Question about RCA RT2500 System
RCA RT 2500
I have an RCA RT 2500, and it was working fine until the power went off yesterday. When the power came back on, the unit was in standby mode, and it would not come on no matter what I tried. I tried the solution posted online (stadium - night - dsp off - club), but it did not work. Please help....
Jeremy A. Rife
502-797-9322
jallanrife1976@msn.com
Try unplugging it and pluggingg it back in. That works for me.
Good Luck
Posted on Jun 29, 2008
My rca home theater reciever rt2760 seems to be
Have you tried unplugging and plugging it back in? If that doesn't work, then you might have some bad capacitors in the power supply that aren't allowing it to switch to "on."
Sep 24, 2014 | Audio Players & Recorders
Sony dab fc7 wont power on
Two thing here.
#one the internal fuse has blown unlikely as the standby light is powered.
Two the power supply unit or switch is faulty.
get some one electrical component with the unit unpluged open the case and check any internal fuses have not blown.
Two check capacities on the power board these are large cylindrical shaped objects. These can dry out and or exploded if faulty relatively cheap to replace.
Second check the power switch actual powers the unit again someone with a multi meter and electrical compertent.
It is probably worth replacing either a capacity or switch anything else may prove false economy
I have replaced power board on other units but to be honest unless the unit was very expensive I would buy new
Dec 06, 2013 | Audio Players & Recorders
Model RT2500/ RT 2500R. Standby button is lit but when I press it the home theater fails to turn on
I had the same problem. I held down the power button while plugging the unit into the wall and it fired right up. works fine now. You might have to do this a couple of times but mine was fixed on the first try.
My model is the RT2500
Sep 01, 2009 | RCA RT2500 System
I have a HT-X40 Samsung home theater that worked fine until yesterday. It's been used very little to this point but now it won't turn on. I was watching a DVD yesterday morning then hit the stop button on...
I would say the DVD was stuck in the unit. Try pulling on the drawer whilst hitting eject. Also try pushing on it doing the same thing. Keep on trying to play it also, sometimes the control system and the mechanics get out of synch and need a little bit of help. But first thing - have you tried disconnecting the power completely (at the chord) and leaving it for about 10 minutes? Always a good first thing to try.
Aug 03, 2009 | Samsung HT-X40 System
Power goes off
Try resetting the unit.
Make sure there is no disc in the unit. With the unit on, go to the front panel and look for the STOP (square) button.
Hold it down until the unit shuts off by itself. Turn it back on it shoudl work fine.
Jul 01, 2009 | Samsung HT-X40 System
How do you reset the system (RT 2500 )
unplug and hold the power button while turning unit on. it will start back in demo mode.
Jun 19, 2009 | RCA RT2500 System
Rt2280 no power up, no display, standby light works
Might be the relay on the power board that stands up just behind the big transformer. I has a complete no power also, I shorted out the relay legs on the black one, it started to work again. I will probably replace it, since the problem started by the system shutting off randomly.
Oct 19, 2008 | RCA RT2280 System
Only standby power
most likely the unit has suffered a spike sorry but nothing can be done service will be required
Jun 06, 2008 | RCA RTD255 System
Rca rt 2500
do you have antennas hooked up to the back? if you do, make sure they reach a high place.
Feb 26, 2008 | RCA RT2500 System
Power cord for a rt 2500
Sandworms, that is the exact problem I had after a power out. It doesn't look the same as ducast's problem though. I posted the same solution in another thread. Here's hoping it works for you too.
When the red LED on the power button would glow, but it wouldn't turn on. Try unplugging it and plugging it back in repeatedly and it will eventually turn on. If that doesn't work try moving it to another outlet then try plugging it back in and out.
Oct 29, 2007 | RCA RT2500 System
RCA RT2500 System Logo
255 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
