Question about Lexmark X5150 All-In-One InkJet Printer
Unable to turn power on.
I've checked the connections, changed electrical outlets locations--still can't turn the x5150 on. what's going on.
    Problem Solver:
  • 11 Answers
The black rectangular power dongle is not inserted properly.
Posted on Aug 21, 2008
Electrical outlets in my 98 skyline fifthwheel stopped working.but there's power going out of the breakers
This is an indication of a failed connection. Somewhere. Since you probably do not know how the affected circuit was run, it's going to take some time - but it's not difficult work. But before we roll up our sleeves - first locate and RESET any Ground Fault Interrupter (GFI) type outlet. If any fail to reset - replace it with another GFI outlet with the same electrical rating. Pay attention to which cables and wires that are connected LINE and LOAD terminals wires when removing and replacing! Don't forget to check outlets on the outside of the 5th wheel.
Circuits fail almost always at connections. Wires and cables in walls don't just "break" in the middle. We need to check connections in the bad circuit. First, plug lights in all the outlets. Turn the circuit breaker for the bad circuit from ON to OFF. Note which lights shut off. With the break OFF, check the outlets that WORKED.
We're looking for the point that power entered the outlet box, but due to a failed connection is unable to leave it and feed the first failed outlet. Check and tighten all screw terminals and wirenuts. Check both hot and neutral wires. Make sure no wires are loose, pull out or are burned (cut and strip back these wires and reconnect / wirenut). Try to power the circuit to see if you found the problem after each check - if not - repeat at the next outlet that worked until you find the problem. If you are still unable to get it working after checking the working outlets, repeat the process on each of the non-working outlets. If still unable to get it working, check ceiling fixtures as it is not uncommon to wire to the light fixture first and then feed down to outlets.
Feb 02, 2016 | Electrical Supplies
No power
If it is not getting any power at all, only one of three things: cord is fried/dead; could be the outlet, try something else in the same socket; or, the board in the printer is dead.
1. Press the POWER button to power on the printer The device has a <POWER> button.
Connect the power cord from the printer to the electrical source.
Press the <POWER> button.
Wait until the device has completed its cycling process before submitting a print request or completing installation.
2. Disconnect and Reconnect AC power adapter or power cord to the device and electrical source
  • Disconnect the AC Power Adapter or power cord from both the device and the electrical source.
  • Then reconnect it.
  • If you are still unable to obtain power to the device, try another power outlet.
  • If possible, try connecting power directly to a wall outlet (as opposed to using a surge protector or power strip...just as a troubleshooting measure).
3. Disconnect and reconnect the electrical cord to ensure a secure connection 4. The iP6000D may require repair
For toll-free technical support, please call 1 (800) 828-4040 during regular business hours (currently Monday-Friday 8:00 a.m. - 12:00 midnight. EST, Saturday 10:00 a.m. - 8:00 p.m., excluding holidays).
5. Try a different electrical source / outlet
this will surely fix your problem..
Dec 06, 2007 | Canon Pixma iP6000D InkJet Photo Printer
My Remington Keratin Therapy Flat Iron Doesn't Turn On.
see thi steps and fix it.God bless you
If the iron doesn't heat, make sure 1) power is on to the outlet, 2) check the electrical cord and 3) check the thermostat and replace if necessary. Use the VOM.
Oct 15, 2012 | Remington Style Therapy: Keratin Therapy...
My hobart n50 mixer,when pluged in does nothing at all. why? and what to do?
The N50 is a heavy duty / commercial counter top mixer. It is available in several different versions for different power sources. Make sure yours is the model for use with the power available at your location. The power versions are:
100-120/60/1, 100/50/1, 230/50/1, 220/60/1 and 230/60/1
This lists the information in the following format: voltage/frequency/phase. If used in the US or Canada (and many other parts of the world) you would most likely want the 100-120/60/1 or the 230/60/1 version. All are single phase, so this shouldn't be an issue to worry about. Use of any of the other versions could result in shortened life expectancy of the mixer or immediate, catastrophic failure of the mixer and possibility of burns, shock or electrocution if connection is attempted.
