Question about Philips HDD1630 MP3 Player
My mp3 2gb gogear
Every time i try to turn it on I see a bettery flashing and I have had it pluged into my computer usb for a long time and it looks like it telling me the battery is low. Do I need to replace the battery? why woun't it charge? I have lost my owners manual can I get a new one or replacement?
SA5125/37 SN KN1A0720007394
  • 8,596 Answers
Batter is not replaceable - go to and get the firmware upgrade for the player - or, you can just open the Philips Device Manager and click on the "Update" button
Posted on Jul 06, 2008
My philips gogear vibe wont turn on
Reset your GoGear with something sharp like the tip of a pen or the end of a paper clip,
if you're device isn't working properly or there's a frozen display.
Insert the sharp object into the "Reset" hole (located at the bottom of the player), and hold it there until the device turns off.
If resetting the device does nothing to restore the display, access the "Philips Device Manager" through your computer to recover the GoGear.
Click "Start" on your computer, then "Programs," "Philips Digital Audio Player," "Aria Device Manager," and then "Philips Device Manager."
This will launch the "Philips Device Manager." Make sure the GoGear is turned off completely. Connect your GoGear to your computer while holding down the "Volume Up" button.
Continue to hold the "Volume Up" button on your GoGear, until the "Philips Device Manager" recognizes the device and enters recovery mode.
Click the "Repair" button when it appears on your computer, then folow the steps to fully recover the GoGear.
Properly disconnect your GoGear from your computer and restart the device.
Recharge your device if your GoGear dies suddenly while playing.
Connect the GoGear to your computer via the supplied USB cord.
Plug one end of the USB cord into a functional, open USB port on your computer. Plug the free, smaller end of the USB cord firmly into the small USB jack on your GoGear and turn your computer on.
This will begin the charging process of your GoGear.
If recharging doesn't work, the battery may need to be replaced.
Check that your GoGear isn't in standby mode. Hold the "Power" button for two seconds to turn it back on.
hope this helps
Oct 07, 2012 | Philips GoGear ViBE SA1VBE08K MP3 Player
After instal a pendrive in cpu it doesnot disply in my computer & doesnot flash is working
Did you go to my computer,,thats how you open or find a flash drive,,hit my computer and it should be there removible disk,,,if not try pluging it in and restarting computer,,also try wesite of the usb to see if any updates or u may need new driver,,but I never had any flash drive do that so,,could be faulty or went bad,,tap it on a hard surface a few times ,,could free the disk,,it works eith seized hdds ,,so,,goodluck
Nov 20, 2010 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
Brand new gogear keeps freezing up when I connected to computer
Do you allready try in other computers?
Turn off your antivirus, and try to connect
its your computer usb 2.0 (when u connect mp3 player to your pc show something like This device works better in a 2.0 usb port?)
Some times a non original version of Xp dont really works good whit usb devices as digital cameras, usb flash memories, cell phones, and all in one printers (extraible disk drives); In This case try first in other machine if this works reformat your machine o if you got the restauration cds used in your pc
Oct 17, 2009 | Philips GOGEAR SA6045 MP3 Player
I want to download philips gogear software for pc
Welcome To Fixya DIY Community^^
Its my pleasure to help You solving this Problem.
Its obvious that after the installation of a new Windows XP version in your computer, The GoGear Won't operate as usual Because it's missing drivers and the Music downloading utility in the computer Interface.
  • Now you should install the Drivers To Solve this Problem.
You can Download Drivers and utilities from the link below:
Aditional Support:
--ask me if you need any further info. i am always available.^^
*do not use te software upgrade utility, install only the necessary drivers for your MP3 Player.
the upgrade utility is useful when the firmware of Your MP3 player is corrupted or defective.
Jul 12, 2009 | Philips GoGear SA178 MP3 Player
My phlips gogear will not turn even when i plug it in
try holding the up volume button and the power button until it powers up and see if that makes any difference for you.
if not the device may have a corrupt board as many other GoGear products similar to this one have the same problems
Mar 12, 2009 | Philips GoGear HDD6330 MP3 Player
My mp3 player won't turn on
Make sure the hold/lock switch is not activated.
If it is not, then try a different USB port on your computer.
If you get the same result:
Triple Reset for Philips’ GoGear:
Disconnect the Go Gear from computer. Press the reset pinhole until the player turns off. Hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard. If this pop-up does not appear, reset the player again WHILE connected to the computer. Open the Philips Device Manager, and go to Repair Tab. Reset the player one more time while connected to computer. Follow the repair instructions.
After repair is complete, upgrade the firmware for this player. Will erase all the songs, but you should be good to go again.
-Tha Mp3 Doctor
Jan 17, 2009 | Philips SA3025/37 Flash MP3 Player
Usb cord
Plug the Mp3 player to a diffrent USB Port and reboot the computer it should work
Aug 04, 2008 | Philips GoGear HDD1830 MP3 Player
My philips gogear 8gb won't come on.
you wil need to get windows media player 11 and update your usb drivers
Mar 26, 2008 | Audio Players & Recorders
Philips HDD1630 MP3 Player Logo
61 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
