Try keeping your psp battery in a dry place for a day,then try charging.If this doesn't work.. Try the following: a) Try charging using a usb cable... c)Also try cleaning the usb port and power port or the place were u connect the charger to psp... b) Remove ur psp battery and plug in the charger and turn on the psp... When it turns on put the battery back in (do not turn off the switch or psp when u put the battery back in)...
Are you plugging the charging plug into the PSP?There are two plugs on the USB cable 1.the USB plug. 2.the charger plug itself. The USB cable looks like the other end that plugs into the computer only smaller.The charger plug looks like the ordinary AC adaptor.
Also note that You need the computer/device that the PSP is connected to,must be turned on,well this is true with mine anyway.
Also the USB does not charge the PSP as fast as the AC adaptor.
Probably, either the battery or the charger is busted. Try borrowing a friend's PSP charger and plug it in. The power led of the PSP should turn orange when charging. If it still does not charge, you might need to replace the battery.
Remove the battery. Plug the PSP charger into the PSP. Turn it on.
The PSP works with no battery inside. If you're not getting a green light at all, your PSP has some sort of damaged as it should work while plugged in with no battery inside.
it is shot. a quick test is try another psp and charge it with that one.if it does charge then it is your psp and your psp might be fried.if the battery doesn't charge then try another known woking battery.if you got any more qeustions email me at [email protected]
u cant charge on a computer unless you have a charger that hooks up to it...are you sure your using a charger or are you using the cord that transfers data to ur psp! the data cord will not charge ur psp its not a charger all it does is transfer data sorry you need a charger for the psp not a data cable
umm, what exactly are u plugging it into
