TV, otherwise you wont get the picture in HD. Also I should point out that you need to make sure that the signal itself is being broadcast in HD.
Apr 28, 2008 | Mitsubishi WT-46809 46" Rear Projection...
Televison & Video Logo
46 people viewed this question
Top Televison & Video Experts
