RCA RTD160 System Logo
Angelo Milella Posted on Dec 06, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do I unblock parental controls on my PC??
Anonymous
Level 3:
  • Master 687 Answers
  • Posted on Dec 06, 2010
Anonymous
Master
Level 3:
Answers
687
Questions
Helped
232101
Points
1972
You will need admin rights to do this I could help you hack into your system Admin account but that would prevent the Parental limitations which is probably a good thing to have.
I downloaded fxnow on the XBox 360 andmy Samsung s7 activated it changed the parental controls and it didn't unblock any movies
  1. Parental Controls on Xbox 360:
    • Check the Xbox 360 parental control settings. These settings can restrict access to content based on content ratings. Make sure they are set to an appropriate level for your preferences.
    • If you've forgotten your Xbox 360 parental control passcode, you might need to reset it. You can do this through your Microsoft account or contact Xbox support for assistance.
  2. Activation on Samsung S7:
    • If activating the FXNOW app on your Samsung S7 has changed the parental controls, check the settings within the app to make sure you have set the appropriate level of parental controls. There should be an option to customize these settings within the FXNOW app itself.
  3. Unblocking Movies:
    • If you're having trouble unblocking movies, it may be related to the parental control settings within the app. Adjust the settings to allow access to the desired content.
  4. Account Syncing: Ensure that you are using the same FXNOW account on both your Xbox 360 and Samsung S7. Sometimes, parental control settings are associated with your account, so if you're logged into different accounts on the two devices, it might cause discrepancies.
  5. Contact FXNOW Support: If the issue persists, it's a good idea to reach out to FXNOW support for specific assistance related to their app and parental control settings. They can guide you on how to set up the controls to suit your preferences.
By adjusting the parental control settings on your Xbox 360 and within the FXNOW app on your Samsung S7, you should be able to customize the access to content and resolve any issues with blocked movies. If you continue to experience difficulties, contacting FXNOW support for further assistance is advisable.
Parental control issues
Unless you have changed the password (and where did you write it down? The manual gives you the unlock cod. Usually the are 00000(0)or 12345(6).Good luck. Unblocked in the list is 8.
I have a RCR universal remote. It turn the tv on/off but the red lock remains on my apex 2011s. What do I do?
The Apex prompts you to
enter a 4-digit code when you set up parental controls. You can block programs
according to their MPAA ratings or their content designations, such as V for
violence or S for sexual situations. You can override parental
controls on most Apex models by simultaneously pressing the F and mute buttons
on the remote control. If you own Apex models GT2011J or GT2011S, hold the
remote\'s display button for ten seconds. The red key will vanish and the V-chip
will unblock your program.
Apex\'s default parental
lock control code is 6688, so if you haven\'t set a new code, entering 6688 will
remove the red key and unblock your program. If you\'ve set a new password and
forgotten it, entering 3308 will reset the code and unblock your program. For more, http://electronicshelponline.blogspot.com/
1helpful
Need to know how to remove the red key on tv and code
When a red key appears in the lower left corner of your Apex television screen, the set's V-chip is engaged, preventing you from watching restricted content. You can override parental controls and reset your television's pass code with your remote.
Parental Lock
  1. The Apex prompts you to enter a 4-digit code when you set up parental controls. You can block programs according to their MPAA ratings or their content designations, such as V for violence or S for ****** situations.
Disabling the Lock
  1. You can override parental controls on most Apex models by simultaneously pressing the F and mute buttons on the remote control. If you own Apex models GT2011J or GT2011S, hold the remote's display button for ten seconds. The red key will vanish and the V-chip will unblock your program.
Override Codes Apex's default parental lock control code is 6688, so if you haven't set a new code, entering 6688 will remove the red key and unblock your program. If you've set a new password and forgotten it, entering 3308 will reset the code and unblock your program.
2answers
How do i unblock woozworld.com
check your parental settings - log in as administrator and turn off parental settings. this should solve the problem on a windows 7 machine.
How to unblock parental control regular xbox
Here is the procedure to
reset the parental lock code:
  1. From the XBOX dashboard screen, go to settings and then parental control.
  2. When prompted for the password, perform the following sequence using the XBOX controller: X, Y, Left Trigger, X.
  3. Enter in a new password, or disable parental control entirely
HOW TO UNBLOCK FACEBOOK IN A PERSONAL COMPUTER
First, what type of browser you are using accessing facebook? You need to check the browser security options, check if the facebook blocked. If non then check if the computer you are using has parental controls, try to disable the parental controls it the software is not asking you some passwords. Also check if the computer has firewall advance settings blocking the facebook site.
2answers
My laptop wont let me go on face book,but will any other sites.says oops can u help me pls thanks
this happens if facebook site is blocked wither by you browser or a virus
some browsers support parental control which allows you to block certain sites if you dont want your child to view it
some virus are made in order to block high traffic sites like facebook to annoy the user
for a virus prob get better security
if its parental control, charm your way to you parents to unblock the site
1helpful
Fpa lock on how do i get this offf
hello Lock/Unlock Parental Controls
Selecting this option lets you lock and unlock parental controls settings
using a password.
If you do not lock parental controls, none of the settings for V-Chip,
Channel Block, or Front Panel Block will take effect.
If you forget your password, press the MENU button, then select Parental
Control
(the password entry screen appears). Simultaneously press and
hold CH+ and VOL+ on the front panel for 8 seconds. Parental Controls
unlock and the Parental Control menu appears. You can enter a new
password by locking the Parental Controls again.
Front Panel Block
Selecting this option lets you block (disable) or unblock (enable) the TV’s
front panel. The remote still tunes to any channel. When using this as a
Parental Control method, remove access to any remote that is capable of
operating the television while you have the front panel blocked.
Don’t forget to lock parental controls after you change the status. If you
don’t, the front panel block will not take effect .if this don't work get back to me i've got manual good luck
shaun
86helpful
19answers
Top RCA Audio Players & Recorders Experts
 Grubhead
Grubhead
Grand Canyon Tech
Grand Canyon Tech
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
