You shouldn't need any installer. Support for your drive is part of Windows already. It's just a standard CD drive. If the drive is properly connected (data cable plugged in at both ends and power plug seated) and Windows doesn't detect it, there is something wrong with the drive or you have a bad data cable.
Click on
Start, Run, and type regedit and press
Enter
Click on the plus signs (+)
next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder
is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the
following names in the right hand column.
Upper
Filters
Lower
Filters
Upper
Filters.bak
Lower
Filters.bak
If any of the above keys shown in step
4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and
check to see if your CD or DVD drives have returned. You may also want to open
Device Manager and verify that the yellow exclamation and error code on the CD
or DVD drive is gone.
Hope this helps
click start control panel,administrive tools,computer management,device manager scroll to cd/dvd rom drives right click properties then properties again then tick enable cd digital cd audio for this cd rom device or scroll to dvd regions select the no _ for your specific area
hope this helps
