Question about Ricoh Aficio 1035 Copier
Fax error code on Ricoh 2045
1503 is the error code. There was no SC in front of it. That error code doesn't exist in the service manual.We reseated the fax card for now and the error code hasn't come back yet.
Any ideas?
  • 1 more comment
  • Tim Babcock
    Tim Babcock Jul 02, 2008
    This one we found the solution. RX faxing to SMTP was turned on. We turned it off and the problem went away.
  • Tim Babcock
    Tim Babcock Apr 02, 2009
    See the second thread below:
    It wasn't in the book but a tech on copytechnet.com knew the solution when I posted it on there forum. It was the correct code.
  • Tim Babcock
    Tim Babcock Apr 03, 2009
    Thanks.
  • 32 Answers
Network errors, like the 15-03, that you are receiving, have to do with fax "forwarding". the errors are thrown because the proper destination, or setup of the destination, for the forwarded faxes, are incorrect.
personally, i have not seen any 15-whatever codes. all the codes that i have dealt with are 14-01, 14-09, and 14-33. please double check the code that you are getting, and check the settings on copier.
14-01 and 14-09 codes usually mean that the smtp server name is incorrect, or the administrator e-mail address has not been added to the setup of the machine. although, it is still possible to e-mail directly without the administrator address being programmed. fax forwarding canNOT work without it. hence, the codes.
14-33 code usually means that there is an issue with the folder destination that the machine is trying to send to.
Posted on Apr 02, 2009
WHY RICOH AFICIO MP 171 SPF IS SHOWING SERVICE CALL SC 542.
Reseting SC 543 error code on Ricoh copier
Press CLEAR MODE(yellow) key,
Press 1 , 0 , 7
Press and hold down CLEAR/STOP (red) key for more 5 sec.
Press in the SP Mode( on the touch pane)
Go to sp5810 and reset SC code
Open the front door turn OFF the power main switch, and turn it ON
Oct 18, 2016 | Ricoh Office Equipment & Supplies
I got error sc 554 for ricoh mp1600
Ricoh Copier Error Code SC 554 problem Reseting SC 554 error code on Ricoh copier
Press 1 , 0 , 7
Ricoh Error Code SC 554
Heating roller overheat (hardware error)
The heating roller thermistor detects 240°C or more.
Defective PSU
Defective IOB
Defective BCU
Defective fusing control system
1. Replace the PSU.
2. Replace the IOB.
3. Replace the BCU.
Oct 17, 2016 | Ricoh Office Equipment & Supplies
SC392 ERROR CODE
There's a video showing how to clear SC error codes: Resetting Ricoh Savin Lanier SC Error Code There's also a discussion here: Thread Ricoh Aficio 220 error SC392
Jun 30, 2014 | Ricoh 885288 Black Copier Toner Cartridge...
Service Call SC819
I found that this 'SC 819' occurs if you use the bypass tray for the scanner. I found also that this error can be fixed with an firmware update. See link. http://www.copytechnet.com/forums/showthread.php/32934-Ricoh-Aficio-2035-SC819-Error-Code?p=132762&viewfull=1#post132762
I have no idea how to do that at the moment, and I can't report the success of this way.
Jan 22, 2014 | Ricoh Aficio SP C240SF
WHAT DOES THE SC 38 MEAN ?? WHAT FAULT DOES THIS SERVICE CODE REFER TO?? I HAVE A LANIER 2138 COLOUR LASER PRINTER, (SAME AS RICOF AP3800 SERIES)
SC is for "Service Call". The error may be caused by a defect or an irritation of internal sensors.
Ricoh recommends to physically switch off the printer, wait for a few minutes and power on again. (Irritation by change in surrounding temperature)
If you recently replaced any movable parts inside, remove it again and reseat, many parts inside are checked by sensors for proper seating.
If this does not help, you need to call Ricoh customer service.
Feb 09, 2010 | Ricoh Aficio 3800CMF Laser Printer
Ricoh 1045 error code sc 672, 961
Controller to operation panel comucation error at start up.Check the controller stall,controller board installed correctly operation panel connectors.Enter im the service menu ,press the SP mode,open the front door,turn off the copier,unplugged the machine.Wait 10 seconds,plugged on the machine,close the front door,turn ON the copier and make a copy.
Dec 28, 2009 | Ricoh Aficio 1035 Copier
Error code sc211
This error code SC 211 not exist.Exist SC 2-11 is the communication problem.For reset the SC codes following the procedure:enter in the service mode (press total clear key-1-0-7-Clear keyhold down more 3 sec.Enter SP 5-810 SC code reset and select `1`.Then hold down the original type key and the OK key at the same time.This does not require the main switch to be turned OFF and ON.
Aug 12, 2009 | Ricoh Aficio 2015 Copier
Ricoh Service Code error - Service Code SC-300
I am a Ricoh tech and my service manual doesent have a 300 code,
Jun 09, 2009 | Ricoh Aficio AP3800C Laser Printer
I have a Ricoh 2045E I changed the toner and now get a SC680 error?
There are no SC 680 codes listed in the service manual for a 2045e
Please re check the code
Feb 26, 2009 | Ricoh Aficio AP3800C Laser Printer
Ricoh Aficio 1035 Copier Logo
3,618 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