If the mixer matches the power available, check for proper wiring at the source point of connection and in the mixer. You may need an electrician to change the power at the connection point from 100-120/60/1 to 230/60/1 (or vice-versa since BOTH are available in North America). Also check to be sure that fuses or circuit breakers in the electrical panel are intact and on. Do not overlook GFI outlets if using the 100 to 120/60/1 version. Reset any tripped GFI outlet. If still unable to operate, verify that power is present at the connection point. If unable to operate, contact an electrician to check the power and wiring of the mixer.
The mixer data sheet is available here.
Jul 12, 2011 | Hobart N50 Stand Mixer
My apple ipod touch wont turn on
I've seen this before. You need to reset it.
  1. Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.)
  2. Press and hold the Play/Pause and Menu buttons simultaneously until the Apple/iPod logo appears, about 6 to 8 seconds. You may need to repeat this step.
If the above steps did not work, try connecting iPod to a power adapter and plug the power adapter into an electrical outlet, or connect iPod to your computer. Make sure the computer is turned on and isn't set to go to sleep.
If you are still unable to reset your iPod, use only one finger from one hand to press the Center (Select) button, and one finger from the other hand to press the Menu button.
I hope this works!
May 10, 2011 | Vacuums
I have a Dell optiplexGX520 and my grandson changed my admin. password and forgot the new password.Now I am unable to get into my system. But, I still have the manufacture disc that came with the computer.
Jumper
Setting
Description
PSWD
Password features are enabled (default setting).
Password features are disabled.
RTCRST
The real-time clock has not been reset.
The real-time clock is being reset (jumpered temporarily).
advfea28.jpg jumpered advfea29.jpg unjumpered
  1. Replace the computer cover.
  2. Connect your computer and monitor to electrical outlets, and turn them on.
  3. After the Microsoft® Windows® desktop appears on your computer, shut down your computer.
  4. Turn off the monitor and disconnect it from the electrical outlet.
  5. Disconnect the computer power cable from the electrical outlet, and press the power button to ground the system board.
  6. Open the computer cover.
  7. Locate the 2-pin password jumper on the system board and attach the jumper to reenable the password feature.
  8. Replace the computer cover.
notice.gif NOTICE: To connect a network cable, first plug the cable into the network wall jack and then plug it into the computer.
  1. Connect your computer and devices to electrical outlets, and turn them on.
note.gif NOTE: This procedure enables the password feature. When you enter system setup, both system and administrator password options appear as Not Set-meaning that the password feature is enabled but no password is assigned.
This solution can also be found here:
http://www.mccracken.k12.ky.us/techweb/Computer%20Maintenance/advfeat0.htm#wp1134361
Jan 23, 2011 | Dell OptiPlex GX520 PC Desktop
My lexmark x5150 won't turn on. could it be the power cord? It ma
Please follow the instructions given below to troubleshoot the power issue:
1. Connect the printer directly to the power outlet. Surge protectors can actually draw power away from the printer. If this fails, please try multiple power outlets to ensure your specific outlet is not damaged, and make sure the printer is not connected to the PC while testing the unit.
2. When trying to power on the printer, feel the power supply box (if there is one) and note whether or not it is warm. If it is warm, the problem is not in your power supply, but most likely in your printer. If it is cold, the power supply might be defective.
3. Ensure you have the correct power supply connected to the printer.
4. If you have access to a voltmeter, please ensure that the power supply is giving out the correct amount of voltage (most of our printers use 30 volts output).
Apr 13, 2009 | Lexmark X5150 All-In-One InkJet Printer
Printer doesn't turn's on
Per Canon:
Solution: Disconnect and Reconnect AC power adapter or power cord to the device and electrical source
Secure all Power Connections
If this does not work, have you tried a different outlet to ensure that the outlet isn't the issue? Also, when you press the POWER button, does the printer respond at all, or is it basically dead?
Please post back if you need further help, otherwise, thank you for using and rating FixYa!
May 24, 2008 | Canon PIXMA iP1600 Printer
Lexmark X5150 All-In-One InkJet Printer Logo
19 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Roopesh S
Roopesh S
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
