Question about Goodman Heating & Cooling
Janitrol ar 30-1 air handler doesn't blow very strong.
Janitrol ar 30-1 air handler weakly blowing
chillmaster
  • 104 Answers
SOURCE: Air handler only blows air for 3-5 minutes before shut off & not cycling frequently
Sounds like it could be a very weak run capacitor on the blower motor. Run capacitors are sized specifically to the needs of the motor. When a run cap gets weak, the motor trys to compensate for it by drawing more power. More power draw = more heat in the motor, then the motor will overheat and shut off to protect itself. When the motor cools off it will automatically restart and run until it overheats again. Keep in mind that I am a technician that normally diagnoses equipment in a hands on manner. There are many practices and concepts that transcend all air conditioning systems but it is a constantly evolving industry. I live in south eastern WA and I don't see Amana units except as window units. It is possible to have something else causing this problem (faulty thermostat, failing thermal relay(if used), problem with electronic controls(if used)) there are a lot of potential variables
Posted on Jul 02, 2008
cactus bob
  • 267 Answers
SOURCE: fuse blowing on tappan air handler
most of the time its out by the ac unit . you have a shorting thermostat wire .. the outside unit has a large wire thats 240v and a small one that 24v thats the one you want to look at . look for bare wires , look where it goes into the wall , thats the common place . "critters" love to chew thermostat wire . so take a look . .....please rate this answer , i need votes . thanks
Posted on Jan 24, 2009
  • 233 Answers
SOURCE: Janitrol air handler blowing out tepid air - Dry overflow pan
sounds like you have airflow issues, the static pressure is such that the siphon action of the trap cannot overcome the static pressure caused by the blower, have you put a new high efficiency filter in the system? It is very rare to have to install a trap in a central unit... if the compressor is operating, a quick check for charge is the suction line, (the large copper line outside) will generally be cold and wet, you should also feel hot air discharging from the unit outside.
Posted on Jul 14, 2009
james3751
  • 614 Answers
SOURCE: ac fan on, blowing air, but not cold
Check outside unit if unit and compressor are running feel the large line to see if it is cold. If compressor is running and line is not cold possible charge problems. You may have a capacitor problem outside. they go out quite often. You can change this yourself, Open up outside unit and the cap is the silver bullet with terminals out the top. Bad cap can cause compressor to not operate and also the fan. You need to clean the coil inside or at leat check the coil to see if it is clean. You can clean theis with a toilet brush do not go against the coil bit brush with the fins. You may need to call a service tech but try these options first. russ
Posted on Aug 15, 2009
billyvangogh
  • 108 Answers
SOURCE: Goodman Air handler blowing fuse if switch outside unit not runni
Sounds like your compressor in your heat pump is siezed . You can try a "Hard Start" Capacitor...which basically gives your compressor a kickstart and works 95% of the time when compressors get older....It's hooked up in parallel with the existing Capacitor...if you're not familiar with Electrical etc I would call an expert and mention what I said . If this doesn't work you will likely need a new Compressor/Unit . You could also have a short to ground in the heat pump side....likely the compressor is the problem however the original Capacitor could also be the problem
Posted on Oct 27, 2009
My 2003 F-350 A/C blower doesn't blow strong.
may have a cabin air filter clogged. the filter is located behind the glove box. should be an access door on the HVAC box.
Jul 17, 2011 | 2003 Ford F350 Super Duty DRW SuperCab
I have a 2000 pontiac grand prix with a digital climate control system. The heat quit working, it doesn't blow out any heat. Now that it is warm outside the air stopped blowing out any air. The digital...
I have a 2000 pontiac grand prix with a digital climate control system. The heat quit working, it doesn't blow out any heat. Now that it is warm outside the air stopped blowing out any air. The digital temperature on the climate control is not correct. When it states that it is below 30 degrees on the ext and it is warm outside the air wont be cold. Once it starts going above 30 degrees the air gets colder. Today the blower stop working all together. Was told it maybe the climate control unit was bad. You can hear the door opening/shutting when you switch the temp from cold to hot. But there was no heat blowing out whatsoever in the winter time. Could you please give me your opinion on whether or not it is the climate control unit or something else?
Jul 11, 2011 | 2000 Pontiac Grand Prix
Can you tell me the motor specs on a Janitrol ar-30-1 Air Handler? And does the capacitor for this motor need to be a start capacitor or run capacitor? Thanks.
What are you wanting to know? the fan speeds? Or what controls the capacitor? What uf is the one in it now it will say like 370v/7.5uf or it may be like 440v/35+5uf. but to your question it would be a start but it want run with out it either. Is this a factory specified motor or universal?
Jan 15, 2011 | Heating & Cooling
What supply house sells haier air handlers in Atlanta ga
any 4 tonnes air handler will fit if you respect de gas for the unit if r22 than than r 22 air handler if r410 than r410 air handler you can put r410 air handler if r 22 not avalable but be sure that expension valve is compatible.
Dec 13, 2010 | Haier HC48C1VAR Central Air Conditioner
Ac sytem blows strong air but its warm
If the compressor and fan work in the outside unit, and the fan inside (air handler) works, probably the system is low in refrigerant which means there's a leak that has to be fixed and then recharge the unit.
Sep 04, 2009 | Carrier 38CKC030 Air Conditioner
Can somebody help,why is my Central AC blows
Most heat pumps have an auxillary heat. Many are electric auxillary heat with a heat strip in the air handler. A common malfunction is for the electric auxillary heat to operate when the heat pump is set on cool. To confirm this, locate the conductor that runs from the heat sequencer to the connection on the heat strip. You will see this on the top section of the air handler. Use the clamp on part of the amp meter over that wire. If the thermostat is set on cool and the heat strip is drawing amps, it means the heat is coming on while the heat pump is set on cool. There is usually one or two causes for this, either the sequencer is bad or there is low voltage wires usually behind the thermostat or in the air handler closet that are touching that shouldn't be touching.
If this is not the case, if its not a problem of where the heat is coming on with the air conditioner, it could be a case of the reversing valve malfunctioning. The way a heat pump works is it reverses the flow of the refridgerant. For instance, many heat pumps the reversing valve is activated in cool. That would mean that there is a low voltage circuit that activates the reversing valve when the heat pump is in cool. I'm not sure what model/brand your heat pump is, Goodman and Janitrol for instance, the heat pump reversing valve is activated in cool. In any case, if the reversing valve is not operating properly, when the air conditioning is set to cool it will actually be heating. Or you could set it to heat and it may actually be cooling instead of heating. Please check these two items first and if you have any further questions, please let me know. Especially if you know of any additional problems like the evaporater is icing up or if the air handler fan is not operating when it should.
Aug 31, 2009 | Heating & Cooling
Jul 14, 2009 | Ruud UBHC Air Conditioner
Air flow weak when set to heat
check for dirty cab air inlet or "HVAC" filter, or heater core is plugged from debris and air is being restricted and wont blow through. it works like a radiator, air ducts can also be getting stuck.
Jan 06, 2009 | 1983 Toyota Camry
Jul 02, 2008 | Amana PTH123B25AJ Heat Pump Air...
Heating & Cooling Logo
955 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
